Attention POV-Team
I found a cool primitive that HAS got to be included in POV-Ray now! It
is very cool!!!
(Check out the upper folder [modelling], it has good stuff too).
http://www.mhri.edu.au/~pdb/modelling/supertoroid/
Anthony Bennett wrote:
> Attention POV-Team
> is very cool!!!
I guess the equivelant would be a superellipsoid like object that takes
the form of a torus. I see possiblities for this shape. If not an official
primitive addition one of the patchs might pick it up. Nice of them to
provide the C code for it.
Ken Tyler
mailto://tylereng@pacbell.net
> Attention POV-Team
> is very cool!!!
Ron or lutz please add this to the next versions! please!
Anthony Bennett schrieb in Nachricht
<36D2241A.40B29D05@panama.phoenix.net>...
>Attention POV-Team
>is very cool!!!
Yes really interesting shape. Like Ken said, a weird combination of
superellipsoid and torus. Gives you square but rounded donuts. You'd need a
smaller box for transport, I think.
Rudy Velthuis
>> Attention POV-Team
>> is very cool!!!
Unfortunately, it doesn't provide what we really need: the equations for
the intersection of one of these beasts with a line. 'Tis an interesting
object, though, and I've bookmarked it for further investigation.
On 23 Feb 1999 08:29:08 -0500, par### [at] my-dejanews com (Ron Parker)
>>> is very cool!!!
I coded it as a macro using the parametric object in SuperPatch. For
some reason, it works fine with exponents of 1.0 (regular torus) but
gives garbage for any other exponent. Is it the parametric object,
the equations in the referenced page or my bad coding? I am going to
redo it as a mesh object with those equations and see what happens.
If anyone else wants to play with this, here is the macro I used. To
repeat, it uses the SuperPatch. Sorry about the underscores and
indenting, Ken!
// Begin POV code
// _Rj is major radius
// _Rn is minor radius
// _E1 and _E2 are exponents
#macro Supertoroid(_Rj, _Rn, _E1, _E2)
parametric
function (cos(u) ^ _E1) * (_Rj + _Rn * (cos(v) ^ _E2)),
(sin(u) ^ _E1) * (_Rj + _Rn * (cos(v) ^ _E2)),
(sin(u) ^ _E2) * _Rn
<0, 0>, <2 * pi, 2 * pi>
<-(_Rj + _Rn + .1), -(_Rj + _Rn + .1), -(_Rj +_Rn +.1)>,
<_Rj +_Rn + .1, _Rj + _Rn + .1, _Rj + _Rn + .1>
accuracy .001
rotate <90, 0, 0>
// End POV code
Jerry Anning
clem "at" dhol "dot" com
What does Lutz have to do with this? He writes a modeller -- He could make
it as a mesh, or something, but (AFAIK) he's never hacked the pov code.
(easier would be to make a plugin, I think)
( I hope this isn't another case of confusing a modeller with a
renderer... )
povray.doc -- An engaging tale about a spanish guy named Manual.
Psychomek wrote in message <36D2454B.25975805@cyberhighway.net>...
>> Attention POV-Team
>> is very cool!!!
That's a great find, looked at the Superellipsoid page too and may now
understand (well, not really understand) why you get disappearing
superellipsoids at certain input values.
> Attention POV-Team
> is very cool!!!
mailto:inv### [at] aol com?PoV
OK, I've just written an email to a place that makes free plug-ins for MAX.
They produced a plug-in that makes these objects, it's very cool. I've
asked them if they know a formula for the intersection test. I'm not sure
if they will be able to help though because MAX uses adaptive meshs.
Anyway, it's worth a try I guess.
Lance.
For the latest 3D Studio MAX plug-ins, images and much more, go to:
The Zone - http://come.to/the.zone
Jerry Anning wrote:
> Sorry about the underscores and indenting, Ken!
> // Begin POV code
I don't understand why you would want to increase the amount of typing
needed to produce your work, but if it make you happy, then I'm happy.
Ken Tyler
> renderer... )
It does look like a fun primative. Added to a modeler like Moray would
have it's challenges if support wasn't offered by the program rendering
the file. If it was in native Pov format it would gain the benefit of
having varaibles for changing the behavior of the object and would be
a better option. I liked the different shapes shown using various
parameters. Many had similar patterns like the index of superellisoids
I did not so long ago.
Ken Tyler
Ken schrieb in Nachricht <36D3293F.1CC960F0@pacbell.net>...
>> // Begin POV code
I don't understand he even puts some comments and empty lines in there (much
more typing), except for clarity perhaps. But I must admit, the comments are
not indented <g>.
