POV-Ray : Newsgroups : povray.general : Mushroom cloud using DF3 Server Time
28 Oct 2026 00:08:48 EDT (-0400)
  Mushroom cloud using DF3 (Message 1 to 22 of 22)
Subject: Mushroom cloud using DF3
Date: 16 Apr 1999 00:10:27
Message: <3716A9E1.256DBFA5@fatnet.net>
I need help in creating DF3 files to make a Mushroom Cloud caused by an
Nuclear Explosion i've tried to experiment with the DF3's but no success
on creating any thing close to what i wanted or expected. If anyone
knows "ANYTHING" about the elusive DF3's please tell me.  I'm still
quite new to pov ( maybe one year under my belt ) so, please try to
explain it to me as if i were a 2 year old.
Thank you for your time reading this,
Nathan Zwalsh
nrz### [at] fatnetnet
Subject: Re: Mushroom cloud using DF3
Date: 16 Apr 1999 02:13:49
Message: <3716C6F6.28EE2771@virginia.edu>
I am leaving town for a few days, but I would be happy to give you what
help I can when I return.  In actuality, I think Jim Kress probably has
more experience with DF3's than I do.  I just dissected them.
Steve
Send me an email and I'll see what I can do when I return
> Nathan Zwalsh
Date: 16 Apr 1999 08:58:33
Message: <371725E0.408AABA4@netvision.net.il>
What is DF3?
> Nathan Zwalsh
Date: 16 Apr 1999 10:18:43
Message: <3717375B.3E5780B0@pacbell.net>
Lewis wrote:
> What is DF3?
Roughly interperated I believe it means 3D density file. There is an
option in pov that will allow you to use a .df3 file as a way to control
the density function inside a media. It has other uses as well but this
was it's primary intended purpose. There is a utility that will allow
you to take one or several .tga image(s) and create a binary .df3 file.
The black art involved with knowing what to feed the conversion utility
is what this thread hopefully will answer for us all. I am skeptical that
anyone really knows to be perfectly honest with you and I sit patiently
on the side waiting for this revelation to unfold.
Ken Tyler
mailto://tylereng@pacbell.net
Date: 16 Apr 1999 10:27:17
Message: <37173AAF.A7450DC8@netvision.net.il>
Uncle Ken has spoken.
(this should be your signature)
Date: 16 Apr 1999 13:03:01
Message: <37175dca.8994218@news.povray.org>
On Fri, 16 Apr 1999 06:12:59 -0700, Ken <tyl### [at] pacbellnet> wrote:
>Lewis wrote:
>> What is DF3?
Attached is a five I've successfully used to generate several .df3s
out of csg-able objects - a keyboard, the word POV, a julia fractal, a
torus (with some turbulence makes a really good pipe smoke ring). Just
declare the object you need converted and render an animation. The
object bust fit into the unit box and must be csg-able. Frames must be
of square shape. It takes a lot of tweaking to get a complex object to
fit into the unit cube, but if you have the superpatch, a simple macro
using min_extent and max_extent could do the trick. For now, I hopw
this is useful as is.
Peter Popov
ICQ: 15002700
Download 'df3make.pov.txt' (1 KB)
Date: 16 Apr 1999 15:22:37
Message: <37177F93.6FFBC888@aol.com>
I couldn't help but notice the "CSG-able" word said. I wanted a DF3 of a
complex model once and came up with mixed results. Basically it didn't
work in other words (although it almost did it seemed), and I repeatedly
got a "patch object not allowed" during parse as I tried in vain to get
the model sliced up right.
So I guess this is impossible? No work-arounds? Well, I'm not giving up.
Date: 16 Apr 1999 15:27:41
Message: <3717811d.0@news.povray.org>
It depends on how you want to create the df3 file.  there have been several
posts in the povray newsgroups about utilities that create a df3 file from
various types of images.
I've written some code to take a 3D array of x,y,z data and from that
directly create a df3 file.  If anyone is interested, I can clean it up and
post a copy in the binaries.utilities group.
Jim
Check out my web site http://www.kressworks.com/
It'll blow your mind (politically), stimulate your senses (artistically)
and provide scientific insights beyond compare!
Be sure to read the Warp maintained POV VFAQ:
http://iki.fi/warp/povVFAQ.html
Stephen Lavedas wrote in message <3716C6F6.28EE2771@virginia.edu>...
>Steve
>> Nathan Zwalsh
Date: 16 Apr 1999 15:50:40
Message: <37178680.0@news.povray.org>
If you have the Superpatch you could use trace() to do what you're wanting
to do.  In fact, you could write a macro that takes an object, a filename,
and the desired resolution and automatically creates the df3 file for you.
It wouldn't be the fastest thing on Earth, but it wouldn't be too terrible.
Date: 16 Apr 1999 15:58:05
Message: <3717880A.990B92D5@aol.com>
Oh wow, hey, that might work huh? Thanks for the new incentive, and the
S.P.
