POV-Ray : Newsgroups : povray.general : Kenneth requested some math help Server Time
28 Oct 2026 05:28:03 EDT (-0400)
  Kenneth requested some math help (Message 1 to 2 of 2)
Subject: Kenneth requested some math help
Date: 17 Feb 1999 22:22:15
Message: <36CB8770.F25820C3@virginia.edu>
Well, it isn't perfect (I don't have the scaling down for spheres,
though they should looks okay without it) but it does most of what you
want.  By defining the dimensions of the box (YZDim is the one that
really matters) and the number of segments you want per degree of arc
the radius is defined.  The scaling should be more accurate, and if you
choose type 4 (quarter sphere) or type 2 (hemisphere) should scale
correctly.  Type 1 (sphere) doesn't scale as mentioned above but does
render and doesn't look bad (at least from a small distance.  As long as
your segments per degree is greater than say 0.25 it shouldn't matter
too much.  The biggest way to slow parse time is to increase SPD
(segments per degree) to a value greater than 0.5 at 1 it took me 5
minutes to parse a sphere whereas 0.5 took around 30 seconds... Of
course that is POVRay hitting my 64meg physical RAM limit.  Hope this
helps Ken.
Steve
Download 'halfdome.pov.txt' (3 KB)
Subject: Re: Kenneth requested some math help
Date: 18 Feb 1999 02:12:17
Message: <36CBBCE9.DA017E24@pacbell.net>
> helps Ken.
> Steve
I am greatful for your efforts on my behalf and speak for those who I may
choose to share it with. Your contribution was in the true spirit of the
brotherhood of Pov people everywhere and just another example of why this
type of system can work.
Thank you.
Ken Tyler
mailto://tylereng@pacbell.net