Rudy Velthuis
On Tue, 23 Feb 1999 18:13:00 GMT, nos### [at] despam com (Jerry Anning)
It appears to be a little of both the parametric object and your
bad coding. :) First, your bad coding:
The z term is supposed to be based on sin(v), not sin(u).
Now the bad news: there seems to be an issue with the parametric
stuff that I don't fully understand. It seems like only things
in the first quadrant, where both the sin and the cos are positive,
get rendered correctly. I found an ABS in the code for exponentiation
that could have caused the problem, but removing it didn't seem to
make the problem go away. It's possible that I'm missing something
somewhere else in the code. Unfortunately, I didn't write it, so
understanding it fully could be a bit of a treat.
On Wed, 24 Feb 1999 04:04:51 GMT, par### [at] mail fwi com (Ronald L.
Thanks for the debug, Ron. I thought that seemed odd, but I looked at
the original equation several times and saw "theta" instead of "phi"
every time. Maybe I should sue my opthalmologist. Good luck on the
parametric code. FWIW, I will dig up the isosurface source and have a
look, but my compiler is broken so I can do no testing at the moment.
Incidentally, I turned your SuperPatch doc into a Windows help file
for my own use. If you want to add it to the distribution, let me
know and I'll clean up the index and send it along. If you want to
send info on changes for the next version, I'll gladly add it.
Jerry Anning
For the next version of Moray IF the Povray team adds it to the Program....
> -- He could make
> renderer... )
Could be... but not sure....
> >> Attention POV-Team
> >> is very cool!!!
Jerry Anning <nos### [at] despam com> wrote:
: FWIW
What does this mean?
main(i){char*_="BdsyFBThhHFBThhHFRz]NFTITQF|DJIFHQhhF";while(i=
*_++)for(;i>1;printf("%s",i-70?i&1?"[]":" ":(i=0,"\n")),i/=2);} /*- Warp -*/
> : FWIW
For what it's worth
I printed out a dictonary about web acronyms yesterday! ;-)
see http://www.whatis.com/
Marc
Marc Schimmler
> : FWIW
For What It's Worth
Ken Tyler
Jerry Anning wrote in message <36d2ed6f.2561587@news.povray.org>...
>indenting, Ken!
Arrghh!!!! I can't get it to work at all.
Like this:
isosurface{Supertoroid(1,.3,1,1)}
Error: function is not defined
Like this:
isosurface{function{Supertoroid(1,.3,1,1)}}
Error: no matching brace in function
Like this:
#declare S=Supertoroid(1,.3,1,1)}
isosurface{S}
POV crashes (page fault in povray.exe)
If I add precompute to Supertoroid, the scene renders, but the isosurface is
just a box.
I must admit, this is the first time I tried the parametric{} isosurface, so
i may be doing something real stupid. But the crashing is suspicious. Maybe
a bug?
Help! Hilfe! Aidez-moi! Hjälp! Apua! Appi! (i.e. I'd like some help. please)
Margus.
On Wed, 24 Feb 1999 23:35:47 +0200, "Margus Ramst"
>>indenting, Ken!
>Like this:
>Like this:
>Like this:
>isosurface{S}
>just a box.
>a bug?
>Margus.
First, the parametric object is an independent type in its own right,
not an isosurface function. The macro simply wraps a parametric
*object* up and makes it easily usable. Second, there seems to be an
issue about using #declare or #local with the parametric object.
Every variation of that that I try goes straight to GPF city during
the parse. Third, as Ron Parker mentioned, the parametric object
seems to want to be first quadrant only. Since the supertoroid has
suitable symmetry, you can get around that by making four rotated
copies of the object. Since #declare is out, you have to splat four
actual copies of the parametric code into a union in the macro. Here
is an (ugly, dog-slow) working version of the macro with a demo of how
to call it:
// Begin POV code
union
parametric
(sin(v) ^ _E2) * _Rn
accuracy .001
rotate <90, 0, 0>
parametric
accuracy .001
rotate <90, 0, 0>
rotate <0, 90, 0>
parametric
accuracy .001
rotate <90, 0, 0>
rotate <0, 180, 0>
parametric
accuracy .001
rotate <90, 0, 0>
rotate <0, 270, 0>
// End POV code
You call it like this:
// Begin POV code
object
Supertoroid(8, 3, 2, .5)
texture
pigment { color Red }
normal { dents 2 scale <.1, 3, .2> }
finish { specular 1 roughness .002 }
rotate <-30. -30, 0>
// End POV code
I will post the mesh version somewhere in a day or so. Should be much
faster to render, although slower to parse. Good luck.
Jerry Anning
