POV-Ray : Newsgroups : povray.general : Lens Flare Server Time
28 Oct 2026 02:20:08 EDT (-0400)
  Lens Flare (Message 1 to 2 of 2)
Subject: Lens Flare
Date: 27 Mar 1999 12:22:35
Message: <36fd13db.0@news.povray.org>
i'm using moray for win, and I'm having trouble using the lens falre plugin.
Does anyone know how to use this properly??
Thanks in advance
David
Dav### [at] sprosonfreeservecouk
www.sproson.freeserve.co.uk
Subject: Re: Lens Flare
Date: 27 Mar 1999 17:40:45
Message: <36fd5e6d.0@news.povray.org>
David Sproson wrote in message <36fd13db.0@news.povray.org>...
plugin.
>Thanks in advance
This might be better suited for moray.win :)
Still, try this.
Create a normal point light, and position it where you want the lens flare
to be.  If you don't want this light to actually give off "real" light, then
set its colour to black.  Now, create a lens flare object by simply pressing
the [create-->plugin objects-->]LensFlare  button.  Now, press the little
button next to the Camera option at the bottom of the modify windows.
You'll probably only have one camera listed in the selection box that pops
up - so select it and press OK.  Now, click the little button next to the
Lightsource option.  Select the name of the point light you just created.
There you go :)  Your lens flare will appear where your point light is.
The rest (such as changing flare type etc.) should be fairly obvious.
Hope that helps,
Matt
