POV-Ray : Newsgroups : povray.general : Making faster #switch statements Server Time
7 Nov 2026 00:34:26 EST (-0500)
  Making faster #switch statements (Message 1 to 15 of 15)
Subject: Making faster #switch statements
Date: 4 Mar 1999 18:53:22
Message: <36df1cf2.0@news.povray.org>
I'm working on a method of making cloth, and I posted a version of it in
.binaries.animations, but now I'm trying to make it faster. I used to have
this statement
#declare Unstretched = sqrt(pow(k*Normal_Length,2) +
pow(l*Normal_Length,2));
which is evaluated 24*16*16*4 times for each frame. Since Unstretched really
can have only five values, I thought I should precompute them and use a
#switch statement to choose, so I changed that line for the following:
#switch (abs(k) + abs(l))
  #case (1)  #declare Unstretched = Unstretched1;  #break
  #case (2)
    #if ((k=0) | (l=0))
      #declare Unstretched = Unstretched3;
    #else
      #declare Unstretched = Unstretched2;
  #break
  #case (3)  #declare Unstretched = Unstretched5;  #break
  #case (4)  #declare Unstretched = Unstretched4;  #break
but it seems like that *increased* the parse time by about 50%. I thought
that just picking a precomputed value would be faster than calculating
Pythagoras' theorem. Did I do something wrong, or is #switch really that
slow?
Martin Magnusson
e-mail: Mar### [at] studentuuse
www-site: http://www.geocities.com/SoHo/9946/
Subject: Re: Making faster #switch statements
Date: 4 Mar 1999 22:35:25
Message: <36DF52AE.726E3BB1@panama.phoenix.net>
Hi. Glad you started posting some code.
Yes, as far as I know, in C, switch is extremely slow when compared to if. I
recommend you use that.
Here's how I would do it.
#declare Value=abs(k) + abs(l);
#if (Value=1) #declare Unstretched = Unstretched1;  #end
#if (Value=3) #declare Unstretched = Unstretched5;  #end
#if (Value=4) #declare Unstretched = Unstretched4;  #end
#if (Value=2)
    #if ((k=0) | (l=0))
    #else
Date: 4 Mar 1999 22:46:41
Message: <36DF5350.C7DA7158@xs4all.nl>
Assuming you're using 3.01 why not use a (small) array?
That's probably the fastest you can get.
Remco
> this statement
>   #case (2)
>     #if ((k=0) | (l=0))
>     #else
>     #end
>   #break
> #end
> slow?
> Martin Magnusson
Date: 5 Mar 1999 05:26:58
Message: <MPG.1149d0093256ed4f9896a0@news.povray.org>
'T was on Fri, 5 Mar 1999 00:25:10 +0100,
> slow?
The switch statement is already slow in compiled code (C, that is). It's
total horror when used in an interpreted language like POV's. Use #if if
you can.
Phoenix
eag### [at] telekabelnl                       http://users.telekabel.nl/eagle
The POV-Ray VFAQ: http://iki.fi/warp/povVFAQ.html
Date: 5 Mar 1999 06:38:06
Message: <36DFC21D.23FAFB0B@peak.edu.ee>
Damn. I was convinced that #swich is faster and used it whenever I
could. It is faster in BASIC, if I'm not mistaken (or am I wrong there,
too?)
Margus
> you can.
> Phoenix
Date: 5 Mar 1999 07:15:44
Message: <36dfcaf0.0@news.povray.org>
Margus Ramst schrieb in Nachricht <36DFC21D.23FAFB0B@peak.edu.ee>...
>too?)
I'm not sure switch () is generally slower in C (don't know about POV-Ray or
BASIC) at all. Good optimizers will code a range of consecutive values (e.g.
4, 5, 6, 7, and 8) as a calculated jump or a jump table. But if the values
are not arranged so well, you will have code similar to the if ()
statements. In fact a switch statments should at least be converted to
something like:
if (value == value1) dothis;
else if (value == value2) dothat;
else if (value == value3) .... etc.etc.
else dothedefault;
The speed increase should come from the fact, that "value" doesn't have to
be reloaded, but can be compared against an array of values and according
jumps to code. Now C could be a bit difficult from my favourite language,
Pascal, in that code can fall through (if there's not break) to the next
case statement, but I'm not sure this will really slow things down. The
break statement should just be translated into a jump to the end of the
switch.
