POV-Ray : Newsgroups : povray.general : New video cards may offload POV Server Time
27 Oct 2026 15:54:47 EDT (-0400)
  New video cards may offload POV (Message 1 to 37 of 37)
Subject: New video cards may offload POV
Date: 24 Jul 1999 14:06:39
Message: <379a00af@news.povray.org>
Plain PaperTry this link
http://headline.gamespot.com/news/99_07/23_pc_nvidia/index.html
Looks like the next generation of video boards may start doing some of the
math currently done in POV.
Jim
Check out my web site  http://www.kressworks.com/
It'll blow your mind (politically), stimulate your senses (artistically)
and provide scientific insights that boggle the mind!
Subject: Re: New video cards may offload POV
Date: 24 Jul 1999 15:21:39
Message: <379A11BC.A1FF9EA@pacbell.net>
> Jim
Sorry Jim but it won't help Pov in this case.
Ken Tyler
mailto://tylereng@pacbell.net
http://home.pacbell.net/tylereng/links.htm
Date: 24 Jul 1999 23:37:23
Message: <379a8673@news.povray.org>
Really?  Even with the onboard shading, lighting, and rendering functions?
Or would a card specific version of POV be required to take care of those
functions?
Jim
Ken <tyl### [at] pacbellnet> wrote in message
news:379### [at] pacbellnet...
the
> > Jim
> Ken Tyler
Date: 24 Jul 1999 23:46:26
Message: <379A8802.F53A31D2@pacbell.net>
> functions?
> Jim
 With the current way that Pov works it calculates each pixel internal to the
program before it outputs to the screen. There are no internal routines that
take advantage of external hardware accelerations. If you read the literature
carefully they make reference to direct x and openGL instruction sets which
are specificaly written to take advantage of such abilities. Pov works in a
completely different way. There's has been a lot of talk about writting an
openGL preview mode for Pov but it is problematic and would still not help
for final renders. Quality of the images produced but direct X and openGL
are inferior to Pov's raytracing methods anyway and I personaly think it
would be a step backward.
Ken Tyler
Date: 25 Jul 1999 07:19:06
Message: <379AF3E8.AF37E7C3@puzzlecraft.com>
What Ken states is true. However, there are accelerator boards for professional
graphics that will accelerate POV-Ray. Daystar sells them for the Mac.
Basically, they work by replacing your motherboard with a quad-CPU motherboard.
They are expensive and top out at 1,800 mhz.
If you really want speed, Silicon Graphics has a motherboard that can support
256 alpha RISC CPU's which are now running at 1,000 mhz for a total speed of
256,000 mhz. Better have some really deep pockets for this.
A low budget solution is to get a dual Pentium Dell server and run it as a
workstation.
steve
> > functions?
> > Jim
> Ken Tyler
Date: 25 Jul 1999 09:20:43
Message: <379b0f2b@news.povray.org>
Steve <ste### [at] puzzlecraftcom> wrote in message
news:379AF3E8.AF37E7C3@puzzlecraft.com...
> workstation.
    Can you elaborate on this a little? I have been having some sort of
thought like this... getting a box and a motherboard and a network card and
using that box to do nothing but renders. No keyboard, monitor, mouse,
soundcard, videocard, with smallest possible HD, lots of RAM...
    But, since I have never done any networking but some serial port copying
of HDs...
Date: 25 Jul 1999 09:52:14
Message: <379B167E.84F30E41@plymouth.ac.uk>
What Bill is suggesting is buying a server similar too those found in
offices and running povray on that. What you're thinking of is buying a
bare-bones system to run POV. If you did that you'd still need the
keyboard, mouse and videocard (at the very least to install Windows
etc.) but you could save on the monitor by having a switch box (using
your existing monitor) or running it remotely using a piece of software
such as CarbonCopy. Networking is getting very cheap and what you're
suggesting is entierly possible, all you would need is the two network
cards, a cable and the software (Windows.) I've been doing this
successfully for nearly a year and only had a few minor problems.
	Graham.
> > workstation.
