POV-Ray : Newsgroups : povray.general : The misunderstandings page Server Time
28 Oct 2026 03:10:49 EDT (-0400)
  The misunderstandings page (Message 1 to 26 of 26)
Subject: The misunderstandings page
Date: 11 Mar 1999 13:01:17
Message: <36e804ed.0@news.povray.org>
I started another page with the same idea of the VFAQ page: The
common misunderstandings page. The intention of the page is to clear up
some common misunderstanings people have about computer related things
(mainly about topics related with povray, graphics, etc). The page has
only one entry right now, which is a very good example of what I mean.
  Wrong allegations and correct information about them is very welcome.
  I'll add a link to the page from the VFAQ page if/when I get some more
entries.
  The page can be found at:
http://iki.fi/warp/misunderstandings/
main(i,_){for(_?main(i+1,"FhhQHFIJD|FQTITFN]zRFHhhTBFHhhTBFysdB"[--i]
Subject: Re: The misunderstandings page
Date: 11 Mar 1999 14:28:45
Message: <36E81981.3F0875A6@virginia.edu>
My personal biggest pet peeve, which isn't about POVRay or Graphics is
when people ask..."Are you on the Internet"  and they mean World Wide
Web.  The Internet is so much bigger than just the Web that I want to
smack them one and point out what else is out there.
Steve
> entries.
Date: 11 Mar 1999 14:32:52
Message: <36E81BB3.1250B1D2@tiac.net>
<HTML>
So which formats are better than the other?
<BR>If you had to use a scale of 1 - 10 ...is png better than jpeg, gif
etc.
<BR>I assume the bitmap is the best, or maybe not...you tell me.
<P>--
<BR>...coffee?...yes please! extra sugar,extra cream...Thank you.
<BR> </HTML>
Date: 11 Mar 1999 15:51:44
Message: <36E82D62.24517E5A@panama.phoenix.net>
> etc.
There is no perfect format, although I find the 'best' format for me is
PNG.
Allow me to ellaborate a bit on graphics files. There are 5 main
compression tecniques used in graphics files:
Run Length Encoding (RLE): lossless. Supported by Photoshop and TIFF
file formats and some common Windows file formats.
Lemple-Zif-Welch (LZW): lossless. Supported by TIFF, PDF, GIF, and
PostScript language file formats. It's good for compressing images that
contain large areas of a single color, like screenshots or simple paint
images.
Joint Photographic Experts Group (JPEG): lossy. Supported by JPEG, PDF,
and PostScript language file formats. JPEG compression provides the best
results with continuous-tone images, such as photographs.
CCITT: lossless. It is mainly for black-and-white images. Supported by
the PDF and PostScript language file formats.
ZIP: lossless compression technique supported by the PDF file format.
Like LZW, ZIP compression is best for images that contain large areas of
single color.
These are the main formats used in graphics (at least in the POV world).
BMP: the standard Windows image format on DOS and Windows-compatible
computers. The BMP format supports RGB, indexed-color, grayscale, and
Bitmap color modes, and does not support alpha channels. You can specify
either Microsoft® Windows or OS/2® format and a bit depth for the image.
For 4-bit and 8-bit images using Windows format, you can also specify
RLE compression.
GIF: or Graphics Interchange Format, is the file format commonly used to
display indexed-color graphics and images in hypertext markup language
(HTML) documents over the World Wide Web and other online services. GIF
is a LZW-compressed format designed to minimize file size and electronic
transfer time. The GIF format does not support alpha channels.
IFF: or Amiga™ Interchange File Format is used for working with Video
Toaster and transferring files to and from the Commodore Amiga system.
In addition, this format is supported by a number of paint programs on
IBM®-compatible computers. IFF is the best export format to use with
DeluxePaint from Electronic Arts. The IFF format supports RGB,
indexed-color, grayscale, and Bitmap color modes, and does not support
alpha channels.
