POV-Ray : Newsgroups : povray.general : transparency gradient? Server Time
27 Mar 2026 00:30:13 EDT (-0400)
  transparency gradient? (Message 1 to 10 of 15)
Subject: transparency gradient?
Date: 15 Feb 1999 18:35:00
Message: <36C8AFC1.F51E1374@ica.uni-stuttgart.de>
I'm just wondering if it is possible to make an object which
transparency that changes with it's height?
Imagine a cylinder which is nearly total transparent at it's bottom and
and fully opaque at the top.
Any help appreciated from indenters as well as from non-indenters!!! ;-)
Thanks in advance,
Marc
Marc Schimmler
Subject: Re: transparency gradient?
Date: 15 Feb 1999 18:57:22
Message: <36C8B40C.90E30E9E@pacbell.net>
> Thanks in advance,
> Marc
Note: for the purpose of this response I am going to refer to
transperancy as clear just because it's easier to type :)
You are on the right track with the gradient idea. The thing you
have to watch out for with mixing solid pigments with clear pigments
is that the pattern function will blend the solids in with the clear
parts making them much less clear. TO get around this you have to
carefully design you color map around this limitation.
An untested example:
                              cylinder{
                             <0,-1,0>,
                            <0,1,0>,
                           1
                          pigment{
                         gradient y
                       color_map{
           [0.0 rgbf<1,1,1,1.0>]
           [0.2 rgbf<1,1,1,0.8>]
           [0.4 rgbf<1,1,1,0.6>]
           [0.6 rgbf<1,1,1,0.4>]
           [0.8 rgbf<1,1,1,0.2>]
           [1.8 rgbf<1,1,1,0.2>]
           [1.0 rgbf<1,1,1,0.0>]
                      translate -.5
How is my indenting now people ?
Anyway if you study the example you will see that I have bracketed each
map entry with a duplicate entry. This causes a sharp demarcation of
pigment color, clearness, and stops the bleeding from adjacent entries.
This example may be too sharp in it's cutoff points for what you want.
To correct this let each value in the color map entry extend a bit
higher than the one before it. If that doesn't work for you then just
start randomly playing with values and see what happens. Exploration
is a mighty powerfull teacher and there are few substitutions that will
replace it.
Ken Tyler
mailto://tylereng@pacbell.net
Date: 15 Feb 1999 19:13:21
Message: <36C8B6D8.23C34458@bahnhof.se>
> > Thanks in advance,
> > Marc
>                               cylinder{
>                              <0,-1,0>,
>                             <0,1,0>,
>                            1
>                           pigment{
>                          gradient y
>                        color_map{
>                       translate -.5
interesting. it's.... Different.
> replace it.
Well, that is if you want it to be filtering the light.
Easier would be transparent.(transmit)
  gradient y
  tubulence <0.3,1.2,0.2>
  octaves 3600 //ou _are_ patient, aren't you *smile*
  omega 1/24
  lambda 0.4
  colour_map {
    [0.0 colour rgbt <0.7,0.7,1,0>]
    [1.0 colour rgbt <0.7,0.7,1,1>]
//Spider
"42"
http://www.bahnhof.se/~spider/
Date: 15 Feb 1999 19:48:12
Message: <36c8c04c.0@news.povray.org>
Creative, yet still functional.  Go with it!
Date: 15 Feb 1999 20:36:45
Message: <36C8CB58.D0297D84@pacbell.net>
> Thanks in advance,
> Marc
> Marc Schimmler
  After Spiders comments I felt compelled to prove, to myself anyway, that my
example was indeed an accurate representation of the requested pigment pattern.
I met those requirements quite well thank you. As for my comments in my other
reply to this thread about extending the color map entries so each map entry
is more the it's predecessor I went ahead and adjusted the map for you plus
corrected a couple of scaling issues. The example below should easily satisfy
your requirements. From what I saw the pigment is indeed clear at the bottom and
goes completely solid at the top. You may wish to still have some transparent
value even at the top and may accomplish this by extending the filter values
to the end of the color map.
Note to Spider:
  While your example was both a creative and fanciful example of
blending solid and transparent pigments it really didn't address
Marc's requirements for a gradual transition from clear to solid.
Marc may well take note of your example as it does show one of the
often under used and powerful features of creative texturing. The
one main fault with your example is that it is difficult at best
to get a totally transparent blend from one end of an object to the
other with only two entries in your color map (not to mention the
large amounts of turbulence used). Three pallet entries are almost
mandatory and four of more offer considerably greater control of the
patterns function.
  // #Ken       = 1
  // #indenting = 0
  cylinder{<0,-1,0>,<0,1,0>,1
  pigment{gradient y color_map{
  [0.1 rgbf<1,1,1,1.0>]
  [0.2 rgbf<1,1,1,0.9>]
  [0.3 rgbf<1,1,1,0.8>]
  [0.4 rgbf<1,1,1,0.7>]
  [0.5 rgbf<1,1,1,0.6>]
  [0.6 rgbf<1,1,1,0.5>]
  [0.7 rgbf<1,1,1,0.4>]
  [0.8 rgbf<1,1,1,0.3>]
  [0.9 rgbf<1,1,1,0.2>]
  [1.0 rgbf<1,1,1,0.0>]}
  translate -.5 scale 2}
  scale<1,2,1>}
Ken Tyler
Date: 15 Feb 1999 21:40:25
Message: <36C8D94F.A0AC8191@bahnhof.se>
> > Thanks in advance,
> > Marc
> > Marc Schimmler
> Note to Spider:
> patterns function.