Now the implementation of #switch in POV-Ray could be different, because
POV-Ray is really interpreted, so pre-calucalted jumps or jump tables etc,
are out of the question here.
Rudy Velthuis
Date: 5 Mar 1999 07:15:46
Message: <36dfcaf2.0@news.povray.org>
Phoenix schrieb in Nachricht ...
>you can.
What makes you assume switch is slow in compiled code (C, Pascal, compiled
Basic) at all?
See my reply to Margus' reply too.
Rudy Velthuis
Date: 5 Mar 1999 07:24:04
Message: <MPG.1149eb79f78933399896a1@news.povray.org>
'T was on Fri, 5 Mar 1999 12:59:14 +0100,
> Basic) at all?
This may have to do with the compiler I once wrote for a simple version
of C. I had a hell of a time getting a working executable with a switch
statement, let stand the horror of optimizing the code in such a fashion
that would please my teacher...
In general, the time it takes to read in a jump table is far greater than
just using the jump system that gets generated by an if-clause.
Phoenix
Date: 5 Mar 1999 10:17:19
Message: <36dff57f.0@news.povray.org>
In article <MPG.1149eb79f78933399896a1@news.povray.org> , eag### [at] telekabelnl
That depends a lot on the density of the case conditions you have. Assume
you write a switch statement for the tokenizer in POV-Ray: You have most of
the ASCII characters and a high density of the numbers you compare. So the
compiler generates a jump table. It will most likely be somewhere around 128
entries. You need two comparisons plus branches (range checking) and one
jump. However, using a "if-clause jump system" you will in the worst case
have 128 comparsions and 128 conditional branches. Even if the processor
pipeline never gets interrupted you will still have 256 instructions
compared to only about 8 instructions. Compared to the "if-clause jump
system" average which would (assuming equal distribution, also for ASCII
characters (I used as example) it might be even worse) be 128 instructions -
not to mention the memory overhead...
     Thorsten
Date: 5 Mar 1999 11:03:16
Message: <36e00044.0@news.povray.org>
On Fri, 05 Mar 1999 09:17:18 -0600, Thorsten Froehlich
>jump.
This depends on your compiler.  I've seen modern compilers do one of two
things when given a switch statement like
switch (i) {
  case 1: foo(); break;
  case 2: bar(); /* fall through */
  case 4: baz(); break;
  default: quux(); break;
One compiler would make this look like:
  mov  esi, ebp+i
  dec  esi
  test esi, FFFFFFFC
  jnz  default
  mov  ebx, table[esi*4]
  jmp  [ebx]
table:
  .dd  case1
  .dd  case2
  .dd  default
  .dd  case4
case1:
  call foo
  jmp  end
case2:
  call bar
case4:
  call baz
  jmp  end
default:
  call quux
end:
The other (older, less efficient compiler) would make it look like:
  mov  eax, ebp+i
  dec  eax
  jz   case1
  jl   default
  dec  eax
  jz   case2
  jl   default
  sub  eax, 2
  jz   case4
  jmp  default
case1:
  (...same code as above...)
Both look no less efficient than what you'd expect from an if-else
chain.  The jump table might take up space, but it's pretty quick
to execute.  Note the fancy footwork in the first case: it does the
range checking for you in only three instructions, and only one
subtraction.  You can always do this when the table is a power-of-two
size.  If it makes sense to use a jump table in the first place, you
can always pad it to the next power of two.  All of this is, of
course, way off topic. :)
Subject: Off Topic: Re: Making faster #switch statements
Date: 5 Mar 1999 12:54:11
Message: <36e01a43.0@news.povray.org>
In article <36e00044.0@news.povray.org> , par### [at] my-dejanewscom (Ron
>>jump.
