I need to compare render times across different processors.
Unfortunatily I do not have access to any Intel processors.
I would be grateful if anybody could find times to process
the following:
Site: ftp.icnet.uk
Login: ftp
password: email address
directory: /pub/bmm/tmp
files: test.ray and test.ray.par
(file size is 327k and the include file 51k)
command: povray +Itest.ray +W1200 +H1200
and let me know the render time (Parse + Trace + Total)
and system being used.
Thanks
p.s. Trace time on a Silicon Graphics MIPS R10000, 195MHz
was 22 seconds.
____________________________________________
Suhail A Islam
Biomolecular Modelling Laboratory
Imperial Cancer Research Fund, P.O. Box 123
44 Lincoln's Inn Fields, London WC2A 3PX
Tel: (0171) 269 3380
Fax: (0171) 269 3258
email: isl### [at] icrf icnet uk
http://www.icnet.uk/bmm/
> the following:
> Site: ftp.icnet.uk
> Login: ftp
> Thanks
> was 22 seconds.
> Suhail A Islam
Pentium 200 mmx win 98 Pov 3.1d
parse 3.0 sec.
trace 50.0 sec.
totatl 53.0 sec.
Memory consumed - 1,428,750
Ken Tyler
mailto://tylereng@pacbell.net
islam wrote:
> Site: ftp.icnet.uk
> Login: ftp
Smallest Alloc: 28 bytes Largest: 24044
Peak memory used: 1383164 bytes
Time For Parse: 0 hours 0 minutes 1.0 seconds (1 seconds)
Time For Trace: 0 hours 0 minutes 15.0 seconds (15 seconds)
Total Time: 0 hours 0 minutes 16.0 seconds (16 seconds)
Pentium II 350 MHz running under OS/2 Warp 4
Povray version 3.1a for OS/2 Warp
See ya
Udo
Email: sicota.country(at)bigfoot(point)com
WWW-Pages:
Programming pages:
http://www.bielefeld.netsurf.de:8080/~u_mueller/program.html
Travel pages:
http://www.crosswinds.net/bielefeld/~sicota/index.html
U. Mueller wrote:
> islam wrote:
> > Site: ftp.icnet.uk
> > Login: ftp
I have noticed that you should post some other parameters like
antialising(on/off), jitter(on/off),...as the results vary depending on
the settings.
Just to add another result:
Smallest Alloc: 12 bytes Largest: 24028
Peak memory used: 1107472 bytes
Time For Trace: 0 hours 0 minutes 13.0 seconds (13 seconds)
Total Time: 0 hours 0 minutes 14.0 seconds (14 seconds)
Pentium II 350 MHz running under Suse Linux 6.1 (Kernel 2.2.5)
Povray version 3.1
See ya
Udo
WWW-Pages:
Programming pages:
Travel pages:
test.ray 1200X1200, no AA:
parse: 0 sec
trace: 20 sec
total: 20 sec
peak memory used: 1429140 bytes
POVWin 3.1d on Win98 (highest render priority)
Pentium II Celeron 416MHz (FSB 83MHz * 5)
Margus
islam wrote in message <372### [at] icrf icnet uk>...
>the following:
> Site: ftp.icnet.uk
> Login: ftp
>Thanks
>was 22 seconds.
>Suhail A Islam
>Povray version 3.1
Are you sure you used the right settings (1200X1200)? I don't think Linux is
THAT fast...
Margus
Just some data from a
UltraSPARC-II, 296 MHz, 640MB RAM
Peak memory used: 1218068 bytes
Time For Trace: 0 hours 1 minutes 3.0 seconds (63 seconds)
Total Time: 0 hours 1 minutes 4.0 seconds (64 seconds)
Of course I don't know why povray doesn't that beast working. Even on a 2
processor machine a idle of 80% is too much.
(Should I try the huge one? :-)
I will...
Axel
> >Povray version 3.1
> THAT fast...
Yep...it is...although if I set antialising and jitter to on...it takes
about 30 seconds...but he hasn't stated how to set them and these
settings are not needed here...
See ya
Udo
WWW-Pages:
Programming pages:
Travel pages:
On a Pentium II 300MHz running POV 3.1e under Windows 98 with render
priority set to Highest:
Peak memory used: 1429163 bytes
Time For Parse: 0 hours 0 minutes 3.0 seconds (3 seconds)
Time For Trace: 0 hours 0 minutes 32.0 seconds (32 seconds)
Total Time: 0 hours 0 minutes 35.0 seconds (35 seconds)
rygad
islam <isl### [at] icrf icnet uk> wrote in message
news:372### [at] icrf icnet uk...
> the following:
> Site: ftp.icnet.uk
> Login: ftp
> Thanks
> was 22 seconds.
> Suhail A Islam
Using Normal priority and render window off:
Peak memory used: 1429078 bytes
Time For Trace: 0 hours 0 minutes 19.0 seconds (19 seconds)
Total Time: 0 hours 0 minutes 20.0 seconds (20 seconds)
Windows NT 4.0, PII 333mhz, VC++ compile of POV-Ray 3.1e
-Mike