Gee, is nothing impossible...? If you see a DF3-made image at
binaries.images later on you will know I succeeded.
Date: 16 Apr 1999 16:02:43
Message: <371787FD.BA31EF45@pacbell.net>
> Jim
  That would of course be appreciated but I think that the one thing
on many peoples minds at this point is what exactly should a .df3 file
contain ? What does it do and how can a person control it to make the
media conform to a shape at will ?
  If you can offer even a simple overview of what can be gained and where
to start you would be doing a lot of people here a big favour. My self
included. I have some vague notions and have explored the field a bit but
my own results to date have not yet been satisfactory and I owe that mostly
to lack of sufficient input from a knowledgeable source. I found the docs
sorely lacking on this subject for some reason.
Ken Tyler
Date: 16 Apr 1999 16:30:35
Message: <37178fdb.0@news.povray.org>
Have you ever found yourself wishing you could create a 3D bitmap?
Perhaps something simple, like alternating octahedra and tetrahedra
in a nice lattice.  Or something complex, perhaps a swirly pattern
that can't be modeled with POV's built-in procedural textures. Say
you have a nice algorithm to generate it but the only language you
know is Visual Basic, so patching POV is out of the question.
Well, a .df3 file is just that: a 3D bitmap.  When you use one, it's
just like an imagemap (well... more like Nathan's image_pattern patch,
in that it works with color_map) except that it varies in all three
dimensions instead of just two.
You're the artist here; you tell me how useful such a thing is. :)
Date: 16 Apr 1999 16:41:00
Message: <371790F6.5E2AF293@pacbell.net>
  I have as yet insuffecient data to perform a meaningful task.
  I am not arguing it's potential for the artist I am crying for more
imput on how to use it. I even to some degree understand the 3d image
file concept but don't know where to start in it's implementation.
For example the program tga2df3. If I wanted to create a simple shape
let's pick something simple like a narrow cylinder with a sphere on top.
Your basic tootsi pop shaped object. What kind of tga images would I
feed tga2df3 to realize this shape when applied in a density statement ?
  Give me fundamentals I will worry about concepts later. I need buttons
to push not fancy words to ponder. Give me a damn monkey wrench so I
can start to work with it.
Buzz ! Click !
Ken Tyler
Date: 16 Apr 1999 17:08:34
Message: <37179898.45C9F80A@aol.com>
You kind of answered your own question, the object you exampled with is
what you would model and slice into thin planar sections (along the z
axis most likely, using a box for CSGing let's say) as frame output.
Then use those in tga2df3.
I'm not one to explain them myself so I'll stop right there. Gee, I
thought you were able to do this kind of thing already though, you are
quite a capable person.
> Buzz ! Click !
> Ken Tyler
Date: 16 Apr 1999 17:14:26
Message: <37179a22.0@news.povray.org>
You feed it cross-sections, I assume (not having used the program.)
For the Tootsie pop, you'd feed it a bunch of identical images with
small circles (for the stick) and then a series of circles getting
larger and larger, then reducing again to nothing (for the candy).
Picture what one of those egg-slicer gadgets you can get at the local
kitchen store would do to your lollipop, and you'll have a pretty good
idea what you need.  Or, if you wanted to make a file for a human, try
this URL for a (somewhat graphic) depiction of cross-sections:
http://www.npac.syr.edu/projects/vishuman/VisibleHuman.html
Date: 16 Apr 1999 17:34:51
Message: <37179E9A.9EEFB4DF@fatnet.net>
Yes i would like to create a DF3 using XYZ data rather than Bit maps!.
I've experimented with TGA2DF3 using an
animation of a sphere with a CSG Moving down the sphere to create a
sliced effect but still getting odd results.
If i could model the density it would make life much less frustrating.
Thank you Everyone who "tried" to answer such a difficult question,
Nathan Zwalsh
Date: 18 Apr 1999 04:39:44
Message: <37198508.174861@news.povray.org>
As I understand it your complex model was made up of patches, most
probably using moray or spatch. You are using windoze 95 (at least for
newsreading) so here's a windoze-only workaround: from spatch, export
your model to some polygon format (ex. vrml). Then, convert that to a
pov mesh. Then use uvpov to slice up the mesh since it treats meshes
as csg-able.
There is another problem with this method and I have not yet found an
universal solution. Since the plane (or box or whatever) used for
chopping gives the resulting surface its own texture, the result is
either a monochrome .df3 or a black .df3 :) (if no texture is given to
the plane). Suppose you've modelled a nice blob with separate element
textures, and you want to see the inside of it. No way, Jose. Sorry.
That's the reason I went a little off topic and gave up trying to
model a mushroom cloud density with blobs (the original poster's
question). Modelling is easy, but making the .df3 out of it is a pain.
