POV-Ray : Newsgroups : povray.general : Far objects are pruned???!!! Server Time
18 Oct 2026 02:59:01 EDT (-0400)
  Far objects are pruned???!!! (Message 1 to 17 of 17)
Subject: Far objects are pruned???!!!
Date: 27 Dec 1998 15:49:39
Message: <36869D1C.366BFAB@iro.umontreal.ca>
I have this small problem... I have a very large object
that is very far from the center ( <0,0,0>), but it seems
that pov prunes objects that are not inside <+-1000000,
+-1000000,+-1000000>... Is there a way of settings this?
Best,
    S.
Steven Pigeon                     Ph. D. Student.
University of Montreal.
pig### [at] iroumontrealca           Topics: data compression,
pig### [at] jspumontrealca          signal processing,
ste### [at] researchattcom           non stationnary signals
                                  and wavelets.
         http://www.iro.umontreal.ca/~pigeon
Subject: Re: Far objects are pruned???!!!
Date: 27 Dec 1998 16:01:20
Message: <36869FD8.580A407A@iro.umontreal.ca>
> Best,
>     S.
Oh, yeah, I use version 3.1a for windows.
It seems in fact that the bug is much more perverse...
#declare EarthMoonDistance =    469928448; // Earth-Moon distance
#declare EarthRadius       =      6379439.6; // in meters (thus, 1 pov unit =~=
1 m)
#declare MoonRadius        =      3476183; // for now
box
  0, MoonRadius
  translate <0,-EarthRadius,0> + EarthMoonDistance*vnormalize(<0,0.5,1>)
  pigment { Green }
Yields a visible box, but:
sphere
  0, MoonRadius
  pigment { Green }
does not yield a visible sphere... the object doesn't even exist!
suggestions?
Best,
    S.
                                  and wavelets.
Date: 27 Dec 1998 16:36:15
Message: <3686A88F.45376E95@flash.net>
> suggestions?
1. Fix the source.
or....
2. Scale your distances to fit within POV's current bounds.  If your moon is 100x
closer and
   100x smaller, the error in parellax will be well under one pixel.
Dan
Date: 29 Dec 1998 22:30:37
Message: <36899EDF.3678CBC5@mindspring.com>
Due to prescion limitations of Float math, Povray is compiled
by default with the following:
Anything below 0.001 is considered 0.0
Anythung beyond +/- 1e7 is non exsistant
Don't try to be 100% accurate. Povray isn;t a physics real
world modeler. its an Artistic Program. As long as it looks
right to you then its accurate =}
"fixing" the source will give prescion errors.
Dan Connelly wrote:
> > suggestions?
> 1. Fix the source.
> or....
closer and
> Dan
Date: 30 Dec 1998 01:38:30
Message: <3689CAA4.708CC439@flash.net>
POV sets its limits rather conservatively, and in some cases
does calculations in a fashion which make it more susceptible
to precision limits than it needs be.... doing things like taking
squares and squareroots in nonoptimal sequence.
I agree, though -- there often isn't a need to use such large numbers,
as I pointed out.
Dan
Date: 30 Dec 1998 02:37:36
Message: <3689D7DE.3D451C83@iro.umontreal.ca>
Well, pov uses DOUBLEs, and not FLOATs, and the epsilonis 1e-6...
not 1e-3.  I've checked the source.
Besides, I could show you a couple of pictures where a difference
of 0.001 is visible as a thin line.
However, after toying with objects, I've discovered that
the bug is related to spheres and ellipsoids. A cube a couple
of thousand miles wide set at a quarter millon miles is visible
(as a pixel, granted, but still visible). A sphere, 6 k miles wide,
(assuming a pov unit is 1 meter) at 292 000 miles is not visible.
Why?
I have not been able to pinpoint the bug in the source. It
seems OK to me... still, it is not. My guess is that the epsilon
is used in an additive way instead of multiplicative way in
the sphere intersection routine (should be something like
eps * dist rather than just eps).
Best,
     S.
closer and
That's the best fix, but I dont like it
> > Dan
                                  and wavelets.
Date: 30 Dec 1998 14:30:12
Message: <368a7f44.0@news.povray.org>
<snip>
<snip>
Rather than a bug that only effects these shapes, could it not just be that
a sphere's image is less clear than a squares from the same distance?  For
example, looking straight at at, a cube will show up as a solid, pretty much
evenly shaded square.  A sphere will however be more of a brighter point
with dimmer edges around it.  Perhaps, at these distances, it is the less
visible properties of the sphere that makes POV decide there's not enough
light to plot a pixel - unlike the cube, which may just have enough light
from it's apparently brighter side to appear as one.
