I hope someone can help get me started with my latest experiment.
I want to try out arrays. My plan is to create a cube made up of, say, 20x20x20 tiny
spheres. If I pick one of these spheres and designate it to be the centre of the
effect
I'm trying to create, and scale it by a factor of 2, how do I make the surrounding
spheres
get gradually smaller until 5 spheres away they are back to scale 1? I plan to animate
the
effect so that the centre of the effect moves around inside the array of spheres.
I have heard the term 'fields' used. Is this the method I should use, and if so, could
anyone suggest either how it is done, or else point me in the direction of where I can
find more out about it.
I am not a mathematician or a programmer, but I hand-code only so I should be able to
make
use of any suggestions, as long as you assume large levels of ignorance on my part.
Many thanks in anticipation.
Andy
On Fri, 12 Mar 1999 20:32:52 -0000, "Andrew Cocker"
effect
spheres
animate the
Give this little macro the array coordinates of the sphere you are
defining and of the sphere at the center of the effect. At the proper
point in the sphere definition say:
scale Size(Mysphrx, Mysphry, Mysphrz, Mycentx, Mycenty, Mycentz)
#macro Size(_Xloc, _Yloc, _Zloc, _Cxloc, _Cyloc, _Czloc)
#local _Dist = min(min(abs(_Xloc - _Cxloc), abs(_Yloc -_Cyloc)),
abs(_Zloc - _Czloc));
#local _Scl = (5 - max(_Dist, 5)) / 5;
<_Scl, _Scl, _Scl>
The macro will, of course, work with actual position coordinates as
well and for noninteger positions (with a Manhattan metric). To do
this for another range, replace every occurrence of 5 with a variable
and add that variable to the parameter list. This reduces the size
linearly. If you want to do inverse square or somesuch, or change the
metric, it is pretty simple. You can also easily modify it to wrap
around.
Jerry Anning
clem "at" dhol "dot" com
Thanks for that Jerry, although at this stage, it seems incomprehensible. You'll
perhaps
understand why when I tell you that, as yet, I have never even created an array, let
alone
manipulated one. I'll start from scratch, and ask more questions later when ( not *if*
) I
get really stuck.
If you have any further suggestions that might help me make progress, they'd be most
welcome.
Thanks again
Andy
Jerry Anning wrote in message <36e98aea.22674829@news.povray.org>...
effect
spheres
animate
the
> <_Scl, _Scl, _Scl>
>#end
>around.
>Jerry Anning
effect
spheres
animate the
could
can
to make
> Andy
I started a test file to look at this as follows:
#declare MyGrid = array[10][10]
// initalize the array
#macro InitGrid ()
#declare i = 0;
#declare j = 0;
#while ( i < 10 )
#while ( j < 10 )
#declare MyGrid[i][j] = 1;
#declare j = j + 1;
#declare i = i + 1;
#macro DrawGrid ()
#declare i = 0;
#declare j = 0;
#while (i < 10 )
#while ( j < 10 )
sphere { <i*2,2,j*2> MyGrid[i][j]
pigment { red 1 }
finish { phong 1 } }
#declare j = j + 1;
#declare i = i + 1;
InitGrid()
DrawGrid()
And in theory this is place to start, but when I render this code I get 10 spheres
instead of
100. It would appear that POV Ray does not like nested loops but there is nothing I
can find
to support this theory... has anyone else run into this or am I missing somthing very
obvious
in my code?
Josh English
eng### [at] spiritone com
www.spiritone.com/~english
On Mon, 15 Mar 1999 12:09:06 -0800, Josh English
tiny
effect
spheres
animate the
could
can
to make
>> Andy
>#macro InitGrid ()
> #declare i = 0;
> #declare j = 0;
> #while ( i < 10 )
******Insert #declare j=0; here! *********
> #while ( j < 10 )
> #declare j = j + 1;
> #end
> #declare i = i + 1;
> #end
>#end
>#macro DrawGrid ()
> #declare i = 0;
> #declare j = 0;
> #while (i < 10 )
> #while ( j < 10 )
> pigment { red 1 }
> #declare j = j + 1;
> #end
> #declare i = i + 1;
> #end
>#end
>InitGrid()
>DrawGrid()
instead of
can find
obvious
>in my code?
