I just had an idea. See what you think. There has been much discussion in this group
regarding media and it's shortcomings, particularly with regard to creating a dusty /
smoky atmosphere. This is what I use it for mainly, but usually give up because a) it
takes so long to render, and b) because it often / usually looks too grainy.
My idea is this. Would it not be effective to use similar code to the way that
constant
fog works ( which seems to just change each pixel by a certain amount towards the
chosen
fog colour ), but *only for those pixels that are in line of sight of a light source*.
So
any obstructions would effectively seem to be casting a shadow *onto* the fog. It
seems to
me that this is how a dusty atmosphere looks when light shines in through a window
etc. Of
course the huge benefit of this approach would be a minimal increase in rendering
time.
You could have a parameter for controlling the intensity of the effect ie how near to
white each pixel becomes, a parameter to control how the effect fades as it moves
further
from the light source. I'm not sure how additional lights would affect things..they
could
each add to the intensity where spotlights cross one another, or they could all be
automatically adjusted so an overall effect is maintained, regardless of the number of
lights used.
Finally, the fog could be affected by, for example, a pigment map in a similar way to
a
density map, so that wherever rgbf 1 occured, the fog was clear. This could then be
animated in the usual way to create many atmospheric conditions. Sort of a simpler
Density.
Have I overlooked something here? My idea seems so simple, but sometimes the simple
ideas
work best. I'm not suggesting getting rid of media, as it excels at fires, clouds etc,
but
in my opinion it's overkill in some instances.
Maybe for the next version?
Andy
.....*AND* using a small value for the fade, and a high effect intensity...you have
visible light sources glowing beautifully
Andy
it
constant
chosen
source*. So
seems to
etc. Of
time.
to
further
could
of
> lights used.
to a
> Density.
ideas
etc, but
> Andy
This topic and the solutions you have suggested were discussed in
some detail back in January. I believe the thrust of the discussion
centered aorund the use of monte carlo sampling and it's limitions.
I tmight have been Nathan Kopp who mentioned tht he has been trying
different sampling methods to be used with the media feature and has
passed on the concerns of people about the process to Chris Young
the pov team coordinator. I guess you could say there is work in
progress to add more functinality to the media process but I have
no confirming data to support this. I do agree that there are some
sampling methods like that used in the previous atmosphere feature that
could add greater funtionality to the current system and it would be
nice to see some improvements in that area.
Ken Tyler
mailto://tylereng@pacbell.net
HI Ken,
That was quick! Do you have a permanent internet connection, or free local calls? If
so,
I'm envious- my phone bill's due tomorrow and I expect it to top £200. EEK
Have you had any luck with your consequtive images/
Andy
Ken wrote in message <36E31469.905C54F4@pacbell.net>...
>Ken Tyler
> HI Ken,
so,
> Andy
I get about 140 hrs. per month fixed rate internet access through my
phone company and a fixed monthly rate for all phone calls to the
dialup connection in my calling area. My phone bill with internet
access and normal phone usage, i.e. no long distance calls, runs less
than $40 a month US. That's less than most US families pay with no
internet connection but have two teenagers in their house.
As far as the other project I have had no success making it work. Either
I am too dense or there is something wrong with the exapmles given me so
far. I can get the include file method to work but can't seem to figure
out how to use successive images to create height fields as I am tring
to do.
The HF statement want's a syntax of:
height_field {"tga "xxx.tga" stuff }
I can't figure out how to use the code provided to satisfy it's need
for the - tga "xxx.tga" - part of the syntax. If you have any suggestions
I am willing to listen to your advice.
Ken Tyler
Ken wrote in message <36E### [at] pacbell net>...
Damn..why don't we get that over here? I have a free internet connection, but British
Telecom charge lots and lots
>to do.
Presumably you'll have tried
height_field { tga INCF stuff }
from my solution. I'll have a go myself and get back to you shortly if I come up with
a
solution.
The same guy who came up with the photon mapping idea wrote a paper
decribing how to extend it to work with participating media too. I
don't know if Nathan has this paper, but it would be neat if it could be
worked into POV sometime down the road.
It can handle caustics in media and even diffuse <-> volume light
transfer! :)
-Mike
> Ken Tyler
I read the paper (very nice images in it). But you'll notice that, unlike
the original work that Jensen did on photon maps (which ran on a low-end
linux box), the atmospheric stuff was rendered on an 8 (or was it 16?)
processor graphics workstation with many, many megabytes of memory.
I do plan to implement it, but it's not top priority right now. First,
I want to work on finishing photon mapping for caustics, then make it
work with radiosity. Also, I want to have a closer look at media to
try to get back the adaptive sampling method before introducing volume
photons.
-Nathan
> transfer! :)
PoDs Saturday reply to that Consecutive frames thread is all you really
need to make that work. Just put FileName in place of the "*.tga". Don't
use quotes.
> to do.
> Ken Tyler
mailto:inv### [at] aol com?PoV
> use quotes.
It was the quotes that was hanging me up. Got it going a while ago with
Andrews help.
Ken Tyler
Your luck might change soon. I live in Ireland, and at the moment, one of
our telecommunications companies is trying to get a bill passed by the
minister for telecommunications that will give Telecom Internet users a
IR£30 flat charge per two months for internet connections, no matter how
long you stay online. If the bill is passed, then this trend could spread to
the rest of the EU. Wouldn't that be cool?
Equiprawn
British
It is your digital phone lines. We with our old outmoded analog lines
enjoy a few benefits. That and it seems many things are cheaper in the
US. (Kinda surprised me)
Steve
On Mon, 8 Mar 1999 00:36:05 -0000, "Andrew Cocker"
Indeed they do - and so do the competition. However - one of the other
"free" ISP's in the UK has an interesting (perhaps) deal going during
weekends this month. friday midnight to Sunday midnight you can use an
0800 number (i.e. FREE) to connect. the downside (as I understand it -
not tried them yet) is that you must use their software, which
downloads and displays adverts to you. However - if the ISP is free
and the telephone cost is free - will the adverts be that much of a
problem?
the ISP in question is x-stream - I'd guess you can find them at
http://x-stream.com (maybe you'll need a www. stuck in there too if
that doesn't work).
Hope this is of use...
Cheers,
Cliff Bowman
Why not pay my 3D Dr Who site a visit at
http://www.geocities.com/Area51/Dimension/7855/
PS change ".duffnet" to ".net" if replying via e-mail