JPEG: or Joint Photographic Experts Group format is commonly used to
display photographs and other continuous-tone images in hypertext markup
language (HTML) documents over the World Wide Web and other online
services. The JPEG format supports CMYK, RGB, and grayscale color modes,
and does not support alpha channels. Unlike the GIF format, JPEG retains
all color information in an RGB image but compresses file size by
selectively discarding data.  A higher level of compression results in
lower image quality, and a lower level of compression results in better
image quality. In most cases, maximum quality produces a result
indistinguishable from the original.
PCX: commonly used by IBM PC-compatible computers. Most PC software
supports version 5 of the PCX format. A standard VGA color palette is
used with version 3 files, which do not support custom color palettes.
The PCX format supports RGB, indexed-color, grayscale, and Bitmap color
modes, and does not support alpha channels. PCX supports the RLE
compression method. Images can have a bit depth of 1, 4, 8, or 24.
PNG: developed as a patent-free alternative to GIF, the Portable Network
Graphics (PNG) format is used for losslessly compressing and displaying
images on the World Wide Web. Unlike GIF, PNG supports 24-bit images and
produces background transparency without jagged edges; however, some
older versions of Web browsers may not support PNG images. The PNG
format supports grayscale and RGB color modes with a single alpha
channel, and Bitmap and indexed-color modes without alpha channels. PNG
uses the saved alpha channel to define transparency in the file.
TGA: Targa® format is designed for systems using the Truevision video
board and is commonly supported by MS-DOS color applications. The Targa
format supports 32-bit RGB files with a single alpha channel, and
indexed-color, grayscale, and 16-bit and 24-bit RGB files without alpha
channels.
Date: 11 Mar 1999 19:21:08
Message: <36e85df4.0@news.povray.org>
I would call this one of the BIG misconceptions, that there is a "best"
format (or a "best" graphics programs, or, "best" computer, or,.....). Like
most things in life there is no best way. There is only a most appropriate
trade off depending on circumstances. In other words, it depends on what you
want to use the file for. Try to learn what the properties
(colour depth, compression, compatibility,...) of the different file types
are and then make a decision in each case as to what suits best.
Sorry if that sounds like a rant, but this is something I battle every day
working an a Help Desk.
Regards
Gordon
    Phil Clute wrote in message <36E81BB3.1250B1D2@tiac.net>...
    If you had to use a scale of 1 - 10 ...is png better than jpeg, gif etc.
Date: 12 Mar 1999 02:05:36
Message: <36E8BDDD.578E328@tiac.net>
<HTML>
Thanks Anthony, that was educational.
<P>--
<BR> </HTML>
Date: 12 Mar 1999 03:47:49
Message: <36E8D4B5.CBC4D287@ida.liu.se>
Just a small error correction. PNG does support alpha channels
in index-color mode. The alpha values can be stored in the
palette. (Read it yesterday in a libpng example file)
/ Mathias
Date: 12 Mar 1999 07:53:37
Message: <36e90e51.0@news.povray.org>
Anthony Bennett <ben### [at] panamaphoenixnet> wrote:
: TGA: Targa® format is designed for systems using the Truevision video
: board and is commonly supported by MS-DOS color applications. The Targa
: format supports 32-bit RGB files with a single alpha channel, and
: indexed-color, grayscale, and 16-bit and 24-bit RGB files without alpha
: channels.
  Targa supports also compression. Can you specify which kind of compression?
Subject: Suggestions
Date: 12 Mar 1999 08:46:39
Message: <36E91A12.D29E1341@aol.com>
Suggestions for additional topics include:
1. Why raytracers cannot do caustics :
I spent probably 10 hours experimenting with Corel Dream3D trying to get
caustics in an underwater scene by placing refractive, bumpy glass things in
front of my light source.  I was cursing the shareholders of Corel Corp when
I just didn't understand raytracing.
2. Why raytracers cannot make a "homemade" spotlight:
When I first got POV, I probably spent about 10 hours trying to make my own
spotlight with a reflective surface on a parabolic shape and a point light
source in it.  Again, I didn't understand how raytracers worked...
3. Explain compression in the MPEG format by giving exhaustive examples.
This is probably a bit more work, but is still a slight source of confusion.
> entries.
Subject: Re: Suggestions
Date: 12 Mar 1999 09:23:06
Message: <36e9234a.0@news.povray.org>
These are, of course, both the same topic.  Clearly one would need
to start with a definition of caustics.
