POV-Ray : Newsgroups : povray.general : Stats Dos/Win Server Time
15 May 2026 15:18:41 EDT (-0400)
  Stats Dos/Win (Message 1 to 10 of 18)
Subject: Stats Dos/Win
Date: 31 Jan 1999 17:07:08
Message: <36B4CF02.34F2197A@bahnhof.se>
I've made a little comparsion on my own PC, on a fireworks scene.
Hardware :
P166mmx overclocked to 200Mhz
32Mb EDO
1 Mb Cache.
win95 :
  Litestep as shell, no unnecessary programs run.
  no editor, no menubar, no animation.
Test scene can be posted in .text.scene-files on demand.
Same .pov file and .ini file in both tests.
Scene info :
two infinite spheres
sky_sphere
a HF, 512*334*16
4 lights of diff. colour
a fog.
3207 objects total
Resolution 640 x 480
Antialiasing Off
Radiosity Off
Dos-Stats
Memory : 6 194 964
Parse  : 20.0 seconds
Trace  : 8 minutes   3.0 seconds
Time   : 8 minutes  23.0 seconds
Win-Stats
Memory : 6 191 008
Parse  : 27 seconds
Trace  : 8 minutes   56.0 seconds
Time   : 9 minutes   23.0 seconds
As you can see there is not much difference between the two.
//Spider
Subject: Re: Stats Dos/Win
Date: 31 Jan 1999 17:24:43
Message: <36B4D89E.40B570A3@compuserve.com>
Spider wrote :
> Dos-Stats
> Memory : 6 194 964
> Win-Stats
> Memory : 6 191 008
> Parse  : 27 seconds
"not much" ?  Well, 10% faster is appreciated on longish renderings...
It gives more than 2 hours difference in a not-so-rare-for-me 24 h
render...  Also, the DOS version (if clean DOS boot) gives more
useable memory to POV.  Appreciated by people who have 32 megs or so.
(I got 128 Mb, but still prefer the dos "interface" in most cases).
Cheers,
Fabien.
Date: 31 Jan 1999 18:32:43
Message: <36B4E6FE.84F4CE87@bahnhof.se>
Not much was compared to my first test run.
I had draw vistas on, and there happened to be a a 4 min change in parse
then, because of the caption update bug in the render window. That
difference was far more tahn I had appreciated.
And, I agree with you for finals, but i had still expected windows to
make it slower than this. Oh, came to think of it now, Pov dind't run at
full priority at the time either...
//Spider
Date: 1 Feb 1999 05:26:13
Message: <36b58145.0@news.povray.org>
Spider <spi### [at] bahnhofse> wrote:
: two infinite spheres
  What's an infinite sphere?
main(i){char*_="BdsyFBThhHFBThhHFRz]NFTITQF|DJIFHQhhF";while(i=
*_++)for(;i>1;printf("%s",i-70?i&1?"[]":" ":(i=0,"\n")),i/=2);} /*- Warp. -*/
Date: 1 Feb 1999 05:43:38
Message: <36B58533.288C2A58@pacbell.net>
An infinite sphere is one that your camera is inside of, such
as when you are using a sphere for the sky, and forget to use
the inverse keyword to flip the sphere's surface normal.
Why it is considered an infine sphere, I know not, but it has
puzzled me for years now.
Ken Tyler
tyl### [at] pacbellnet
Date: 1 Feb 1999 07:43:54
Message: <36B5A074.7149C5D6@peak.edu.ee>
Actually, the difference is much less than 10% between DOS and Win,
provided you have enough memory and care to tweak your system settings a
bit. On my machine, skyvase (640x480 AA) took 1:12 (DOS) and 1:14 (Win).
Still, there's no denying Win is a recource hog and a no-no for large
scenes.
Perhaps sb. could give the results on Linux/Unix as a comparison? I am
considering getting Linux; this might be a nice incentive to take the
trouble.
Margus
> Cheers,
> Fabien.
Date: 1 Feb 1999 13:36:07
Message: <36B5016D.363FE8E3@vargol.demon.co.uk>
> Dos-Stats
> Win-Stats
I must try this with the unofficial Linux version
and my own personal unofficial BeOS port :)
Dave, on his linux box...
"I'd prefer the non-smoking lifeboat, please."
Date: 1 Feb 1999 16:33:49
Message: <36B5F9EA.C1CAFD2F@bahnhof.se>
So THAT's why. I thought it was enough to have it hollow.
does the invere give me any other advantages except that the infinite
goes away?
//Spider
Date: 1 Feb 1999 17:21:20
Message: <36B628CA.3A19DC2F@aol.com>
Like they say, that *little* grows when doing long renders.
Btw, I've seen an average 8% difference on this 233MMX 32Meg SDRAM (now
64) but haven't done any DOS renders since).
POVpro, the dos "speed-optimized" version of POV-Ray 3, was usually 20
to 40 percent faster, depending on the scene.
> Hardware :
> 32Mb EDO
> 1 Mb Cache.
> win95 :
> Scene info :
> sky_sphere
> a HF, 512*334*16
> a fog.
> 3207 objects total
> Antialiasing Off
> Radiosity Off
> Dos-Stats
> Memory : 6 194 964
> Win-Stats
> Memory : 6 191 008
> Parse  : 27 seconds
> //Spider
=Bob
Date: 1 Feb 1999 17:52:14
Message: <36B62EFF.E79DC8AC@bahnhof.se>
yeah, but I can't say taht this was fair to windoze.
If I shall make a true compariosn I'll boot with poray as shell, using
no editor and at highest priority.
But then... Perhaps not.
//Spider
