Hi ?
Does anyone have a stripped candy cane they could share with me. I
can model the thing all right but getting the stripe to wrap around the
bend properly is giving me epileptic fits. I prefer a non patch solution
for this if at all possible.
Thank you in advance for any help you may have to offer.
Ken Tyler
mailto://tylereng@pacbell.net
On Fri, 25 Jun 1999 12:56:53 -0700, Ken wrote:
>Hi ?
That sounds difficult. You might find it easier to write a script
to generate the stripe as a mesh that's just slightly larger than
a white candy-cane object. Or of course you can see if the Object
Bender does what you need.
> >Hi ?
Unfortunatly I am not too adept at writing triangle construction scripts
so that rules out that option. The object bender is still an option I
have not overlooked but would like to avoid this too as I plan to create
possibly hundreds of duplicates and the parse time MAY be unnaceptable.
I have no experience with that particular inc file but have heard that
it is prohibitavly slow if the radius of the bend is excessive. A candy
can has a bend that exceeds 180 degrees which borders on excessive.
Ken Tyler
Sounds like a job for some sort of twisting on a torus slice unioned with the usual
cylinder and candy cane stripe texture (duh). Haven't done it myself. There's
Spiralizer
here:
http://www.armanisoft.ch/webdesign/default.htm
Just not sure of it's use for this particular purpose (makes 3D models not textures).
I couldn't find one of the many twisting spiral includes among my several links here
but
maybe theres a way to apply such a thing if you can locate one or if someone knows of
the whereabouts and can lead you to something, plus it seems the more plausible
alternative too.
Actually best of all would simply be a 'image_map' with 'map_type 5' applied to the
torus slice (wide red and white diagonal lines). Leave it to me to think of the best
solution last.
mailto://inversez@aol.com?Subject=PoV-News
I have posted a candy cane model in the text scene files newsgroup.
Grr, I can't get it to post. I seem to be having a problem with long
messages. I will e-mail it to you.
Thank you very much !
Ken Tyler
I would, but I've already licked it...
Lance.
For the latest 3D Studio MAX plug-ins, images and much more, go to:
The Zone - http://come.to/the.zone
For a totally different experience, visit my Chroma Key Website:
Colorblind - http://listen.to/colorblind
Kinda on this same topic...
It sure would be nice if there were a spiral pattern that varied angle
only with y. That is to say, one like spiral1 but with a
cross-section that looks like radial. Am I alone in thinking this?
On Sun, 27 Jun 1999 00:56:46 +1000, "Lance Birch"
That's perfect. He wanted a stripped one anyway. Now if he wanted a
striped one, then you might have cause to be concerned.
I have wished this...
Ken Tyler
Yes, you are definately not alone in that.
> Ken Tyler
This one is easily faked with a) a pigment_map b) dejong box effect
but these solutions are slow. I have needed this, too, in fact my
twister.inc was born to suit my need for this pattern. If there was
such a pattern then I could render that H.E.Day toothpaste that people
dream about drinking after downloading it from this server (he he he™)
Peter Popov
ICQ: 15002700
> (he he he™)
HEY!!! ;-)
Lance.
On Sun, 27 Jun 1999 16:37:51 +1000, "Lance Birch"
>> (he he he™)
>HEY!!! ;-)
he he he™ is an (yet) unregistered non-trade mark of Lance Birch.
He even has it stamped on his forehead :)
Lance, if you dare deny I'll show you a pic (with two more rings :) )
Peter Popov
ICQ: 15002700
he he he™
Go ahead, I'd love to see where you'd put them :) Lucky you've only got my
head! LOL
(for anyone else read this, it may sound very confusing)
Lance.
Ken, I know this is a bit late but I have posted KandyCane.jpg in
povray.binaries.images and the source in povray.text.scene-files. It uses the
Striscia macros developed by Daniele Varrazzo. It's a bit different to Chris
Huff's solution. Hope you like it.
David
dav### [at] cwcom net
http://www.hamiltonite.mcmail.com
> David
Thank you David I will check it out.
Ken Tyler
Ken wrote:
> Hi ?
If you map the colors instead of letting them be the spectrum
colors something like this should work. See the COMMENT!!! in the
file.
The result is the first equation image on the page at the end.
// Persistence of Vision Ray Tracer Scene Description File
// File: ?.pov
// Vers: 3.1
// Desc: Basic Scene Example
// Date: mm/dd/yy
// Auth: ?[esp]
#version 3.1
global_settings
assumed_gamma 2.2
camera
location <0.0, 9, -9.0>*3
direction 1.5*z
right 4/3*x
look_at <0.0, 0.0, 0.0>
sky_sphere
pigment
gradient y
color_map { [0.0 color blue 0.6] [1.0 color rgb 1] }
light_source
0*x // light's position (translated below)
color red .50 green .50 blue 0.50 // light's color
translate <-30, 30, -30>
light_source
color red .50 green .50 blue .50 // light's color
translate <30, 30, -30>
//plane { y, -1 pigment {color rgb <0.7,0.5,0.3>}}
//sphere { 0.0, 1 texture {pigment {radial frequency 8}
finish{specular 1}} }
#declare tortor =union {
#local count1 = 0 ;
#local maximum =1500;
//#declare count = 1;
#while (count1 < maximum)
//box
torus
//superellipsoid {<0.8,0.2>
{ 0.8, 0.2
texture {pigment {radial frequency count1/100} /* COMMENT!!!
play with this line first */
finish{specular 1}
rotate y*count1*(360/maximum) }
//interior {ior 1.8}
rotate x*count1*360/maximum/5
translate <count1*360/maximum/25,0,0>
translate
<sin(2*pi*count1/maximum)/cos(2*pi*count1/maximum),0,0>
#declare count1 = count1 +.5;
}//end union
tortor
<blink>------------------------------------</blink>
http://www.giwersworld.org/artsii/
Finally up on 99/06/22
Download 'us-ascii' (1 KB)
Ken,
You might try using Twist and Bend includes, both of them are at Chris
Colefax's site.
steve
Ken wrote:
> Hi ?
> Ken Tyler
Sorry - just the Object Bender include from Chris Colefax will do the job
of both twisting and bending an object. Used with ClockMod you can even
animate the effect.
steve
Ken wrote:
> Hi ?
> Ken Tyler