There's a method that works for csg unions, though. Instead of slicing
the union with the plane, slice each part of it separately and texture
it afterwards. This may be quite a tedious work, but a macro might
help, like:
// suppose your cutting plane is caused sliceObj
#macro Object ( myObj )
  intersection
    SliceObj
    myObj
Invoke it like this:
Object ( niceCSGableObj ) texture { coolObjectGuts } }
This will save... um, some time ... at least.
Man, this *is* an ugly macro, I know, but it should work.
Now, I summon all gurus: gather around and try to make up a way to
show the cross-section of a blob keeping its internal textures intact.
Here are some suggestions to try out:
Use a bounding (not clipping!) object that incorrectly bounds the
blob.
Use a weird orthographic camera setting (some combination of location,
look_at and direction which is beyond my skills) so that the screen
plane is *inside* the object. Will this work?
// object fits the unit sphere
camera
  location -4*z
  look_at 0
  direction 4*z
  orhographic
One last question: how about slicing objects with media and getting
correct results?
I've asked these questions before, but now 1) I am narrowing them down
2) there are more povers around and 3) pov skills increase with time
I can't test the stuff right now as there's already a line waiting at
the computer (I hope dad doesn't notice the slowdown... I put POV in
the  system tray and then intentionally hung explorer, so the tray now
only holds a clock and a volume control :) ).
Peter Popov
ICQ: 15002700
Date: 18 Apr 1999 04:39:46
Message: <371a8b31.1751385@news.povray.org>
On 16 Apr 1999 14:50:40 -0500, par### [at] my-dejanewscom (Ron Parker)
With all due respect to you, sir,  and your SuperPatch, I think this
macro will be only suitable for a minimal share of all .df3
applications. If I have gotten your idea correctly, it will not be
able to either reproduce the internal structure of the desired object
nor the texture / interior. See my reply to Bob Hughes for more
details.
Peter Popov
ICQ: 15002700
Date: 18 Apr 1999 05:24:20
Message: <37199680.F9CB3F96@aol.com>
See inserted replies, please:
> as csg-able.
Yep, there is one little sPatch piece in it, used 6 times. Thanks for
the work-around idea however it already is a bicubic_patch anyway, not
the same thing? (I know very little of these things). Though it was
messing up before getting to any of them. It looked like I had a decent
slice going at first with a plane, I think it was, then maybe messed up
at the bicubics. Keeping textures and all from what I could tell. I was
doing quick tests at low resolution. Then upon some changes, using a box
instead, I failed to get anywhere near the same result.
Yeah, I know what you mean, but I know I had colors of the original
model showing properly at first, as I said :)
> help, like:
>   intersection
>     SliceObj
>     myObj
> blob.
I did try clipping with a box inversed. And was using orthographic
camera. I don't quite follow your "inside" idea, however 'direction no
longer applies (nor 'angle') with this camera type, only 'up' and
'right' do.
> camera
>   location -4*z
>   look_at 0
>   direction 4*z
>   orhographic
> correct results?
I do hope you mean slicing an object that has media, instead of use a
object with media to slice up another object.
Bad boy!
> Peter Popov
> ICQ: 15002700
Well, trial and error always prevails. It's that error part that bugs me
most.
Date: 18 Apr 1999 05:32:50
Message: <37199756.56808417@pacbell.net>
> Nathan Zwalsh
  I am not altogether certain that a .df3 density file is the ultimate
solution to making a mushroom cloud. I am about to post a quick preview
of my own efforts towards rendering a reasonable facsimile of a mushroom
cloud. The image will be in the binaries.images group along with the source.
  I have no more time to work on it but it might point you or someone else
in the right direction of research. Personaly I think I have made good
headway in the 1 hours time I had available to work on the problem.
Cheers,
Ken Tyler
Date: 18 Apr 1999 18:56:24
Message: <371a52f7.138844609@news.povray.org>
On Sun, 18 Apr 1999 07:39:36 GMT, pet### [at] usanet (Peter Popov)
Depending on the interior structure you have in mind, it certainly
could.  Say you have a hollow sphere, made of two concentric rings of
bicubic patches.  If the macro were coded correctly, it would in fact
trace a ray to the first intersection, then start another ray just
past that intersection tracing in the same direction, etc.  In fact,
I never seriously considered any other way of doing it.
If you're talking about an object that is not closed and otherwise
well-behaved (i.e. no patches with 'bare' edges) then no, it won't
work, but then neither will any other method.
This is true as well.  One could, of course, create a .df3 of a block
of any given pigment, then write a quickie program to perform a
logical 'and' between corresponding elements of the two resulting
files.
Besides, everything being discussed in this thread is only useful for
a very small fraction of .df3 applications.  I haven't yet seen anyone
even scratch the surface of what these things are good for.  What I
want to see is a big pile of utilities, like the pbm utils, but
operating on .df3 files - smooth, sharpen, general convolutions... the
sky's the limit.
Date: 18 Apr 1999 19:02:25
Message: <371A56EF.6E810A7@netvision.net.il>
Are wee seeing here a new aging system? POV-years? I'll be about 3 years
old, then, but experience is earned by rough hours not years
