POV-Ray : Newsgroups : povray.general : Stats Dos/Win Server Time
7 Nov 2026 00:54:33 EST (-0500)
  Stats Dos/Win (Message 1 to 18 of 18)
Subject: Stats Dos/Win
Date: 31 Jan 1999 17:07:08
Message: <36B4CF02.34F2197A@bahnhof.se>
I've made a little comparsion on my own PC, on a fireworks scene.
Hardware :
P166mmx overclocked to 200Mhz
32Mb EDO
1 Mb Cache.
win95 :
  Litestep as shell, no unnecessary programs run.
  no editor, no menubar, no animation.
Test scene can be posted in .text.scene-files on demand.
Same .pov file and .ini file in both tests.
Scene info :
two infinite spheres
sky_sphere
a HF, 512*334*16
4 lights of diff. colour
a fog.
3207 objects total
Resolution 640 x 480
Antialiasing Off
Radiosity Off
Dos-Stats
Memory : 6 194 964
Parse  : 20.0 seconds
Trace  : 8 minutes   3.0 seconds
Time   : 8 minutes  23.0 seconds
Win-Stats
Memory : 6 191 008
Parse  : 27 seconds
Trace  : 8 minutes   56.0 seconds
Time   : 9 minutes   23.0 seconds
As you can see there is not much difference between the two.
//Spider
Subject: Re: Stats Dos/Win
Date: 31 Jan 1999 17:24:43
Message: <36B4D89E.40B570A3@compuserve.com>
Spider wrote :
> Dos-Stats
> Memory : 6 194 964
> Win-Stats
> Memory : 6 191 008
> Parse  : 27 seconds
"not much" ?  Well, 10% faster is appreciated on longish renderings...
It gives more than 2 hours difference in a not-so-rare-for-me 24 h
render...  Also, the DOS version (if clean DOS boot) gives more
useable memory to POV.  Appreciated by people who have 32 megs or so.
(I got 128 Mb, but still prefer the dos "interface" in most cases).
Cheers,
Fabien.
Date: 31 Jan 1999 18:32:43
Message: <36B4E6FE.84F4CE87@bahnhof.se>
Not much was compared to my first test run.
I had draw vistas on, and there happened to be a a 4 min change in parse
then, because of the caption update bug in the render window. That
difference was far more tahn I had appreciated.
And, I agree with you for finals, but i had still expected windows to
make it slower than this. Oh, came to think of it now, Pov dind't run at
full priority at the time either...
//Spider
Date: 1 Feb 1999 05:26:13
Message: <36b58145.0@news.povray.org>
Spider <spi### [at] bahnhofse> wrote:
: two infinite spheres
  What's an infinite sphere?
main(i){char*_="BdsyFBThhHFBThhHFRz]NFTITQF|DJIFHQhhF";while(i=
*_++)for(;i>1;printf("%s",i-70?i&1?"[]":" ":(i=0,"\n")),i/=2);} /*- Warp. -*/
Date: 1 Feb 1999 05:43:38
Message: <36B58533.288C2A58@pacbell.net>
An infinite sphere is one that your camera is inside of, such
as when you are using a sphere for the sky, and forget to use
the inverse keyword to flip the sphere's surface normal.
Why it is considered an infine sphere, I know not, but it has
puzzled me for years now.
Ken Tyler
tyl### [at] pacbellnet
Date: 1 Feb 1999 07:43:54
Message: <36B5A074.7149C5D6@peak.edu.ee>
Actually, the difference is much less than 10% between DOS and Win,
provided you have enough memory and care to tweak your system settings a
bit. On my machine, skyvase (640x480 AA) took 1:12 (DOS) and 1:14 (Win).
Still, there's no denying Win is a recource hog and a no-no for large
scenes.
Perhaps sb. could give the results on Linux/Unix as a comparison? I am
considering getting Linux; this might be a nice incentive to take the
trouble.
Margus
> Cheers,
> Fabien.
Date: 1 Feb 1999 13:36:07
Message: <36B5016D.363FE8E3@vargol.demon.co.uk>
> Dos-Stats
> Win-Stats
I must try this with the unofficial Linux version
and my own personal unofficial BeOS port :)
Dave, on his linux box...
"I'd prefer the non-smoking lifeboat, please."
Date: 1 Feb 1999 16:33:49
Message: <36B5F9EA.C1CAFD2F@bahnhof.se>
So THAT's why. I thought it was enough to have it hollow.
does the invere give me any other advantages except that the infinite
goes away?
//Spider
Date: 1 Feb 1999 17:21:20
Message: <36B628CA.3A19DC2F@aol.com>
Like they say, that *little* grows when doing long renders.
Btw, I've seen an average 8% difference on this 233MMX 32Meg SDRAM (now
64) but haven't done any DOS renders since).
POVpro, the dos "speed-optimized" version of POV-Ray 3, was usually 20
to 40 percent faster, depending on the scene.
> Hardware :
> 32Mb EDO
> 1 Mb Cache.
> win95 :
> Scene info :
> sky_sphere
> a HF, 512*334*16
> a fog.
> 3207 objects total
> Antialiasing Off
> Radiosity Off
> Dos-Stats
> Memory : 6 194 964
> Win-Stats
> Memory : 6 191 008
> Parse  : 27 seconds
> //Spider
=Bob
Date: 1 Feb 1999 17:52:14
Message: <36B62EFF.E79DC8AC@bahnhof.se>
yeah, but I can't say taht this was fair to windoze.