I assumed that this point would be obvious because it is a well known (I
thought) fact that different compilers generate different code. :-)
But maybe I should still have added it...
With CodeWarrior 4.1 I get these results (it does not offer assembler
output, so it is a bit harder to read the disassembled code - all compiled
on a Mac, of course :-)
The code on a 68K:
00000000: 4E56 0000          link      a6,#0
00000004: 202E 0008          move.l    8(a6),d0
00000008: 5380               subq.l    #1,d0
0000000A: 670A               beq.s     *+12           ; 0x00000016
0000000C: 5380               subq.l    #1,d0
0000000E: 670E               beq.s     *+16           ; 0x0000001e
00000010: 5580               subq.l    #2,d0
00000012: 6710               beq.s     *+18           ; 0x00000024
00000014: 6016               bra.s     *+24           ; 0x0000002c
00000016: 4EB9 0000 0000     jsr       foo
0000001C: 6014               bra.s     *+22           ; 0x00000032
0000001E: 4EB9 0000 0000     jsr       bar
00000024: 4EB9 0000 0000     jsr       baz
0000002A: 6006               bra.s     *+8            ; 0x00000032
0000002C: 4EB9 0000 0000     jsr       quux
00000032: 4E5E               unlk      a6
00000034: 4E75               rts
00000036: 8474 6573 7400     dc.b      0x84,'test',0x00
0000003C: 0000
And in PowerPC code:
00000000: 7C0802A6  mflr     r0
00000004: 90010008  stw      r0,8(SP)
00000008: 9421FFC0  stwu     SP,-64(SP)
0000000C: 2C030003  cmpwi    r3,3
00000010: 41820044  beq      *+68                    ; $00000054
00000014: 40800014  bge      *+20                    ; $00000028
00000018: 2C030001  cmpwi    r3,1
0000001C: 41820018  beq      *+24                    ; $00000034
00000020: 40800020  bge      *+32                    ; $00000040
00000024: 48000030  b        *+48                    ; $00000054
00000028: 2C030005  cmpwi    r3,5
0000002C: 40800028  bge      *+40                    ; $00000054
00000030: 48000018  b        *+24                    ; $00000048
00000034: 48000001  bl       .foo
00000038: 60000000  nop
0000003C: 48000020  b        *+32                    ; $0000005C
00000040: 48000001  bl       .bar
00000044: 60000000  nop
00000048: 48000001  bl       .baz
0000004C: 60000000  nop
00000050: 4800000C  b        *+12                    ; $0000005C
00000054: 48000001  bl       .quux
00000058: 60000000  nop
0000005C: 80010048  lwz      r0,72(SP)
00000060: 38210040  addi     SP,SP,64
00000064: 7C0803A6  mtlr     r0
00000068: 4E800020  blr
And in x86 code:
00000000: 8B 4C 24 04         mov       ecx,dword ptr [esp+4]
00000004: 89 C8               mov       eax,ecx
00000006: 2D 01 00 00 00      sub       eax,1
0000000B: 3D 03 00 00 00      cmp       eax,3
00000010: 77 2E               ja        $+48 ; --> 0x0040
00000012: FF 24 85 1C 00 00   jmp       dword ptr [eax*4+.text++28] near
00000018: 00
00000019: 8D 40 00            lea       eax,dword ptr [eax+0]
0000001C: 2C 00               sub       al,0
0000001E: 00 00               add       byte ptr [eax],al
00000020: 33 00               xor       eax,dword ptr [eax]
00000022: 00 00               add       byte ptr [eax],al
00000024: 40                  inc       eax
00000025: 00 00               add       byte ptr [eax],al
00000027: 00 38               add       byte ptr [eax],bh
00000029: 00 00               add       byte ptr [eax],al
0000002B: 00 E8               add       al,ch
0000002D: 00 00               add       byte ptr [eax],al
0000002F: 00 00               add       byte ptr [eax],al
00000031: EB 12               jmp       $+20 ; --> 0x0045
00000033: E8 00 00 00 00      call      _bar
00000038: E8 00 00 00 00      call      _baz
0000003D: EB 06               jmp       $+8 ; --> 0x0045