>Josh English
Jerry Anning
#macro InitGrid ()
#local i = 0;
#while ( i < 10 )
#local j = 0;
//RESET J HERE !!!
#while ( j < 10 )
#local j = j + 1;
#local i = i + 1;
#macro DrawGrid ()
#local i = 0;
#while (i < 10 )
//RESET J HERE !!!
#local j = 0;
#while ( j < 10 )
pigment { red 1 }
#local j = j + 1;
#local i = i + 1;
I set the comments. Sorry for screaming :-)
you only have to reinit J to 0 every outer loop, or it will only happen ince.
And, use #local inside a macro.
//Spider
( spi### [at] bahnhof se ) [ http://www.bahnhof.se/~spider/ ]
#declare life = rand(seed(42))*sqrt(-1);
On Mon, 15 Mar 1999 20:15:38 GMT, nos### [at] despam com (Jerry Anning)
tiny
effect
spheres
animate the
could
can
to make
part.
>>> Andy
>>#macro InitGrid ()
>> #declare i = 0;
>> #declare j = 0;
>> #while ( i < 10 )
>> #while ( j < 10 )
>> #declare j = j + 1;
>> #end
>> #declare i = i + 1;
>> #end
>>#end
>>#macro DrawGrid ()
>> #declare i = 0;
>> #declare j = 0;
>> #while (i < 10 )
******** And here! ***********
>> #while ( j < 10 )
>> pigment { red 1 }
>> #declare j = j + 1;
>> #end
>> #declare i = i + 1;
>> #end
>>#end
>>InitGrid()
>>DrawGrid()
instead of
can find
very obvious
>>in my code?
>>Josh English
>Jerry Anning
Jerry Anning
Is it just me or did you not actually write anything in those two previous
posts? ;-)
Lance.
For the latest 3D Studio MAX plug-ins, images and much more, go to:
The Zone - http://come.to/the.zone
he added the same comment that I did.
//Spider
[ spi### [at] bahnhof se ]-[ http://www.bahnhof.se/~spider/ ]
"Marian"
By: "Sisters Of Mercy"
Thank you. I figured it had to something obvious like that, I only couldn't admit
to it yesterday. Thank you.
I DID take programming courses at one point, granted it was a Modula-2 class, but
it was programming... that's what you forget over the years.
> #macro InitGrid ()
> #local i = 0;
> #while ( i < 10 )
> #local j = 0;
> //RESET J HERE !!!
> #while ( j < 10 )
> #local j = j + 1;
> #end
> #local i = i + 1;
> #end
> #end
> #macro DrawGrid ()
> #local i = 0;
> #while (i < 10 )
> //RESET J HERE !!!
> #local j = 0;
> #while ( j < 10 )
> pigment { red 1 }
> #local j = j + 1;
> #end
> #local i = i + 1;
> #end
> #end
> //Spider
Josh English
I've been coding for years, and I still do that mistake sometimes...