> of HDs...
Date: 25 Jul 1999 10:40:04
Message: <379b21c4@news.povray.org>
support
of
Sillygon Graphics have an ALPHA cpu running at a 1000Mhz,,
I thought digital (compaq) uses/builds alpha processors and SGI uses MIPS
(R12K being the latest edition, running at 300Mhz), and a SINGLE motherboard
supporting 256 CPU's, I know that their deskside origin2000 sports 1-4 node
cards, 2-8 cpu's. And an Origin2000 rack system can house 1-256 node cards,
2-512 cpu's (R10K or R12K), but that's the entire rack-system, not a single
motherboard.
Could you please give some details on this?
Regards, Jens Berg Churchill.
Date: 25 Jul 1999 13:15:45
Message: <379b42ae.212962279@news.povray.org>
  True, Ken. These cards are great for their intended use but we would see
no advantage. I don't think that incorporating OpenGL into POV-Ray would be
anything to crow about. We've already fast previews with more control by
using the quality switches (+q). OpenGL might be better suited to displays
from modeling programs, although I like Moray just the way it is now.
Alan
news.povray.org - where POV-Ray enthusiasts around the world can get
together to exchange ideas, information, and experiences with others
Date: 25 Jul 1999 13:28:16
Message: <379B48A0.5961D6C2@pacbell.net>
> Alan
I think I summed it up very well in the VFAQ. If you want to play games and
mpeg movies on your system then by all means buy a good harware accelerated
graphics card. If speed is a concern in raytracing then buy a fast processor,
with a mother board the has a fast buss, good amounts of level one and 2 cache
memory for swapping out instructions, and tons of fast system ram. Then sit
back and wait cause raytracing is a slow process no matter what kind of system
you can afford to buy :)
Ken Tyler
Date: 25 Jul 1999 13:30:05
Message: <379B5723.6CD9C078@pilot.msu.edu>
Yes networking is easy.  As long as it is with winsows.  I can't get
linux to see my NIC because it is a 9.99 special.  But dual processors
will not speed up POV if I'm correct.  Does POV use treads?  If it does
it would benefit from mulitple processors.
I heard someone is makeing an eight processor motherboard for the AMD
K7.
> > workstation.
> of HDs...
Date: 25 Jul 1999 14:31:05
Message: <379b57e9@news.povray.org>
In article <379B5723.6CD9C078@pilot.msu.edu> , Nick Portelli
You can start POV-Ray several times.
     Thorsten
e-mail: tho### [at] trfde
Date: 25 Jul 1999 15:42:31
Message: <379B68F4.6A0406EB@geocities.com>
>         Graham.
Well, if you go with Linux you might be able to skip all that. No mouse needed at
all. Keyboard and monitor need only be connect if you are doing a simple
installation (i.e. default off the RedHat CD).
At my prior company, we had a product that was a linux-based small office server.
To configure each box all we had to do was have it hooked to the network and a
serial port. I believe that we'd just connect to the serial port to enter a
machine name and IP address for our install script (running from a boot floppy),
then everything else was automatic. No need for monitor, keyboard or mouse. We
did have a video card, but I'm not sure if that was completely necessary, or just
default on the boxes we were buying.
BTW, I setup a system here at home quickly with a $15 cheapie network card from
Fry's. The main trick was just needing to figure out which driver to use (found
the chip listed then everything else went quickly). I didn't even configure the
graphical display on the system. When I needed to run a graphical configuration
tool, I just telneted in from my main machine, set the display environment
variable to name that main work machine, and then the X display from the new
computer was running on my main computer no problem. Don't even have a monitor
switch box here (but I did use a spare monitor for the initial setup). Gee,
Linux/Unix is quite handy.
"My new computer's got the clocks, it rocks
But it was obsolete before I opened the box" - W.A.Y.
Date: 26 Jul 1999 00:53:33
Message: <379be9cd@news.povray.org>
Nick Portelli wrote in message <379B5723.6CD9C078@pilot.msu.edu>...
>K7.