Date: 12 Mar 1999 11:11:34
Message: <m3emmu1ydl.fsf@clodomir.rezel.enst.fr>
Nieminen Mika <war### [at] cctutfi> writes:
>   compression?
Run length encoding (RLE).  One group of consecutive pixels of the
exact same colour is coded on two (resp. three or four) bytes as a
whole instead of one (resp. two or three) byte for each pixel.  This
allows to use only two bytes to code one hundred pixels if they have
the exact same colour (assuming we are in an eight bits per pixel
image).  Of course, if you have horizontal gradients, this increases
the size of the file instead of diminishing it, but it generally
behaves The Right Way.
Roland.
Roland Mas
- Ogenki desuka, yau de poêle ?
- Genki desu, ture en zinc.
Date: 12 Mar 1999 11:42:34
Message: <36e943fa.0@news.povray.org>
Ron Parker wrote in message <36e9234a.0@news.povray.org>...
Which is covered in the VFAQ I would guess, and:
Not entirely true anyway, as Nathan is showing us with his new patched
version of POV-Ray.
The statement "cannot do caustics" should be "usually, and with the current
technique - if they are not enhanced with photon-maps or something similar -
cannot do caustics" ;-)
Johannes.
Date: 12 Mar 1999 11:45:51
Message: <36E943FE.487554C8@pacbell.net>
> entries.
Mis-whatevers:
Q.) Why don't they implement a modeling interface into Pov-Ray
A.) Pov-Ray is a rendering engine. This means it is designed to read a
    text based scene discription language and output an image for it.
    The programming work to keep this working bug free and adding
    features at regular intervals takes a lot time and energy by the all
    volunteer programming team. Adding a modeling interface would add to
    their aleady heavy workload and the progam was never written to be a
    modeling program anyway. There are numerous modeling programs already
    available that are designed with the sole purpose of providing a
    graphical modeling interface to Pov so it really isn't neccessary for
    the programming team to think about adding one.
    And...  or...
Q.) Why can't I use 3ds, dxf, vrml, or whatever models directly without
    having to convert them to triangles first ?
A.) ?
For Ron Parker:
Q.) If I just add the inverse keyword to my triangle meshes shouldn't they
    work in csg operations ?
A.) ?
Ken Tyler
mailto://tylereng@pacbell.net
Date: 12 Mar 1999 12:06:24
Message: <36e94990.0@news.povray.org>
On Fri, 12 Mar 1999 08:42:38 -0800, Ken <tyl### [at] pacbellnet> wrote:
>For Ron Parker:
>A.) ?
Wow.  Drifting across newsgroup boundaries now.  I'm impressed.
A.) No.  There is no way to find the "inside" of an arbitrary triangle
mesh, so the current implementation just assumes that nothing is inside of
a mesh object.  Adding the inverse keyword would just change it to say
that everything is inside of a mesh object.  The result would be that
intersecting an inverted mesh with a sphere would leave the entire sphere,
plus whatever part of the mesh is inside the sphere.  The correct result,
of course, would be to leave only the parts of the sphere that are "outside
the mesh," and only the parts of the mesh that are inside the sphere.  The
problem comes in when POV tries to define "outside the mesh."
The real common misunderstanding here, and one I've been guilty of, is
"If I want to make an object work in CSG, all I have to do is add an
insideness test, right?"  The answer is no: you also have to ensure that
the all_intersections routine for your object really does return all of
the intersections for any given ray.  The other common misconception is
that an insideness test for meshes is as simple as counting intersections.
See the recent and ongoing discussion in povray.programming for more than
you ever wanted to know about these topics.
Date: 12 Mar 1999 12:13:29
Message: <36E94B99.9DCD17E9@spiritone.com>
> Steve
As immortalized by Bob Dole (American presidential candidate from a few years
ago, failed, for you who are lucky enough not to live with American politics) :
"The Internet is the fastest way to get on the Web."
Josh English
eng### [at] spiritonecom
www.spiritone.com/~english
Date: 12 Mar 1999 16:26:52
Message: <36E98764.B7D6F502@ica.uni-stuttgart.de>
> entries.
