Hi
I am trying to combine real Images, and POV-Images, and for that i need
to know
how to create Objects, that make shadows, but are not seen, i mean they
must be
100 % transparent, but the shadows must be dark.
Does anybody know if such things are possible with POV-Ray ?
or maybe knows some alternatives ?
greetings Lars Wolter
E-Mail : lar### [at] snafu de
Homepage : www.snafu.de/~larts.wolter
Well, I'll give you the hint on where to find the message, Ken will give
you the link soon enough. I'm not sure if this is exactly what you
want, but Dan Connelly posted an image in which he had a sphere casting
a square shadow. It was several months back, but I remember it
distinctly and wondering if I would ever find a use for his method. Ken
will know more.
Steve
"Lars W." wrote:
> Hi
> to know
> must be
In article <36C87745.5713B049@snafu.de> , "Lars W." <lar### [at] snafu de>
> to know
> must be
Yes, there is a trick. Combining the filter and transmit color components
will do it. Then make sure you render _with_ alpha channel to a format that
supports alpha channels (e.g. PNG). All you need now is a program that can
use this alpha channel to mix the two images (Photoshop and some shareware
programs can do it).
Now here is the sample:
camera
location <0.0, 0.5, -4.0>
direction 1.5*z
right 4/3*x
look_at <0.0, 0.0, 0.0>
// you need skysphere not background
sky_sphere
pigment
color blue 1.0
// some light
light_source
<-30, 30, -30>
color rgb 1.0
plane { y, -1 pigment { color green 1.0 } }
// the object
sphere { 0.0, 1 texture { pigment { color rgb 1.0 } } }
// the "hole", just a bit larger than the original object
sphere { 0.0, 1.0001 texture { pigment { color filter 0.0 transmit 1.0 } } }
So all you need to do is to create the object twice. Make one (the second
one in the example above) of them a bit larger and set its texture to
"texture { pigment { color filter 0.0 transmit 1.0 } }". Note that just
"color filter 0.0 transmit 1.0" (the direct color option) won't work, you
need a complete texture. The filter makes the object invisible and the
transmit make the "hole" in the alpha channel.
In the example the first object creates the shadow and when you render with
preview you won't see a difference (except on Macs where you can see the
alpha channle during rendering).
Thorsten
"Lars W." <lar### [at] snafu de> writes:
> Hi
> to know
> must be
If you don't find any alternatives, contact me. I have hacked the source
code of POV-Ray to allow just what you want: Completely transparent objects
casting black shadows. Additionally, if have created a possibility to
completely avoid shadows on an object. (This is different from the no_shadow
keyword. In the latter case, the object doesn't cast shadows, whereas my
addition removes the shadows from the object.)
I have used these modifications to create my image "twklein"
http://www.fmi.uni-konstanz.de/~willhalm/graphics/tracegallery/index.html
Unfortunately, my hack doesn't work anymore with POV-Ray 3.01, and I guess
that this is also true for the upcoming version 3.1. So you have to stick
with 3.0, if you want to use my modifications. I could provide you binaries
for Solaris, Linux, or SGI, or I can send you the source code.
Lars W. wrote:
> Hi
> to know
> must be
How realistic does the shadow have to be?
You can create a 'shadow' by using a light_source with a negative colour
value.
eg. point a spotlight with a colour of rgb -1 at the ground and you'll
get a dark
circle. As for real shadows from invisible objects, sorry no ideas.
Cheers, PoD.
> Lars W. wrote:
> > Hi
> > to know
> > must be
One idea: if you have one predominant light-source, put a very, very tiny
version of your object [sub-pixel-sized] very close to it. As the light
source is a point, a .01mm object .02mm away from the light will cast just
as good a shadow as a 1m object 2m away. This has the advantage that it
allows an actual POVthing to cast a shadow w/o being seen. It won't work if
there are several strong light sources, unless you get the proportions and
positions just right.
(If you *do*, though, there is no reason that you could not get [say] a
human figure that appears only by casting *correct* shadows in several
intersecting spotlights. Spooky!) I don't think it will work at all with
linear or area lights.
Another possibility is to create a darklight [=negative intensity light
source] in a "magic lantern" [= opaque box with a shaped cutout or
transparent "dianegative"] and, again, shrink it to speck size. With this,
I imagine that you could even cast colored shadows [think a shadow with
colored eyes?] This will work against any available light but has the
disadvantage that it may interact oddly with other shadows - it may look
more like a dark stain than a shadow, as it will interact independly with
shadows from every source.