If I shall make a true compariosn I'll boot with poray as shell, using
no editor and at highest priority.
But then... Perhaps not.
//Spider
Date: 1 Feb 1999 18:34:59
Message: <36B63A01.14B47B49@pacbell.net>
> goes away?
> //Spider
It will flip the direction of the surface normal. I suppose
an example would be if you were using a bumps normal you
would be seeing dents without the inverse.
Ken Tyler
Date: 2 Feb 1999 03:47:34
Message: <36b6bba6.0@news.povray.org>
: So THAT's why. I thought it was enough to have it hollow.
: does the invere give me any other advantages except that the infinite
: goes away?
  I think it's more a conceptual think. I personally prefer to look at objects
from _outside_. Although povray only models surfaces I like to think about
(non-transparent) objects as solid. If I put the camera inside an object then
it conflicts against how I imagine the world since it should be solid but it
isn't. So I personally don't feel comfortable if I put the camera inside
a sphere which should be solid. That's why I always make sky spheres, walls,
etc, which 'inside' part is away from the camera (ie. the camera is outside
the object). That way I'm also always sure that I'm really looking at the
outer surface of the wall so pigments, normals, etc will work as expected.
  This is even more important if I use things like fog. What I think is:
"There is a wall there; a wall is solid material and I'm looking it from
outside; I'm not inside the wall but outside; so the fog will be seen outside
the wall (where I am) but not inside (so if the wall was transparent, there
should not be fog inside there)".
  Many people use walls (ie. planes) the wrong way, ie. with the camera inside
the wall instead of outside and then just define the wall as hollow so that
fog etc will work. This conflicts entirely with my notion of the 3D world I
am modelling. I would feel very uncomfortable at the wrong side of walls...
Date: 2 Feb 1999 11:26:09
Message: <36B725FE.342CE1C7@bahnhof.se>
I won't argue with your view of the world. But my definition of a plane,
that I got from my algebra classes is that it has no 3D definition, it
is 2D, and therefor shouldn't have inside or outside. It took some time
before I oculd understand why and how the thing had it in pov. now I
know(csg and so on.) but before that. Why the HECK does it think I'm
INSIDE it, it HAS no inside, it CAN'T, it's 2D !!! *smile*
Welcome to the world of pov.
As your thoughts of the other things, i'll meditate on it :-)
//Spider
> : goes away?
Date: 3 Feb 1999 20:11:20
Message: <36B8F291.30A5037C@bahnhof.se>
Hmm, i tried the inverse and it din't work.
Any idea why?
<code>
sphere {
  <0,0,0>, 1
  texture {T_Clouds scale 1/2}
  scale 100000
  inverse
sphere {
  <0,0,0>, 1
  texture { T_Clouds scale 1/3.3 }
  rotate x*20
  scale 200000
  inverse
</code>
This still is called 2 infinite. Why ?
//Spider
> Ken Tyler
Date: 4 Feb 1999 02:12:53
Message: <36B94842.3E787520@pacbell.net>
> Any idea why?
<snip>
> //Spider
Pov is still going to consider this an infinte object, any
time your camera is inside a sphere, even with the inverse
word attached.
The gain from doing so is:
One - you won't get a warning that your camera is inside
a non-hollow object and
Two - it will allow you to use interior restricted items, like
fog, without consequence. Essentialy Pov will look at an object
that uses the inverse keyword as an object that has been turned
inside out.
The reason pov calls it an infinite object in all likelyhood
is because one of the developers decided there was a reason
for treating it as infinite and it's now deply embedded in the
program. Even if it's physicaly misleading it may not be
conceptually and really it doesn't matter any way does it ?
Ken Tyler
Date: 4 Feb 1999 07:23:34
Message: <36b99146.0@news.povray.org>
Ken <tyl### [at] pacbellnet> wrote:
: The reason pov calls it an infinite object in all likelyhood
: is because one of the developers decided there was a reason
: for treating it as infinite and it's now deply embedded in the
: program.
  I have an idea of what could this reason possibly be: Since the camera is
inside the sphere, povray has to calculate ray-sphere intersections for
each pixel, just like with ordinary infinite shapes. Perhaps it's faster
to treat it as an infinite surface when you are sure that you really will
need to test it for every pixel (perhaps it has something to do with
vista/light buffers or whatever).
Date: 4 Feb 1999 13:21:37
Message: <36B9E40B.B9E2CF71@bahnhof.se>
> word attached.
Oki, I thought the inverse would kill the infinite :-) Sorry for
misundrerstandings.
Ahh, I used hollow, so... :-)
> inside out.
That might be interestings, once I do media.
Nope, it doesn't matter, but it is an interesting fact to know.
//Spider
Date: 10 Feb 1999 16:52:55
Message: <36C1FFB4.3D3D5C4A@club-internet.fr>
This is only true with "usual" scenes. POVPro is great but uses a lower
precision calculation (to increase speed), but this introduces noise in
the results and makes it more difficult to have AA converge correctly.
With strong AA, it can be far slower than the official version.
François DISPOT
http://www.geocities.com/vienna/7709
_  _  _  _   ______  _____  _____      _____  _____  _
|| ||// //  //   // /___ / /___ /     / ___/ / ___/ //
|| |// //  //   //     //     //     / /__  / /    //__
|| // //  //   //     //     //     / ___/ / /    //|__|
||//|//  //   //     //___  //___  / /__  / /__  // ||
|//|//  //___//     /____/ /____/ /____/ /____/ //  ||
