POV-Ray : Newsgroups : povray.general : 360 panorama Server Time
6 Nov 2026 23:14:18 EST (-0500)
  360 panorama (Message 1 to 10 of 10)
Subject: 360 panorama
Date: 28 Jun 1999 07:50:33
Message: <37776A95.59AD7829@no13.net>
Hi all.
Anyone has success with 360 degree panorama renders ? If so I'd be
interested in the results.
regards
Nathan O'Brien
no1### [at] no13net
http://www.no13.net
Subject: Re: 360 panorama
Date: 28 Jun 1999 08:01:13
Message: <37776406.AEF06C69@ica.uni-stuttgart.de>
Nathan O'Brien wrote:
> Hi all.
> regards
> Nathan O'Brien
> no1### [at] no13net
> http://www.no13.net
There had been a thread about it!
title: Check this out ...
date 21/10/98
started by the newsadmin that had been about panoramas. But I think it
used a browser plugin for IE.
Marc
Marc Schimmler
Date: 28 Jun 1999 09:02:17
Message: <37777259@news.povray.org>
>> Hi all.
>> regards
>> Nathan O'Brien
>> no1### [at] no13net
>> http://www.no13.net
>date 21/10/98
http://www2.fwi.com/~parkerr/pantest.html
is a panoramic scene without a plugin that works on both Netscape and IE,
and should work on any HTML-4.0 compliant browser.  I don't remember
specifically what camera I used, but it was probably a panoramic one.  I
also stretched the image quite a bit in the X direction.  Check out the
HTML source to see how easy it was to do.
Date: 28 Jun 1999 10:40:06
Message: <37778792.A40DAE4D@aol.com>
I've been trying to swing a patch for a spherical camera.  It isn't
quite as easy as I thought it would be, but hopefully I'll have
something together sometime this week.  I got all kinds of elliptical
cameras to work, so I think I'm on the right track. :)
-Mike
> Hi all.
> regards
> Nathan O'Brien
> no1### [at] no13net
> http://www.no13.net
Date: 28 Jun 1999 10:59:58
Message: <37778F41.FE83AD31@puzzlecraft.com>
A single-image panorama is called "periodic boundary" in mathemetics,
where the left edge meets the right edge, top meets bottom, etc. It's
essential feature is the fact that the image will tile a plane
seamlessly. There's a large body of research on this, usually cataloged
under geometry, tiling. Under this description, it's actually rather
trivial to render a panaroma.
steve
> Hi all.
> regards
> Nathan O'Brien
> no1### [at] no13net
> http://www.no13.net
Date: 28 Jun 1999 12:12:53
Message: <37779FA4.A7F13CF6@inapg.inra.fr>
There's a little utility called SpinPanorama that's bundled with MS
Frontpage 98. I was able to render 30 frames of a POV "landscape" (with
the camera rotating at 360 degrees) and the utility stitched them
automatically into a QTVR movie. It was OK, but I still have to design a
real scene for this.
Gilles
> Hi all.
> regards
> Nathan O'Brien
> no1### [at] no13net
> http://www.no13.net
Date: 28 Jun 1999 15:24:10
Message: <3777CBD3.DFEE9DC1@emc-inc.com>
See Paul Bourke's Cuberender paper:
http://www.mhri.edu.au/~pdb/rendering/cuberender/
Cuberender is a fast 360 degree 3D
model exploration technique using 6 precomputed views.
I have posted an example that I created in Moray in
povray.binaries.images entitled "VRMLizing your POV models (part 2 of
2)".  It doesn't create a single 360° panoramic image, but the results
are just as impressive as QTVR.  Maybe more impressive since the
Cuberender method allows for complete 360° exploration in every
direction.
You could also setup a camera in your POV scene that has a thin viewing
angle (i.e. 15°).  For each 15° segment, rotate the camera & render.
These segments could then be combined in Photoshop or Paintshop Pro.
Date: 29 Jun 1999 19:45:10
Message: <37795a86@news.povray.org>
Nathan O'Brien wrote in message <37776A95.59AD7829@no13.net>...
>Hi all.
Yep, unfortunately not online anywhere...
Using a cylindrical camera...(so only 360 around the y axis) the
standard mac download of POV-Ray 3.1 includes a VR panorama scene in the
scenes folder, I used its camera definition (but changed the aspect
ratio). Can't recall what the dimensions were, I just grabbed them from
some doco of a demo tool Apple included on a Develop CD some time ago...
[sorry I did this under v2(? maybe 3.0), it's been a while...] I used
the same tool to turn the single image into a pano.
Makes the scene I used much more 'obvious' than the still image (you can
actually tell which are real objects and which are reflections...)
HTH
Have Fun
Martin
<Spa### [at] tesseractcomau> is a valid address
If you prefer mnemonic addresses you can use:
<Martin 'at' tesseract.com.au> or <Martin.Crisp 'at' Tourism.tas.gov.au>
My opinions should not be taken as indicative of Tourism Tasmania's
opinions
Date: 1 Jul 1999 05:51:25
Message: <markp-0107991951250001@cbr-56k-138.tpgi.com.au>
In article <37776A95.59AD7829@no13.net>, Nathan O'Brien <no1### [at] no13net> wrote:
> Hi all.
I did a little dablling with QTVR panoramas awhile ago.  Nothing
spectacular or complicated but have a look at
<http://www1.tpgi.com.au/users/mpainf/Mars1/index.html> for the results.
Note that the URL for the apple site does not work anymore (bummer). It
should be <http://www.apple.com/quicktime/developers/tools.html> and it
only runs on a Mac.
Mark P.
Date: 1 Jul 1999 22:25:24
Message: <377c2314@news.povray.org>
Mark Paine wrote in message ...
wrote:
>> Hi all.
results.
>only runs on a Mac.
There's the public beta of VRToolBox's VR Worx...
And the downloadable demos of their existing products...
www.vrtoolbox.com
obviously it'll cost if you want to keep using this, but it's a good way
to get started FOC...
(no association other than I'm using the beta...)
Have Fun
Martin
opinions