I remember one in c.g.r.r. about the stacks in POVray and the
misunderstanding that they can be increased in autoexec.bat (or
config.sys ?). Somebody wiser than me should give the answer. If I
remember right it's not in the VFAQ.
Marc
Marc Schimmler
Date: 12 Mar 1999 18:26:50
Message: <36E907F3.56A69E5A@bahnhof.se>
> > etc.
Hmm, a question here, the Huffman compression technique that is used in many of
the newer compression algorithms(RAR, ARJ and so on) is used in the zip format
as well, If I'm not misunderstanding what I read. But, as far as I know, the PNG
uses a dynamic compression table, in difference to the standard zip algorithm
that uses a static table. am I correct or totally lost in my compression?
Another file format I'd like some tips on is the FIF(Fractal Image Format)
I had a compressor/viewer for this once, but lost it as so many otehr progs.
Anyone has anything on where I can find a program that can store to this? It was
very good at shrinking files, admittedly with loss, but the technique used made
it possible to zoom into the image in a totally different way than any
rasterized(bitmapped) format allows.
//Spider
( spi### [at] bahnhofse ) [ http://www.bahnhof.se/~spider/ ]
#declare life = rand(seed(42))*sqrt(-1);
Date: 12 Mar 1999 19:05:34
Message: <36E9AB0B.A5FCC81D@pacbell.net>
> //Spider
 Take a look in announce.frequently-asked-questions for a list of
links that will take you to faq's on image file format formats and
related image resources on the net. It's the best starting place I
know to send you for the info you seek.
Ken Tyler
Date: 12 Mar 1999 19:18:43
Message: <36e9aee3.0@news.povray.org>
I've been looking into this issue this week.
PNG and JPG are complementary, not competitors.
Use PNG for lossless work-in-progress and still get some compression.
Use JPEG for final pieces.
etc.
Download 'iso-8859-1' (2 KB)
Date: 12 Mar 1999 19:32:57
Message: <36E9B0AC.98E3A08@bahnhof.se>
Thanx. I'll do that sometime when I feel bored :-) This prog. isn't really on
top of my list of TOGET things
//Spider
Date: 12 Mar 1999 20:46:53
Message: <36e9c38d.0@news.povray.org>
Yes, it just depends on the raytracer doesn't it?  :)
MIRO is pretty good though.
Lance.
For the latest 3D Studio MAX plug-ins, images and much more, go to:
The Zone - http://come.to/the.zone
Subject: Re: FIF compressor and decompressor
Date: 12 Mar 1999 21:09:47
Message: <36e9c8eb.0@news.povray.org>
There was a great one on Iterated System's website (www.iterated.com), but I
can't seem to find it (the site's so damn big!!!).  It was very fast and
efficient... shame I can't find the installation file any more... :)
Lance.
Date: 13 Mar 1999 20:46:42
Message: <36eb1502.0@news.povray.org>
: Q.) Why don't they implement a modeling interface into Pov-Ray
  This is a FAQ, not a misunderstanding. I can add it to the VFAQ page
if you want.
Date: 14 Mar 1999 02:08:38
Message: <36eb6076.0@news.povray.org>
Who thinks that JPEG works by reducing colors?  I've never come accross that
legend.  People either know the difference between JPEG and GIF, or they
have no clue how they work at all, in my experience.
Nieminen Mika wrote in message <36e804ed.0@news.povray.org>...
>entries.
Date: 14 Mar 1999 11:36:30
Message: <wbu2vot4dt.fsf@tycho.oslo.infostream.no>
["John M. Dlugosz" <joh### [at] dlugoszcom>]
There are quite a few people out there who think that JPEG-files will
always be smaller than GIF files. I think the faq should mention that.
A penny for your thoughts.
Mine are more expensive.
Date: 14 Mar 1999 11:48:42
Message: <36ebe86a.0@news.povray.org>
Bjørn Vaggen Konestabo <bjo### [at] intervettno> wrote:
: There are quite a few people out there who think that JPEG-files will
: always be smaller than GIF files. I think the faq should mention that.
  I added a note about this.