0000003F: 90                  nop
00000040: E8 00 00 00 00      call      _quux
00000045: C3                  ret       near
As you can see, it does not optimize this case, too, but a larger one and
then the optimizer starts doing its work:
 switch(i)
  case 5: foo1(); break;
  case 6: bar1(); break;
  case 7: baz1(); break;
  case 8: quux1(); break;
In 68K code:
00000008: 0C80 0000 0008     cmpi.l    #8,d0
0000000E: 6252               bhi.s     *+84           ; 0x00000062
00000010: D040               add.w     d0,d0
00000012: 303B 0006          move.w    (6,pc,d0.w),d0
00000016: 4EFB 0002          jmp       (2,pc,d0.w)
0000001A: 0048 0012          ori.w     #0x12,a0
0000001E: 001A 0048          ori.b     #0x48,(a2)+
00000022: 0020 0028          ori.b     #0x28,-(a0)
00000026: 0030 0038 0040     ori.b     #0x38,(64,a0,d0.w)
0000002C: 4EB9 0000 0000     jsr       foo
00000032: 6034               bra.s     *+54           ; 0x00000068
00000034: 4EB9 0000 0000     jsr       bar
0000003A: 4EB9 0000 0000     jsr       baz
00000040: 6026               bra.s     *+40           ; 0x00000068
00000042: 4EB9 0000 0000     jsr       foo1
00000048: 601E               bra.s     *+32           ; 0x00000068
0000004A: 4EB9 0000 0000     jsr       bar1
00000050: 6016               bra.s     *+24           ; 0x00000068
00000052: 4EB9 0000 0000     jsr       baz1
00000058: 600E               bra.s     *+16           ; 0x00000068
0000005A: 4EB9 0000 0000     jsr       quux1
00000060: 6006               bra.s     *+8            ; 0x00000068
00000062: 4EB9 0000 0000     jsr       quux
00000068: 4E5E               unlk      a6
0000006A: 4E75               rts
0000006C: 8474 6573 7400     dc.b      0x84,'test',0x00
00000072: 0000
In PowerPC code the optimizer takes over and you get:
0000000C: 28030008  cmplwi   r3,$0008
00000010: 41810068  bgt      *+104                   ; $00000078
00000014: 80820000  lwz      r4,@12(RTOC)
00000018: 5460103A  rlwinm   r0,r3,2,0,29
0000001C: 7C84002E  lwzx     r4,r4,r0
00000020: 7C8903A6  mtctr    r4
00000024: 4E800420  bctr
00000028: 48000001  bl       .foo
0000002C: 60000000  nop
00000030: 48000050  b        *+80                    ; $00000080
00000034: 48000001  bl       .bar
0000003C: 48000001  bl       .baz
00000040: 60000000  nop
00000044: 4800003C  b        *+60                    ; $00000080
00000048: 48000001  bl       .foo1
00000050: 48000030  b        *+48                    ; $00000080
00000054: 48000001  bl       .bar1
0000005C: 48000024  b        *+36                    ; $00000080
00000060: 48000001  bl       .baz1
00000064: 60000000  nop
00000068: 48000018  b        *+24                    ; $00000080
0000006C: 48000001  bl       .quux1
00000070: 60000000  nop
00000074: 4800000C  b        *+12                    ; $00000080
00000078: 48000001  bl       .quux
0000007C: 60000000  nop
00000080: 80010048  lwz      r0,72(SP)
00000084: 38210040  addi     SP,SP,64
00000088: 7C0803A6  mtlr     r0
0000008C: 4E800020  blr
And in x86 code:
0000000B: 3D 07 00 00 00      cmp       eax,7
00000010: 77 5E               ja        $+96 ; --> 0x0070
00000018: 00
0000001C: 3C 00               cmp       al,0
00000020: 43                  inc       ebx
00000021: 00 00               add       byte ptr [eax],al
00000023: 00 70 00            add       byte ptr [eax+0],dh
00000026: 00 00               add       byte ptr [eax],al
00000028: 48                  dec       eax
0000002B: 00 50 00            add       byte ptr [eax+0],dl
0000002E: 00 00               add       byte ptr [eax],al
00000030: 57                  push      edi
00000031: 00 00               add       byte ptr [eax],al
00000033: 00 60 00            add       byte ptr [eax+0],ah
00000036: 00 00               add       byte ptr [eax],al