-Robert Dawson
PoD <pod### [at] merlin net au> writes:
> colour value. eg. point a spotlight with a colour of rgb -1 at the
> ground and you'll get a dark circle. As for real shadows from
Still thinking...
Two light sources... One coloured +1 is normal, one coloured -1 is
shadowless... No, that won't work.
And with negative transparency... Won't work either.
I'm sure the solution is lurking around those two themes. Just cannot
find it right now.
Roland.
Roland Mas
- Ogenki desuka, yau de poêle ?
- Genki desu, ture en zinc.
Hi
Thanks for all your responses, i think i use the trick with the alpha
channel, cause i have to use the alpha
anyway. The trick with the negative Light is good too, but i need shadows
from 3D-Objects, and developing
an Projektor image that looks like 3d is a bit complicated.
greetings Lars
Thanks for the tip,
by implementing this into my scene i recogniced another problem, maybe you can
help me with this one too.
Does POV-Ray only supports 1 bit Alpha Channels, or is there a Trick to use more
then 1 bit, maybe 8 or 16
or am i so blind, and it has more than one bit, cause the compositing Programm
DTA ( Daves Targa Animator 3.0 beta ) converts
the alpha channel only to an black and White image, even when there are
transparencies in there ( i removed any Skyspheres for
testing that ).
greetings Lars
> > to know
> > must be
> camera
> direction 1.5*z
> right 4/3*x
> sky_sphere
> pigment
> color blue 1.0
> // some light
> light_source
> <-30, 30, -30>
> color rgb 1.0
> // the object
> Thorsten
POV-help is here !
Output_Alpha=bool Sets alpha output on/off
Bits_Per_Color=n Sets file output bits/color to n
The default type of image file depends on which platform you are using.
MS-DOS and most others default to 24-bit uncompressed Targa. See your
platform-specific documentation to see what your default file type is.
You may select one of several different file types using
Output_File_Type=x or +Fx where x is one of the following...
+FN New PNG (portable network graphics) format
(this isn't very interesting)
Most of these formats output 24 bits per pixel with 8 bits for each of
red, green and blue data. PNG allows you to optionally specify the
output bit depth from 5 to 16 bits for each of the red, green, and blue
colors, giving from 15 to 48 bits of color information per pixel. The
default output depth for all formats is 8 bits/color (16 million
possible colors), but this may be changed for PNG format files by
setting Bits_Per_Color=n or by specifying +FNn, where n is the desired
bit depth.
-------(THIS IS INTERESTING)
Targa format also allows 8 bits of alpha transparency data to be output,
while PNG format allows 5 to 16 bits of alpha transparency data,
depending on the color bit depth as specified above. You may turn this
option on with Output_Alpha=on or +UA. The default is off or -UA. See
section "Using the Alpha Channel" for further details on transparency.
all this from the doc's -
//Spider
( spi### [at] bahnhof se ) [ http://www.bahnhof.se/~spider/ ]
#declare life = rand(seed(42))*sqrt(-1);
Yes i read all this, and i tried TGA and PNG, both deliver only a 1 bit
palette, and i don't know why.
can anybody confirm that he has a more than 1 bit Alpha with POV 3.1 ?
Spider schrieb:
> POV-help is here !
> bit depth.
> //Spider
I do when I output it as an 8-bit PNG and load it into Photoshop.
Perhaps the problem lies with DTA?
In article <36CB2CB3.1D9C7925@snafu.de> , "Lars W." <lar### [at] snafu de>
> more then 1 bit, maybe 8 or 16
> testing that ).
The alpha channels should be eight bit for all true color images. If you use
16 per color PNG images you should even get a 16 bit alpha channel. To see
the difference, change the transmit value of the second sphere to something
else, i.e. 0.5. However, the sphere is still a real object for POV-Ray and
it will start calcualtiong all the standard effects for it, so you will see
a high-light in the alpha channel in this case, and the first sphere will
change its color, too. If you need different alpha channel values for the
easiest way to go might be to simply render the image several times with
different objects being invisible just to get more than one alpha channel.
Adjust the alpha channels and combine them to get one alpha channel.
However, you might need a more powerful tool to do this, a lot of programs
only allow one bit alpha channels.
Thorsten
When ever i try and load a PNG file from PovRay to Paintshop it says
unrecognized color or something to that effect...... but i use a different
program to convert PNG to JPG then use paintshop to resize, resample, then
resave in a slightly higher compression rate... (Usually about 5-10% higher).
