POV-Ray : Newsgroups : povray.general : Reflection vectors ? Server Time
28 Oct 2026 09:44:05 EDT (-0400)
  Reflection vectors ? (Message 1 to 19 of 19)
Subject: Reflection vectors ?
Date: 9 Jan 1999 08:53:40
Message: <36975EF9.50AB37AE@pacbell.net>
I was looking at the source for the scene file "Brilliant" and noticed
that the artist used vectors for describing the reflection values of each
facet. This possibility had totaly excaped me until now. What benefit
if any is gained by doing so ?
An example: finish { reflection <0.5,0.75,0.5> }
Ken Tyler
tyl### [at] pacbellnet
Subject: Re: Reflection vectors ?
Date: 9 Jan 1999 11:17:43
Message: <36978051.F186E362@bahnhof.se>
i think it defines how each colour will be reflected...
//Spider
> Ken Tyler
Date: 9 Jan 1999 14:58:03
Message: <3697B563.9F9DC655@erols.com>
It modifies the color of the reflected light.  You could, for instance,
have a silver mirror (neutral tones in the pigment) that reflected a blue
image of the things in view.
John
Date: 9 Jan 1999 15:30:13
Message: <3697BBE0.76BDBFDA@pacbell.net>
Thanks John, Spider.
Ken Tyler
Date: 11 Jan 1999 06:59:14
Message: <3699E791.93643AD1@olicom.dk>
> Ken Tyler
I have used that feature. The vector is a colorvector :) rgb that is.
cu
Bjarne Nygaard
Date: 11 Jan 1999 18:30:16
Message: <369A896C.EEEAF17@aol.com>
Surprised that you, Ken, of all people had failed to notice the
vectorable reflection before now. Though I must admit I did not, and
presume, do not (which comes in handy) know all there is to know.
Cross-threading a bit here, but, I tried to do a mixture of spectral
dispersion and reflection color shifting together to no avail.
Seems that the reflection simply refuses to be averaged as refraction
does. Been puzzled ever since. As others may already know, normals have
a difficult time being layered or averaged too (or so I think) so it
follows that there are probably many such impossible(?) characteristics,
along with a few good pluses which balances things out thank goodness.
> Ken Tyler
=Bob
Date: 11 Jan 1999 18:49:39
Message: <369A8D9A.C7D25ABE@pacbell.net>
> vectorable reflection before now.--
It just goes to show that even for someone who is well versed with
the program there are still things to learn. There are so many variables
in this program I doubt that I will ever learn them all. Can you without
looking right now type every possible pigment pattern type ? I did it
once to test myself about three months ago. I missed only two. One
of which I didn't know exsisted (new for 3.1).
Did you know you can use a negative number for a cone diameter and
end up with two cones kissing at their points ? Try this on for size:
cone{x*-1,1,x*1,-1 pigment{rgb 1}}
Who would ever think of using negative values like this especialy since
it's not documented anywhere ? I found out by way of typo. Wanna
see weird ? Try negative values with superellipsoids.
There are some other unique things you can do that are not documented
because the program has so much flexibility that I imagine even the
programmers don't know all that it can do.
I'm not to blame for not knowing because I'm only human and not some
perfect machine. I know little about media and next to nothing about using
blobs. Who cares ? Theres plenty of other features to keep me busy for
years. Implementing and using nested and recursive while loops will keep
me busy for most of 1999 and then it's time to master macros
Ken Tyler
Date: 12 Jan 1999 07:08:43
Message: <369B3A6F.AD469BC3@bahnhof.se>
Oopa... Skilled as imagined.
Kewl...
Porbably not, but then, programmers in general aren't noteworthy for their great
patience
in documentation.... (I know, I'm one of them.)
We don't blame you... I wonder what would happen the day I stopped learning and
testing in
pov.... Hmm. I maybe will get a scene finished... Yeah, that's it.
//Spider
Date: 12 Jan 1999 13:40:46
Message: <369b972e.0@news.povray.org>
Actually, at least up to now there as little point in using rgb values in
reflection. The following would give exactly the same results:
pigment {rgb 1} finish {reflection <1,0,0>}
pigment {rgb <1,0,0>} finish {reflection 1}
i.e. you can do the same thing with pigments.
Now with the variable reflection patch, I'm not so sure... Must try it out.
Margus
Date: 12 Jan 1999 15:26:07
Message: <369BAFDD.3099@merlin.net.au>
> Margus
Not true, in the first instance the object has a red pigment and in the
second, white.
Try the following
plane{	-z,0
  pigment{White}
  finish{ reflection Red } }
sphere{
  <3,0,-3>,1
  pigment{Blue+Green} }
White plane, no reflection of the sphere because the plane reflects none
of the primaries in the sphere's pigment.
