Hi Spider,
I've taken to avoiding reading your posts, as whenever I do, it changes the font (in
Outlook Express ) to a large and ,dare I say, quite ugly one, and I have to go into
Options and change it. It's not my intention to cause offence, I was merely wondering
why
this was happening, as it never used to. And I do like to hear what you have to say.
Andy
and### [at] acocker freeserve co uk
I've noticed the same thing. Also, it's not limited to Spider's posts since
I have encountered it with others (both in the newsgroup and in email).
Maybe it's that demon, HTML :>}
Jim
Check out my web site http://www.kressworks.com/
It'll blow your mind (politically), stimulate your senses (artistically)
and provide scientific insights beyond compare!
Be sure to read the Warp maintained POV VFAQ:
http://iki.fi/warp/povVFAQ.html
Andrew Cocker wrote in message <36b34a58.0@news.povray.org>...
>Hi Spider,
font (in
go into
wondering why
have to say.
>Regards,
>Andy
On Sat, 30 Jan 1999 14:31:33 -0500, "Jim Kress" <jim### [at] dccmail com>
Spider's posts aren't in HTML, but they're in a "user-defined"
charset, which might be confusing your newsreader. When I'm
using SLRN, it offers to run them through metamail, because
they're a nonstandard MIME type. This is probably a config
problem on his end, but I haven't complained about it before
now because they are just plain text, and telling SLRN to
ignore the MIME type makes them perfectly readable for me,
unlike HTML.
Hello group.
I am aware of the problem, and of HOW it came to be.
But I am not familiar with any way of getting RID of it..
I am using Netscape 4.5 as a newsreader, and web-browser..
I know that the error ocurred when I had installed JDK 1.2 that included the JAVA 1.2
plugin.
It then messed up the settings, and all my messages was shown as Binary.
So, to get rid of this, I set the view-> character set to user-defined, since that was
the
thing that worked and showed my mail.
Then, I uninstalled JDK, and the plugin, but I haven't been able to _save_ any
settings
since.
The character set always returns to user defined, whatever I do.
Does anyone know how to fix this mess for me ???
I haven't opened the registry yet, since it is generally a mess to find all occurances
there..
All help appreciated, and once more, I do not wish to cause any trouble for you out
there.
In need of help,
//Spider
Spider wrote:
> Hello group.
1.2
> plugin.
was the
settings
> since.
occurances
> there..
there.
> In need of help,
> //Spider
Netscape has a nasty habit of hiding it's utility reference
files all over the place. You might try finding the file
called prefs.js (ithink it's js ?)and either rename it or
delete it. This will force you to reconfigure everthing
again the first time you start the program. Then again
that part of the information my no be stored in the
particular file. If you really want to get rid of pesky
Netscape bugs check the dates of every file in the
subdirectorys. If they have todays date then you know
the program has been writing to it. Bite the bullet
and delete them all. You will have to resubscribe to all
of your newsgroups, lose stored email access files, lose
your browsers history file, and a probably a dozen other
unknow consiquences but I feel this will have a good chance
of correcting you current problem without having to muck
around in the registry file.
Either that or just use the dos command deltree and reinstall :)
Ken Tyler
tyl### [at] pacbell net
I think I've found it...
A pretty simple... Writing protection on all files in my user-folder.
*sigh*
Tell me if it's messed up.. please
//Spider
Ken wrote:
> Spider wrote:
> > Hello group.
1.2
> > plugin.
was the
settings
> > since.
occurances
> > there..
out there.
> > In need of help,
> > //Spider
> Ken Tyler
> *sigh*
I have never had a problem reading your posts - I don't think
anyway. Is that you typing in three periods after every sentence
or is the program adding that for you ?
Ken Tyler
Looks fine now ...
Jim
Ken wrote in message <36B3CCA7.AEB7F5AA@pacbell.net>...
>> *sigh*
>Ken Tyler
No, the dots are just me and my lazy typing style. Intended to mark my sighing,
dreaming,
depressed way of expressing myself. I'll try and stop it, since I know it's a pretty
bad
habit that disturbs the reading pattern. But...*sigh*
//Spider
Hmm...I have a tendancy to do that as well...I was never much of a...you
know...english major type person...oh well, never mind.
-Mike
dreaming,
bad
> //Spider
Hi!
I have the same problem with Outlook Express, though I didn't make the
connection to Spider's posts - I just thought it was an Outlook bug. Now
that I kept my eyes open I indeed noticed that the change to the other font
happens with Spider's posts (but not all of them, for example his answers in
this thread had no effect).
Anyway, a simple way to switch back to the normal font is to select some
other newsgroup on news.povray.org in the newsgroup list at the left, then
come back to the group you were reading. The next post you open has the
standard font again (well, at least that works for me...).
Greetings,
Johannes.
>Hi Spider,
font (in
go into
wondering why
have to say.
>Regards,
>Andy
Outlook Express users,
While messing with Spiders postings, I found a way to automatically convert
messages from user-defined to western-alphabet.
Doubleclick one of Spiders older messages, you wil get a separate window
with the message. Select image > language. There should be a dot before
user-defined. Select Western-alphabet. Outlook now asks if you want to do
this for all user-defined character-sets.
I hope I rememberd what I did the right way. I was clicking around a bit
when I found this.
hope it helps,
ingo
For Netscape users, View->Character_set->western
Well, My posts should be readable now.
//Spider
>*sigh*
Your charset is okay now. I didn't check anything else, and I don't
use SLRN on this machine, but I'll be sure to let you know if I have
any problems.
Spider wrote in message <36B### [at] bahnhof se>...
>//Spider
They are indeed - thanks for sorting it out :)
Matt
>*sigh*
It's fixed from here, too. Thanks. :)