00000038: 67 00 00            add       byte ptr [bx][si],al
0000003B: 00 E8               add       al,ch
0000003D: 00 00               add       byte ptr [eax],al
0000003F: 00 00               add       byte ptr [eax],al
00000041: EB 32               jmp       $+52 ; --> 0x0075
00000043: E8 00 00 00 00      call      _bar
00000048: E8 00 00 00 00      call      _baz
0000004D: EB 26               jmp       $+40 ; --> 0x0075
0000004F: 90                  nop
00000050: E8 00 00 00 00      call      _foo1
00000055: EB 1E               jmp       $+32 ; --> 0x0075
00000057: E8 00 00 00 00      call      _bar1
0000005C: EB 17               jmp       $+25 ; --> 0x0075
0000005E: 89 C0               mov       eax,eax
00000060: E8 00 00 00 00      call      _baz1
00000065: EB 0E               jmp       $+16 ; --> 0x0075
00000067: E8 00 00 00 00      call      _quux1
0000006C: EB 07               jmp       $+9 ; --> 0x0075
0000006E: 89 C0               mov       eax,eax
00000070: E8 00 00 00 00      call      _quux
00000075: C3                  ret       near
I have to admit that I don't understand x86 assembly language very well. So
I am still wondering what all these add operations do. Any ideas?
>All of this is, of course, way off topic. :)
Well, might be true...
    Thorsten
Date: 5 Mar 1999 13:37:53
Message: <36e02481.0@news.povray.org>
Thorsten Froehlich schrieb in Nachricht <36dff57f.0@news.povray.org>...
Exactly. IMHO most compilers will do a faster switch() than numerous
if-cascades. See also Ron Parker's output of two compilers. They're both
faster than a simple cascade of if's would be. Now this could be different
for the interpreted POV-script (I still didn't have a look at the code yet)
and interpreted BASIC (I think VB and other "compiled" Basics can handle
switch statements just as well as other languages).
Rudy Velthuis
Subject: Re: Off Topic: Re: Making faster #switch statements
Date: 5 Mar 1999 13:37:54
Message: <36e02482.0@news.povray.org>
Thorsten Froehlich schrieb in Nachricht <36e01a43.0@news.povray.org>...
>And in x86 code:
>00000018: 00
>0000004F: 90                  nop
I was doing some arithmetic first, because I didn't get it either, but it's
quite simple. From 0000018 on, you don't see code, you see a kind of jump
table (dword entries). Of course the disassembler doesn't know this, so it
is shown as code.
Rudy Velthuis
Date: 5 Mar 1999 14:42:11
Message: <36e03393.0@news.povray.org>
Don't take my stuff as gospel, though.  I reverse-engineer stuff for a
living, so what you see is from memory, probably not 100% accurate,
could have even been hand-coded by some masochist, and is almost
certainly filtered through my "understand-o-meter"
I don't know what about switch in POV would make it slow, other than the
requirement that it parse even the parts it doesn't use, to find the parts
it needs.  In this case, an array would be the best bet.  In other cases,
it's mostly empirical.  The idea should be to minimize the amount of
text in each case, but that won't always be the best solution either.
Date: 5 Mar 1999 17:43:15
Message: <36e05e03.0@news.povray.org>
Ron Parker schrieb in Nachricht <36e03393.0@news.povray.org>...
I don't do it for a living, but I've seen enough code (Pascal and C
disassembly) like the samples you showed to believe this is the way most
switch statements (should) work. Even the example Thorsten showed seems to
do this (although it was hard to recognise at a first glance).
I don't know how the parser handles a #switch, but I'd expect it to look for
the end of the #switch block when it encounters #break and to look for the
next #case or #range, when a #case/#range check fails. Don't know how this
could be improved easily.
Rudy Velthuis
