POV-Ray : Newsgroups : povray.general : HF question Server Time
28 Oct 2026 08:43:49 EDT (-0400)
  HF question (Message 1 to 17 of 17)
Subject: HF question
Date: 24 Jan 1999 03:19:36
Message: <36AAD70E.114F71BA@pacbell.net>
Anybody have an idea how to map a height field to the inside
of a sphere ? Preferably 360 degrees in all directions.
Any chance Colefax's bend.inc could be used in this regard ?
Ken Tyler
tyl### [at] pacbellnet
Subject: Re: HF question
Date: 24 Jan 1999 06:12:18
Message: <36ab0012.0@news.povray.org>
I think one of the better known heightfield tools / toolsets could map a
heightfield to a sphere and export the result as a POV-mesh. Unfortunately I
don't remember which one (I don't even remember the names of all of them,
but hey, *you* are the linkmaster ;-) Maybe it was HF-Lab?
Johannes.
Ken wrote in message <36AAD70E.114F71BA@pacbell.net>...
>Ken Tyler
Date: 24 Jan 1999 06:14:52
Message: <36ab00ac.0@news.povray.org>
inside
You love Leveller, right? :) Wasn't there someone who wrote
a plugin for it to map heightfields to objects? I'm not
sure, but...
Julius
Date: 24 Jan 1999 07:21:40
Message: <36AB1041.B28A8988@flash.net>
I suspect you are thinking of John Beale's application which
does this.
There is also a macro which does the same thing which has been
publically released.
Dan
> Johannes.
http://www.flash.net/~djconnel/
Date: 24 Jan 1999 11:20:38
Message: <36AB485F.5C4B6483@virginia.edu>
Darnit.... yeah...I can do it with my program which I never finished...
It is still a kludge (you need to convert the tgas to oct format first)
but I should be able to patch it to map interiors instead of exteriors
in very little time.  I'll try and get you a exe within 24 hours.
Steve
> Ken Tyler
Date: 24 Jan 1999 12:52:07
Message: <36AB5D40.A3C3721D@pacbell.net>
> inside
> sure, but...
> Julius
Yes Leveller can do spherical and IIRCC cylindrical HF's
in mesh export now. The thing is it does this externaly
and not internaly. I want the mountains or whatever terrain
pointing inward (inverted).
Ken Tyler
Date: 24 Jan 1999 12:55:20
Message: <36AB5E01.5D246F0@pacbell.net>
> Steve
> > Ken Tyler
It there an easy way to convert tga's to .oct ? I'm unfamiliar with
this process.
Ken Tyler
Date: 24 Jan 1999 17:21:25
Message: <36AB9CF1.EB7456B2@virginia.edu>
HF-Lab will do it.  Just load the tga and save as an oct... they are
huge files but I haven't implemented reading tga's yet...
Steve
> > Steve
> > > Ken Tyler
> this process.
> Ken Tyler
Date: 24 Jan 1999 19:44:28
Message: <36ABBE79.91A3D69E@virginia.edu>
Um, if leveller will do it, why don't you invert the height field and
map it to the exterior?  It should end up the same in the end shouldn't
it?
Steve
Date: 24 Jan 1999 20:13:28
Message: <36ABC52F.E22750ED@pacbell.net>
> it?
> Steve
If you invert the HF image that Leveller uses for height elevation
points all that will happen is that it will be a mirror of itself.
The elevations will still be positive and the terrain will still
be extruded outward from the sphere. Nice try.
Ken Tyler
Date: 24 Jan 1999 20:19:27
Message: <36abc69f.0@news.povray.org>
In article <36ABC52F.E22750ED@pacbell.net> , Ken <tyl### [at] pacbellnet>
Well, then scaling (changing the radius) the sphere should do all you need!
     Thorsten
Date: 24 Jan 1999 20:26:08
Message: <36ABC820.7AD1FE39@flash.net>
Huh?
If the sphere is constructed as a mesh, meshes are hollow, and thus
mountains in the univerted image will become mountains on
the sphere interior.
Dan
Date: 24 Jan 1999 21:05:49
Message: <36ABD174.934D5F1F@pacbell.net>
> Huh?
> Dan
Ha !
  I said "If you invert the HF IMAGE that Leveller uses for height
elevation points...".
  What needs to be done for this to work is to invert the HF elevation
data in the HF image itself. I suppose it's possible - just need to
rethink the way one makes positive elevation HF's in the first place.
Ken Tyler
Date: 25 Jan 1999 01:14:29
Message: <36AC0BD4.8AABC2BD@virginia.edu>
> > Huh?
> > Dan
> Ha !
> Ken Tyler
Ken, you are thinking yourself in circles.  Think about it this way.  If
you take white text on a black background and map it around a sphere,
you get text protruding from the outside of the sphere.  If you take
text in black and background white, you get text protruding INTO the
sphere.  Now, granted, the scaling isn't exactly right (you have a
sphere of radius R+1 and the text is at radius R, but it is still
projected on the interior.  That means that the mountains would then be
on the inside.  All I would do to my program would be to subtract the
height value from the sphere's radius instead of add it.  It ends up
being very close to the same.  Now I don't know if you are making a
Dyson's sphere (which I doubt since you dislike making space scenes), or
if you are making a Geode, or what but I doubt that you will have too
much difficulty due to the slight innaccuracy of the inverted image.
Steve
Date: 25 Jan 1999 01:31:53
Message: <36AC0FCE.DBC9599B@pacbell.net>
> > > Huh?
> > > Dan
> > Ha !
> > Ken Tyler
> Steve
Thinking in circles is what's required for this spherical project :)
What you should say and haven't is that instead of inverting the HF
images I can get the results needed by producing a negative of the
original. This will give me the negative values I need to work right.
Thought about that just after my last post. PSP to the rescue.
Actually without giving to much away it's going to be an inside out world.
Well hopefully. Anyway I think I figured away around it without any
further help and thank all who responded. If not I'll just give up
and try something else.
Ken Tyler
Date: 25 Jan 1999 08:12:45
Message: <36AC6EC3.D7C9D89C@imerir.asso.fr>
You said you have the answer but is my idea right ?
You just make:
difference {
    sphere {<>,bigger_radius}
    height_field_sphere // don't know the syntax of it
                David
Date: 25 Jan 1999 12:49:06
Message: <36ACAEA7.F713B7D6@virginia.edu>
The negative of the image is of course what I actually meant... I was
thinking in HF-Lab terms.  You can tell by my last post I think that I
was intending to use the negative.  Sorry for the confusion.
Steve
> > > > Huh?
> > > > Dan
> > > Ha !
> > > Ken Tyler
> > Steve
> Ken Tyler