Cheers, PoD.
Date: 12 Jan 1999 16:36:18
Message: <369BC050.B8C57C99@aol.com>
Ken wrote:
> Can you without looking right now type every possible pigment pattern type ?
Certainly not make 100% :) And not all the primitives either.
I did know of this.
Don't try odd values or shapes with sor and lathe, unless you like to
crash pov on purpose ;)
> perfect machine.
> Ken Tyler
This I did not yet know.
=Bob
Date: 12 Jan 1999 21:57:11
Message: <36a40a7d.18407018@news.povray.org>
affirmative
affirmative
Try a spotlight with negative tightness or a falloff larger than the
radius. Try a dark dusty room with a black spotlight illuminaging a
julia fractal which will cast white shadows. Try...
>Ken Tyler
What comes next, Ken, a patch? :)
Peter
Date: 12 Jan 1999 21:59:10
Message: <369C0B82.D685E5BD@pacbell.net>
> >Ken Tyler
> Peter
 Media. Maybe !
Ken Tyler
Date: 25 Jan 1999 03:25:17
Message: <36AC29AD.73DCBDA3@aol.com>
OK, I'll bite...I bet I'll miss some of the new ones:
agate [agate_turb]
bozo
bumps
dents
crackle
granite
marble
wood
hmm...
leopard
spotted (same as bozo?)
hexegon
checker
quilted
spiral1
spiral2
ripples
radial
waves
gradient <x, y, z>
spherical_wave
box_wave
cylinder_wave ?
ramp_wave
Not sure if I got the wave forms confused with patterns types toward the
end there.  How did I do?
-Mike
Ken wrote:
> Can you without
Date: 25 Jan 1999 03:36:10
Message: <36AC2CEE.5F9056E3@pacbell.net>
> agate [agate_turb]
> bozo
> bumps
> dents
> crackle
> granite
> marble
> wood
> hmm...
> leopard
> hexegon
> checker
> quilted
> spiral1
> spiral2
> ripples
> radial
> waves
> gradient <x, y, z>
> spherical_wave
> box_wave
> cylinder_wave ?
> ramp_wave
> -Mike
> Ken wrote:
> > Can you without
  Patterns List:
  Agate      Average    Boxed          Bozo         Brick       Bumps
  Checker    Crackle    Cylindrical    Dents        Gradient    Granite
  Hexagon    Leopard    Mandel         Marble       Onion       Planar
  Quilted    Radial     Ripples        Spherical    Spiral1     Spiral2
  Spotted    Waves      Wood           Wrinkles
You missed wrinkles, onion, brick, mandle, hexagon, average, and ...
Ken Tyler
Date: 25 Jan 1999 04:01:36
Message: <36AC3230.DFBFA5B9@aol.com>
OK, you got me on brick, mandle, wrinkles and onion.  Hexagon was a typo
and average technically isn't a pattern.  Planar, boxed, cylinderical
and spherical don't work anymore, unless they work with the version
directive.
-Mike
Ken wrote:
> > agate [agate_turb]
> > bozo
> > bumps
> > dents
> > crackle
> > granite
> > marble
> > wood
> > hmm...
> > leopard
> > hexegon
> > checker
> > quilted
> > spiral1
> > spiral2
> > ripples
> > radial
> > waves
> > gradient <x, y, z>
> > spherical_wave
> > box_wave
> > cylinder_wave ?
> > ramp_wave
> > -Mike
> > Ken wrote:
> > > Can you without
>   Patterns List:
> Ken Tyler
Date: 25 Jan 1999 04:11:36
Message: <36AC353D.64C3B29E@pacbell.net>
> directive.
> -Mike
   I've got the below list commented out at the top of textures.inc
for easy reference. It's easier than trying to find them all in
the documentation.
   The patterens you mentioned needing the version directive I was
not aware that that was true. They are almost mandatory pattern types
for media if you want it to work correctly. I have tried many of the
original patteren types with media and the results were almost solid
with no scattering characteristics (see my recent post in the images
group - Candle flame - Help) which used radial as a pattern type.
> >   Patterns List:
Ken Tyler
Date: 26 Jan 1999 05:49:09
Message: <36AD9D9A.C3E68D14@aol.com>
Don't forget about triangle_wave, scallop_wave and sine_wave too.
As far as remembering them all in a test, I'll take a pass/fail instead
of letter grade please.
> > directive.
> > -Mike
> the documentation.
> > >   Patterns List:
> Ken Tyler
=Bob
Date: 26 Jan 1999 05:55:57
Message: <36AD9F2F.9275816F@pacbell.net>
They don't count because they are pattern modifiers
and not pattern types.
Ken Tyler