//Spider
"Marian"
Okay, barring any stupid coding problems, here we go with an example. It will only to
two
dimentions right now and it not even complete there, but it provides a starting point:
#declare Max_X = 10; // number of spheres along X Axis
#declare Max_Z = 10; // number of spheres along Y Axis
#declare Base_Radius = 1; // radius of a sphere that is not under the influence
#declare Max_Radius = 2; // radius of the sphere that is under the influence
#declare Steps = 5; // the fifth sphere from the center of the effect will be at Base
Radius
#declare Each_Step = (Max_Radius - Base_Radius)/Steps; // Quick formula to determine
// how different adjacent spheres will be
#declare separation = 4; // the distance between sphere centers
#declare MyGrid = array[Max_X][Max_Z]
// initalize the array, giving everything a value of Base Radius
#macro InitGrid ()
#declare i = 0;
#while ( i < Max_X )
#declare j = 0;
#while ( j < Max_Z )
#declare MyGrid[i][j] = Base_Radius;
#declare j = j + 1;
#declare i = i + 1;
#macro DrawGrid ()
#declare i = 0;
#while (i < Max_X )
#declare j = 0;
sphere { <i*separation,2,j*separation> MyGrid[i][j] // Y value is merely
temporary
pigment { red 1 }
#declare j = j + 1;
#declare i = i + 1;
#macro CheckCord(a,b) // we will use this one extensively
( (a < Max_X) & (a >= 0) & (b < Max_Z ) & ( b >= 0 ) )
#macro AlterGrid (m,n) // this macro changes the spheres in the gird
#declare MyGrid[m][n] = Max_Radius;
#declare cvar = 1;
#while (cvar < Steps )
#declare Temp_Radius = Max_Radius- (cvar * Each_Step );
#if (CheckCord(m + cvar, n) ) // spheres in the +X direction
#declare MyGrid[m+cvar][n] = Temp_Radius;
#if (CheckCord(m-cvar, n) ) // spheres in the -X direction
#declare MyGrid[m-cvar][n] = Temp_Radius;
#if (CheckCord(m, n+cvar) ) // spheres in the +Z direction
#declare MyGrid[m][n+cvar] = Temp_Radius;
#if (CheckCord(m, n-cvar) ) // spheres in the -Z direction
#declare MyGrid[m][n-cvar] = Temp_Radius;
#if ( CheckCord (m+cvar,n+cvar) ) // spheres in +X,+Z diagonal
#declare MyGrid[m+cvar][n+cvar] = Temp_Radius;
#if ( CheckCord (m+cvar,n-cvar) ) // spheres in the +X,-Z direction
#declare MyGrid[m+cvar][n-cvar] = Temp_Radius;
#if ( CheckCord (m-cvar,n+cvar) ) // spheres in -X,+Z direction
#declare MyGrid[m-cvar][n+cvar] = Temp_Radius;
#if ( CheckCord (m-cvar,n-cvar) ) // spheres in the -X,-Z direction.
#declare MyGrid[m-cvar][n-cvar] = Temp_Radius;
#declare cvar = cvar + 1;
#end // AlterGrid
InitGrid()
AlterGrid (4,5)
DrawGrid()
Sadly, this still misses 24 cubes in the grid. I'm sure there's an easier way to do
it, and
this is mostly brute force, but it works.
effect
spheres
animate the
could
can
to make
> Andy
Thankyou all.
Andy
Josh English wrote in message <36E### [at] spiritone com>...
two
point:
Radius
>#macro InitGrid ()
> #declare i = 0;
> #declare j = 0;
> #declare j = j + 1;
> #end
> #declare i = i + 1;
> #end
>#end
>#macro DrawGrid ()
> #declare i = 0;
> #while (i < Max_X )
> #declare j = 0;
temporary
> pigment { red 1 }
> #declare j = j + 1;
> #end
> #declare i = i + 1;
> #end
>#end
>#end
> #declare cvar = 1;
> #end
> #end
> #end
> #end
> #end
> #end
> #end
> #end
> #end
>#end // AlterGrid
>InitGrid()
>AlterGrid (4,5)
>DrawGrid()
it,
and
tiny
effect
spheres
animate
the
could
can
to
make
>> Andy
To reduce memory of the scene, declare a pigment for the spheres, and then call
that. This will reduce it grately if you have more advanced scenes.
Here's a test.
#declare N = 100000;
#while(N>0)
#declare N = N-1;
sphere {
<0,0,N>,.25
hexagon
Red
Blue
Green
finish { ambient 1 }
compared to
#declare T =
hexagon
Red
Blue
Green
#while(N>0)
#declare N = N-1;
sphere { <0,0,N>,.25 texture { T } }
(sorry about the tabs)
//Spider
"Marian"
>Here's a test.
That's only true for meshes. Each sphere still has a copy of the
entire texture.
Oh? Hmm, ok.
> >Here's a test.
> entire texture.
//Spider
"Marian"