You could use PVMPov.  I think it can handle multiple processors on one
machine.
Mark
Date: 26 Jul 1999 00:56:24
Message: <379bea78@news.povray.org>
Ken wrote in message <379B48A0.5961D6C2@pacbell.net>...
processor,
cache
system
Actually, there is one system that can raytrace in real time, using
massively parallel processing -- the real world.  Anyone know where I can
buy one? :-)
Mark
Date: 26 Jul 1999 02:40:16
Message: <379c02d0@news.povray.org>
Steve <ste### [at] puzzlecraftcom> wrote:
: If you really want speed, Silicon Graphics has a motherboard that can support
: 256 alpha RISC CPU's
  Too bad the official povray can't be run in multiple processors...
Date: 26 Jul 1999 02:47:58
Message: <379c049e@news.povray.org>
As others have stated, povray will probably never benefit from this card.
  Moreover, the official povray will probably _never_ benefit from _any_
card (as long as compilers can't optimize code for them). Povray is intended
to be portable. This means that it has to be compilable in any standard
compiler.
  The only way povray could benefit from an acceleration card would be:
a) if the compiler can automatically create optimized code for that specific
card, or b) if you create your own custom compile with inline assembler
optimizations (which is not portable anymore).
  AFAIK, no such graphics cards exist nowadays. The 3D graphics cards used
nowadays are pretty useless to povray even if you wanted to optimize it for
them.
Date: 26 Jul 1999 05:15:44
Message: <379C26B1.24384A6A@pacbell.net>
> processor,
> cache
> system
> buy one? :-)
> Mark
The system or a "real" world ?
Ken Tyler
Date: 26 Jul 1999 13:05:24
Message: <379c5e9a.4608388@news.povray.org>
On Sun, 25 Jul 1999 06:24:25 -0500, Steve <ste### [at] puzzlecraftcom>
wrote:
[snip]
>workstation.
I know NT can split it's workload, to some degree, between CPU's - but
IIRC POV-Ray itself doesn't support multiple CPU's so is there an
appreciable benefit from a dual-processor PC? Or is there another OS
(Linux?) which can make better use of the 2nd CPU with it's flavour of
POV?
Cheers,
Cliff Bowman
Why not pay my 3D Dr Who site a visit at http://www.who3d.cwc.net/
PS change ".duffcom" to ".net" if replying via e-mail
Date: 26 Jul 1999 13:23:17
Message: <379C9991.B872F8B3@compuserve.com>
You can always run multiple copies of POV, and even with one copy, it
gets most of one processor with less system overhead. Maybe POV-Ray will
be threaded in POV 4.
Date: 26 Jul 1999 16:39:31
Message: <379B91F3.52C7AE1B@bahnhof.se>
PVMpov does work well in this sort of situations. Windows + networking.
Nothing I really enjoy, I greatly prefer doing that with linux. *humms*
too bad about the NIC though. tried the newer kernels?
//Spider
--Wail of Sumer.
Date: 26 Jul 1999 23:08:27
Message: <379D22EF.A3888EB6@geocities.com>
Have you checked what chips are needed and have you looked on
http://www.deja.com/ to scan newsgroups? I thought I was going to have problems
with my cheapie card, but then I recognized the chip and installed it. Zooom! I
was off and running.
Date: 27 Jul 1999 04:01:10
Message: <379D6702.CE545925@bof.infomaniak.ch>
Do you know if PVMpov exists now in version 3.1?
> //Spider
> --Wail of Sumer.
David Etter Perere
Pour me répondre, enlevez le "bof." svp
Please remove ".bof" to answer
Date: 27 Jul 1999 04:19:25
Message: <379D6AD0.3592E10@pacbell.net>
In v3.1e at:
http://www.luga.de/~flierl/pvmpov/
Ken Tyler
Date: 27 Jul 1999 04:33:35
Message: <379D6EAC.6EF6209C@bof.infomaniak.ch>
Thank's Ken.
I might (is my english coorect?) say you are answering very, but very
fast.
