POV-Ray : Newsgroups : povray.general : Batch files Server Time
28 Oct 2026 02:19:46 EDT (-0400)
  Batch files (Message 1 to 8 of 8)
Subject: Batch files
Date: 21 Mar 1999 16:03:30
Message: <36f55ea2.0@news.povray.org>
How can I run a batch file that will automatically render POVray scene
files?
Is there a way to do it something like this?
for(i=0; i<256; i++) {
    render_file( "scene" + i + ".pov" );
Thanks in advance !!
Ron
Subject: Re: Batch files
Date: 22 Mar 1999 12:42:18
Message: <36f680fa.0@news.povray.org>
You should at least tell us which operating system you plan to be doing this
on...
Johannes.
Ron H. wrote in message <36f55ea2.0@news.povray.org>...
>files?
>Ron
Date: 22 Mar 1999 22:55:49
Message: <36f710c5.0@news.povray.org>
I'm sorry, I forgot to do that.
I'm using WinNT4.0, and I'd like to  perform this repetitive batch loop
either in a java program or perhaps even in POVray's own language using
POVray itself.
Is this possible?
Ron
Johannes Hubert wrote in message <36f680fa.0@news.povray.org>...
this
>on...
>Johannes.
>>files?
>>Ron
Date: 23 Mar 1999 02:51:24
Message: <36f747fc.0@news.povray.org>
In Java it should be easy. Something like this:
public static void main(String[] args)
    int firstFrame = ???;            // set first
    int lastFrame = ???;             // and last frame here
    String pathToYourPOV = ???;      // set your path here
    String yourPOVArguments = ???;   // set your render-args here
    String yourPOVFile = ???;        // set the name of the scenefile here,
    for (int i = firstFrame; i <= lastFrame; i++) {
        String povArgString = pathToYourPOV +
                              "pvengine.exe +I" +
                              yourPOVFile + i + ".pov" +
                              yourPOVArguments;
        Process pov = Runtime.getRuntime().exec(povArgString);
        try {
            pov.waitFor();
        catch (Exception) {
            System.out.println("Something went wrong!");
            break;
The scenefile name should be the name without the frame-number and the
".pov" extension, of course.
You should also choose render arguments that make POV-Ray close itself after
rendering, otherwise you will have to close it manually or "waitFor()" will
wait forever ;-)
Greetings,
Johannes.
Ron H. wrote in message <36f710c5.0@news.povray.org>...
>POVray itself.
>Is this possible?
>Ron
Date: 23 Mar 1999 04:18:32
Message: <m3u2vcftsn.fsf@clodomir.rezel.enst.fr>
"Ron H." <aya### [at] homecom> writes:
> ... even in POVray's own language using POVray itself.
> Is this possible?
  Sure.  There was a thread here some time ago about image-mapping a
different image file at each frame of an animation.  You can reuse
this to include a different *.pov file at each frame.
Roland.
Roland Mas
Food, shelter, source code.
  -- Cyclic Software
Date: 23 Mar 1999 05:40:38
Message: <36F76EB5.8D9A004F@pacbell.net>
> > Is this possible?
> Roland.
> Roland Mas
>   -- Cyclic Software
  If you want a working example let me know as I was the one
that needed help in that thread and got it to work in an easy
and straight forward manner.
Ken Tyler
mailto://tylereng@pacbell.net
Date: 23 Mar 1999 12:01:15
Message: <36F7C8E5.736E@merlin.net.au>
> POVray itself.
> Is this possible?
> Ron
Here it is again
#declare BaseName = "foo"
#declare Extension = ".pov"
#declare NameDigits = 8-strlen(BaseName); // or just put a number in
here for how many digits after the name
#declare LastFrame = 20;
#declare FirstFrame = 1;
#declare Frame = clock * (LastFrame-FirstFrame) + FirstFrame;
#declare FileName = concat( BaseName, str(Frame,-NameDigits,0),
Extension )
FileName will have values such as foo00001.pov, foo00002.pov etc.
Cheers, PoD
Date: 23 Mar 1999 12:52:39
Message: <36F7D4C6.5D69A049@virginia.edu>
It should be possible to do it in NT Batch language too.  Just a
thought.
Steve
> POVray itself.
> Is this possible?
> Ron
> this
> >on...
> >Johannes.
> >>files?
> >>Ron
