POV-Ray : Newsgroups : povray.general : Height fields Server Time
7 Nov 2026 00:08:19 EST (-0500)
  Height fields (Message 1 to 18 of 18)
Subject: Height fields
Date: 4 Apr 1999 05:29:10
Message: <370722D3.E4869EEC@tsn.cc>
Does anyone know how to make an overhang on a height field?
Subject: Re: Height fields
Date: 4 Apr 1999 10:05:09
Message: <37076385.0@news.povray.org>
Well, it can't be done... not with normal height fields anyway... (because
remember, it just gets height from the image...)
There are several ways aroung it though...
Lance.
For the latest 3D Studio MAX plug-ins, images and much more, go to:
The Zone - http://come.to/the.zone
Date: 4 Apr 1999 15:42:48
Message: <3707B18D.1DB900C@bahnhof.se>
it isn't possible.
you'd have to use a mesh for that.
//Spider
                "Marian"
        By: "Sisters Of Mercy"
Date: 4 Apr 1999 16:47:57
Message: <3707c1ed.0@news.povray.org>
Lance Birch wrote in message <37076385.0@news.povray.org>...
Well, you're a lot of help :)
What several ways do you have in mind?
Margus
Date: 4 Apr 1999 16:54:42
Message: <3707C269.CE418AC@bahnhof.se>
import in Breeze and convert to a mesh... :-)
or use a tool for it. (sorry, I don't have the time to write one)
> Margus
//Spider
                "Marian"
Date: 4 Apr 1999 17:13:44
Message: <3707C779.397E@teleport.com>
<<it isn't possible.
you'd have to use a mesh for that.>>
Wrong.  You could make an INVERTED (<1,-1,1>) height field...  I've got
an example, in the form of a upcoming irtc entry... You'll have ta wait
11 days...
H. E. Day
Date: 4 Apr 1999 17:37:52
Message: <3707CC82.197F634E@bahnhof.se>
Hmm, Not really, I've been working on them asw well, but never quite got that
cave-like overhang look. perhaps it's my HF ...
> 11 days...
> H. E. Day
//Spider
                "Marian"
Date: 4 Apr 1999 17:45:19
Message: <3707DD4E.60A0C45@jk.uni-linz.ac.at>
Would say the same. I am thinking of a normal highfield with a negative
highfield on top. The only problem I see is to get the change of the
slope correctly.
Alex
> 11 days...
> H. E. Day
Date: 4 Apr 1999 17:51:47
Message: <3707DED2.E08356F5@jk.uni-linz.ac.at>
I have just go another idea. To make a volcano is rather easy, but if it
is rotated (<-90,0,0>) it should give a nice cave. Of course it can't go
down again, but works if this feature isn't needed.
Alex
Date: 4 Apr 1999 21:03:01
Message: <3707FD99.C5D236EF@aol.com>
'matrix' used to shear it might do if you can get the right matrix maybe
(I have no skill in them myself whatsoever). Or possibly (and better
yet) multiple instances of the same HF scaled/translated/rotated by some
amount to offset from a "base" HF. Something like:
union {
 object {Your_Base_HF} // same as the one below, only no 'water_level'
(could have tho)
 #declare C=1
 #while (C<10)
  object {
   Your_Added_HFs //with a large enough 'water_level' to remove the
base.
         scale C/5 //goes to 2 times larger than original
        rotate C*3*y //rotates to 30 degrees on y axis
       translate <C/10,C/10,0> //move a total of 1 unit along x & y axes
 #declare C=C+1 //ten HFs
 } //union
This is just my quick answer typed out here so you'll need to write your
own.
Date: 4 Apr 1999 22:44:47
Message: <3708158f.0@news.povray.org>
Well, I was leaving it open for other people more experienced (and as you
can see they've all jumped in like I expected them to).
But:  Meshes, Bicubic Patches, Some use of Isosurface (would require the
patch though), Shearing and warping of a normal height field with a matrix
(although I don't know enough about them any more), convert a height field
to a mesh and edit it externally, combine height fields in such a way that
you could have an inverse height field on top to make the overhangs...
OK, that's all I can think of right now.
Lance.
Date: 5 Apr 1999 11:45:58
Message: <3708CB7B.12EA61E6@pacbell.net>
> Lance.
  An idea for a new utility. A height field generator that uses bicubic
patches. After the initial shape is established you can take the patch
object into a program like spatch and make final adjustments to your
surface topography such as flattening areas for road beds, pulling out
cliffs, etc.
No I am not volunteering to write such a montser either. It was a fleeting
thought that got the better of me.
Ken Tyler
mailto://tylereng@pacbell.net
Date: 7 Apr 1999 00:47:22
Message: <370AD559.856AE320@virginia.edu>
I've already written a converted...but it isn't perfect.  I'd have to
figure out the sPatch format however.  Also due to the limitations of
BPatches (ie 4x4) you lose some data in the conversion unless you want
massive numbers of patches.
Steve
> > Lance.
> cliffs, etc.
> Ken Tyler
Date: 7 Apr 1999 01:06:19
Message: <370AD88B.D494ABE4@pacbell.net>
> Steve
It does sound interesting none the less. I take it from the tone of your
message that it currently is not for the inexperienced Pov user, is best
used by the programs developer and the more adventurous, seasoned, Povray
veterans.
Ken Tyler
Date: 7 Apr 1999 14:13:49
Message: <370B9263.C22217D8@virginia.edu>
In reality I'm pretty sure it is best used by me...it is just some C++
code that CAN under a few tweaks do what you ask.  I would be willing to
work on it, but I'm going to need to bite the bullet and actually start
reading TGA files.  I realize it isn't actually too difficult, I just
have to do it...Converting to OCT and then running the program isn't
really a valid option.  (If you'll recall my cylidrical and spherical
height field mapping util converted them to bpatches first.  BTW, there
is an example of a flat height field out of patches on my Web site at
http://www.people.Virginia.EDU/~swl7m/Images/BPatchfield.jpg
The patches aren't joined correctly (so as to reduce the lines you can
see) but it is a proof of concept.  Let me write a new util and see how
it turns out.  In all probability it will be a DOS command line utility.
Steve
(It will be in C++ so it should be REASONABLY portable...I may even make
a linux compile)
> > Steve
> veterans.
> Ken Tyler
Date: 7 Apr 1999 15:52:19
Message: <370B9666.798517B1@bahnhof.se>
Or by the maniacs who just want to try and see what the results will be :-)
(yes, pick it apart.....)
> > Steve
> veterans.
> Ken Tyler
//Spider
                "Marian"
Date: 8 Apr 1999 01:11:42
Message: <370C2C9D.E771297B@virginia.edu>
Oh GOD no...no one who can actually READ my code will ever see it...it
is UUUUUUUUUUGGGGLLLY!
Steve
> > > Steve
> > veterans.
> > Ken Tyler
> //Spider
>         [ spi### [at] bahnhofse ]-[ http://www.bahnhof.se/~spider/ ]
> What I can do and what I could do, I just don't know anymore
>                 "Marian"
Date: 8 Apr 1999 03:23:21
Message: <370C4A09.99F316A8@bahnhof.se>
Hehehe, I can guess, I'm a coder :-))
Actually, take a peek at :
--> The Archive
--> --> Snow
This is an example of code differences..
compare the originnal to the one I rewrote :-)
(Hmm, the original might be  called obfuscated KenCode or somethings)
> Steve
> > > > Steve
> > > veterans.
> > > Ken Tyler
> > //Spider
> >                 "Marian"
//Spider
                "Marian"