Ken a écrit:
> In v3.1e at:
> Ken Tyler
David Etter Perere
Date: 28 Jul 1999 03:06:33
Message: <379eabf9@news.povray.org>
Ken wrote in message <379C26B1.24384A6A@pacbell.net>...
and
accelerated
>> processor,
>> cache
sit
>> system
>> buy one? :-)
>> Mark
Yes.
Date: 28 Jul 1999 03:07:32
Message: <379eac34@news.povray.org>
Jim Kress wrote in message <379a00af@news.povray.org>...
We seem to get this rumor every few months.
Date: 28 Jul 1999 04:26:55
Message: <379fb8bf.439854808@news.povray.org>
On Tue, 27 Jul 1999 10:32:45 +0200, DEPerere <per### [at] bofinfomaniakch>
wrote:
>Thank's Ken.
>fast.
  Scary, isn't it? :)
Alan
Date: 29 Jul 1999 10:07:41
Message: <37A04310.1E2A2DF4@ndirect.co.uk>
Uncle Ken ain't a person he be a AI.
DEPerere wrote:
> Thank's Ken.
> fast.
> Ken a crit:
> > In v3.1e at:
> > Ken Tyler
> David Etter Perere
> Pour me rpondre, enlevez le "bof." svp
Steve
%HAV-A-NICEDAY Error reading file mailto:sjl### [at] ndirectcouk
Date: 29 Jul 1999 11:33:12
Message: <379F61B3.773D7A2D@bahnhof.se>
DEPerere wrote:
> Thank's Ken.
> fast.
He is well known for that.. look for replies that come up to an hour
before the questions... :)
//Spider
--Listening to the whispers of the dead.
Date: 29 Jul 1999 17:36:40
Message: <379f3d13.609325@news.povray.org>
On Wed, 28 Jul 1999 08:26:56 GMT, Alan Kong <ako### [at] pacbellNO-SPAMnet>
>wrote:
>>Thank's Ken.
>>fast.
>  Scary, isn't it? :)
I'm starting to think that the POv guys have been messing about with
some AI code...
Cheers,
Cliff Bowman
Date: 29 Jul 1999 17:43:59
Message: <37A0CB2E.5B5FBD9@compuserve.com>
Raytracing doesn't really take that long, that is a myth. POV-Ray uses
our processors(which are actually linked together, although you can't
usually tell) for processing portions of Ken's mind. The more we render,
the more processing power available for him.
Date: 29 Jul 1999 22:00:10
Message: <37A10685.CCA64F06@pacbell.net>
...more power Scotty ! She given ya all she got capt'n...
Ken Tyler
Date: 30 Jul 1999 14:03:25
Message: <37A1E961.3EFD82CC@ma.usb.ve>
humm..., that would mean that behind the pov-ray code there is a big
eastern egg.
Date: 31 Jul 1999 11:04:45
Message: <37a2ea85.81516693@news.povray.org>
On Thu, 29 Jul 1999 16:45:20 -0500, Chris Huff
That explains a LOT - including why of late his links page seems to be
so useful for stuff I'm looking for (e.g. OBJ2POV).
Now all I have to work out is whether what I'm doing while 4 PC's here
are rendering tilts what KenAI does, or whether KenAI also puts out
subliminal messages so that I just "happen" to want what he's already
found...
Cheers,
Cliff Bowman
Date: 31 Jul 1999 11:16:57
Message: <37A31286.C6829201@pacbell.net>
> found...
> Cheers,
> Cliff Bowman
One correction sir- where you state KenAI that should read KenI as there is
nothing artificial about my intelligence what there is of it.
Ken Tyler
Date: 3 Aug 1999 15:27:03
Message: <37a70b56.65269387@news.povray.org>
On Sat, 31 Jul 1999 08:13:10 -0700, Ken <tyl### [at] pacbellnet> wrote:
>Cliff Bowman wrote:
[snip]
>> found...
[snip]
I did consider that - but thought the danger of you being referred to
by the obvious deminutive ("Kenny") too high and insufficiently
respectful...
Cheers,
Cliff Bowman
