POV-Ray : Newsgroups : povray.general : Help Creating 3D logo Server Time
15 May 2026 00:38:02 EDT (-0400)
  Help Creating 3D logo (Message 1 to 6 of 6)
Subject: Help Creating 3D logo
Date: 24 Jun 1999 11:28:45
Message: <37724EAE.D29E73F7@nacstock.ac.uk>
Hi Folks
I'm trying to create a 3D logo from a flat black and white version. I've
tried doing using a height field. When I render an animated sequence the
logo looks like it's transparent at the sides. Does anyone know why?
Is there a better way of doing this? Here is the pov file and the
original logo. Also frame 10 of the animation.
Mike
mik### [at] nacstockacuk
#include "textures.inc"
global_settings
{assumed_gamma 1.0}
//camera{location  <0.0, 0.5, -4.0> direction 1.5*z right     4/3*x
look_at   <0.0, 0.0,  0.0>}
//camera{location  <4, 0.5, 0.0> direction 1.5*z right     4/3*x
camera{ location <3*sin(2*pi*clock),0,-3*cos(2*pi*clock)> look_at 0}
sky_sphere
  pigment
    gradient y
    color_map { [0.0 color blue 0.6] [1.0 color rgb 1] }
light_source
  0*x // light's position (translated below)
  color red 1.0  green 1.0  blue 1.0  // light's color
  translate <-30, 30, 30>
light_source
  translate <-30, 30, -30>
plane { y, -1 pigment {color rgb <0.7,0.5,0.3>}}
#declare logo=intersection{
height_field {
        tga "naclogoi.tga"
        smooth
        texture {Polished_Chrome}
        rotate <90,0,180>
box
  <-1, -1, -1>
  < 1,  1,  1>
  scale <0.5, 0.5 .5>
  translate < -0.5,0.5,1>
object {logo
        texture{Polished_Chrome}
        rotate <0, 180, 0>
        translate <-.5,-.5,0>
Download 'frame10.jpg' (17 KB) Download 'naclogo.jpg' (25 KB)
Preview of image 'frame10.jpg'
Preview of image 'naclogo.jpg'
Subject: Re: Help Creating 3D logo
Date: 24 Jun 1999 11:53:16
Message: <3772525C.7CC88CCE@pacbell.net>
Mike wrote:
> Hi Folks
> Cheers
> Mike
If you replace the chrome texture you have in two places with
  pigment { rgb 1 }
    finish { ambient .5 diffuse .5 }
and then render the scene you will find there is nothing wrong with
your logo object (I used the first camera to test this). You are the
victim of a highly reflective object and no more. If you are having
any real problems it is with the roughness you have on the objects
edges from a poor quality height field image. The lack of straight
edges in the image is giving you very rough edges in the HF object
and appears as if the edges have been chipped away.
  Please don't post binaries to this group in the future. Instead post
your question here and the source file in the povray.binaries.scene-files
group with a reference to it's location.
Ken Tyler
mailto://tylereng@pacbell.net
Date: 24 Jun 1999 12:23:16
Message: <37725960.F99FA322@pacbell.net>
P.S. You can avoid having to use an intersetion to create your
logo by simply using the HF ojbect as is and use the water_level
feature for HF's to rid yourself of the background.
Ken Tyler
Date: 25 Jun 1999 05:04:41
Message: <3773462C.EF3516A5@nacstock.ac.uk>
Opps, sorry about that! Thanks for the advice
Mike
> Ken Tyler
Date: 25 Jun 1999 05:06:58
Message: <377346B5.63384042@nacstock.ac.uk>
Ahhh! Right. I'll try that. I knew that there had to be a simpler
solution.
Mike
> Ken Tyler
Date: 25 Jun 1999 06:26:59
Message: <37735975.20E96B1A@nacstock.ac.uk>
I actually have the original image as a vector based CorelXara image which can
be converted to CorelDraw easily enough. Can I use this in a 3D modelling
program and 'extrude' it somehow? That way I can avoid using bitmaps and
height fields etc. When I use a very high quality bitmap the file takes ages
to parse. This is a pain for animation type stuff because it happens for every
frame.
Mike
Ken wrote:
> Mike wrote:
> > Hi Folks
> > Cheers
> > Mike
>   pigment { rgb 1 }
> Ken Tyler