Yes, I understand and agree with you, but I thought your example was so
good at adressing the use of multiple entries in a colour_map that I
don't needed to add those(forgot is abetter explination)
as for the turbulence, it was mostly a joke, but with a more serious
tone to it.
I've taken the right to render an example with both our variants.
I'll convert to jpg. and upload to binaries.images.
Here is the source.
look here in the beginning. I haven't made an attempt to make my code
look like ken's, notr the results.
#version 3.1;
#declare SpidMap =
color_map {
  [00/10 color rgbt <1,0,0,1> ]
  [01/10 color rgbt <1,0,0,1> ]
  [09/10 color rgbt <1,0,0,0> ]
  [10/10 color rgbt <1,0,0,0> ]
#declare KenMap =
color_map{
  [00/10 rgbf<1,0,0,1.0>]
  [01/10 rgbf<1,0,0,1.0>]
  [02/10 rgbf<1,0,0,0.9>]
  [03/10 rgbf<1,0,0,0.8>]
  [04/10 rgbf<1,0,0,0.7>]
  [05/10 rgbf<1,0,0,0.6>]
  [06/10 rgbf<1,0,0,0.5>]
  [07/10 rgbf<1,0,0,0.4>]
  [08/10 rgbf<1,0,0,0.3>]
  [09/10 rgbf<1,0,0,0.2>]
  [10/10 rgbf<1,0,0,0.0>]
global_settings { assumed_gamma 1.0 }
  location  <0.0, 0.5, -4.0>
  direction 1.5*z
  right     4/3*x
  look_at   <0.0, 0.0,  0.0>
sky_sphere {
    gradient y
    color_map { [0.0 color blue 0.6] [1.0 color rgb 1] }
light_source { <-30, 30, -30>,color rgb 1 }
plane { y, -1 pigment {color rgb 1} finish{ambient 0 }}
//Top left
cylinder {
  <0,1,0>,<0,0,0>, 0.6
      gradient y
      color_map { SpidMap }
    finish{ specular .2 }
  translate -0.7*x
  translate 0.1*y
//lowLeft
cylinder {
      gradient y
      turbulence <0.3,1.2,0.2>/100
      omega 1/24
      lambda 0.2
  translate -0.7*x
  translate -0.99999*y
//low right, Ken's method
cylinder {
      gradient y
      color_map{ KenMap }
  translate 0.7*x
//top right, Ken's method
cylinder {
      gradient y
      omega 1/24
      lambda 0.2
      color_map{ KenMap }
  translate 0.7*x
  translate 0.1*y
Date: 16 Feb 1999 02:52:24
Message: <36C923B8.3D29DB9F@ica.uni-stuttgart.de>
Thank you Mr. Tyler thank you Spider!
Your advice is a real great help for me!
Povingly,
Marc
Marc Schimmler
Date: 16 Feb 1999 05:22:04
Message: <36C9471B.AB1B4B8D@snafu.de>
Hi
I think it the Ken Map would work better if you are not just fading from red to
transparent red.
Try to fade to transparent White.
I mean the following
color_map {
    [0 color rgbf <1,0,0,0>]
                ...                            <- i still don't know why it is
nesscesary to make multiple entrys ?
    [1 color rgbf <1,1,1,1>]
> > > Thanks in advance,
> > > Marc
> > > Marc Schimmler
> > Note to Spider:
> > patterns function.
> tone to it.
> Here is the source.
> #version 3.1;
> #declare SpidMap =
> color_map {
> #declare KenMap =
> color_map{
> camera {
>   direction 1.5*z
>   right     4/3*x
> sky_sphere {
>   pigment {
>     gradient y
> //Top left
> cylinder {
>   texture {
>     pigment {
>       gradient y
>   translate -0.7*x
>   translate 0.1*y
> //lowLeft
> cylinder {
>   texture {
>     pigment {
>       gradient y
>       omega 1/24
>       lambda 0.2
>   translate -0.7*x
> cylinder {
>   texture {
>     pigment {
>       gradient y
>       color_map{ KenMap }
>   translate 0.7*x
> cylinder {
>   texture {
>     pigment {
>       gradient y
>       omega 1/24
>       lambda 0.2
>       color_map{ KenMap }
>   translate 0.7*x
>   translate 0.1*y
Date: 16 Feb 1999 05:55:44
Message: <36c94eb0.0@news.povray.org>
The simplistic version:
cylinder
{ 0,y,1
  pigment
  { gradient y color_map
    { [0 rgb 1]
      [1 rgbf 1]
main(i){char*_="BdsyFBThhHFBThhHFRz]NFTITQF|DJIFHQhhF";while(i=
*_++)for(;i>1;printf("%s",i-70?i&1?"[]":" ":(i=0,"\n")),i/=2);} /*- Warp -*/
Date: 16 Feb 1999 06:27:43
Message: <36C9562E.3386C025@ica.uni-stuttgart.de>
Hi Warp1
Thank you for your answer!
I checked your solution and changed it in two ways.
First a height of 1 for the cylinder leads to the repeating of the
gradient so that both ends are opaque. By using y*0.999 I avoided this.
Second, the effect I was looking for is more the solution spider had
given using the rgbt instead of the rgbf.
I will post at binaries.images two cylinders that show the difference.
Again, thank you
Marc
Marc Schimmler