Just my 2 pence :)
Matt
Date: 30 Dec 1998 18:39:01
Message: <368AB92E.BB92D7FC@iro.umontreal.ca>
Matthew Bennett wrote:
> <snip>
> <snip>
NO, I _did_ check for that. That was my first thought... then I set
the sphere's color to Yellow*2 on a black background... That should have
been enough...
> Just my 2 pence :)
> Matt
                                  and wavelets.
Date: 31 Dec 1998 02:14:00
Message: <368B249E.800ECB51@randolph.spa.edu>
Strangely enough, I can confirm this... I started with a sphere at the origin,
which I expanded appropriately as I moved it further out along the z-axis, and
when numbers got into the millions, it disappeared. A box, slightly further
out, remained visible...
-Mark R.
Date: 1 Jan 1999 04:20:35
Message: <368C934E.1F21D27D@aol.com>
Yep, the scale of things (distance, size) in POV-Ray is not infinite.
Others have brought this up before, one person in particular I can't
recollect since its been a year or more. But I tried my own scale
testing too and apparently the cone primitive is a very sturdy piece of
pov script. The sphere is one of the weakest, it changes size and
disappears altogether rather easily if scaled too large or small. The
box primitive tends to distort quite a bit before suffering the same
fate. This happens regardless of camera being scaled to view objects.
I could put my scale test file at the scene-files.text group if I can
locate it here.
> -Mark R.
=Bob
Date: 1 Jan 1999 12:17:28
Message: <368d00e1.68027359@news.povray.org>
On Wed, 30 Dec 1998 02:35:58 -0500, Steven Pigeon
Check the source again.  EPSILON varies with the platform.  For
example, the Windows source to version 3.1a uses
#define EPSILON 1.0e-5
The default (if not specified in config.h) in frame.h is
#define EPSILON 1.0e-10
Still not 1e-3, I'll admit, but not 1e-6, either.
HOWEVER:
What Matthew said is entirely correct, if the comments in the source
are to be believed.  Note this fragment from frame.h.  Note too that
it's platform-independent:
 * These values determine the minumum and maximum distances
 * that qualify as ray-object intersections.
#define Small_Tolerance 0.001
#define Max_Distance 1.0e7
>Why?
It has been stated before, perhaps in .programming, that the sphere
intersection routine was suboptimal WRT its use of EPSILON.  I'd go
look up the exact discussion, but I'm too lazy. :)
Date: 5 Jan 1999 21:43:53
Message: <3692cde9.0@news.povray.org>
small. The
the same
view objects.
group if I can
>locate it here.
 Yes, the object type matters a lot. I remember some posting
about half a year ago that tried to scale a sphere and a
cylinder down to .... well, almost nothing.
From a certain scale value, the sphere started to shrink
faster than the cylinder.
Julius
Date: 6 Jan 1999 16:09:24
Message: <3693D035.E0CE0EDA@bahnhof.se>
Hmm
I've ben experimenting a bit, and at certain sizes, pov says that a sphere is
infinite...
Why so ? (camera inside the sphere...)
//Spider
> small. The
> the same
> view objects.
> group if I can
> >locate it here.
> Julius
Date: 6 Jan 1999 16:11:51
Message: <3693D126.F933B9C2@pacbell.net>
Spider wrote:
> Hmm
infinite...
> //Spider
Because it's always been that way. They call a plane
an infinite object too but it fits inside my screen
with no problem.
Ken Tyler
tyl### [at] pacbellnet
Date: 6 Jan 1999 19:38:34
Message: <3694013A.174B4067@bahnhof.se>
> with no problem.
Now that isn't the right answer to give *grin*
"because it has always been....." *yuch*
but I see your point, I know it isn't a bug in output, but It got me confused as hell
the
first time, two more planes(infinite) then I had used...
I only wondered why it was done, because of the sizes or something else ???
> Ken Tyler
Date: 10 Jan 1999 15:48:23
Message: <36991279.89AE1B71@NOSPAM.pacbell.net>
Well, I do know the "sky sphere" object is "infinite" in that it remains the same
distance
'away' no matter how much you move stuff around, AND it makes the 'scene' the center
of the
sphere no matter where the cartesian system SAYS the scene is located.
Was unaware that normal spheres did that if you put the camera inside them.... will
have to
experiment.
As for planes, well... they are a finite distance "away" along one axis, but extend
infinitely in the other two.  We could also argue that the x, y, and z 'vectors' are
also
infinite, but being one-dimensional, wouldn't do us much good as objects...
(I think i should pick up that old copy of Euclid and see if I can't render a few of
the
proofs... that should keep me safely in the padded cell for months. :)
> > with no problem.
hell the
> > Ken Tyler
 george erhard
 microsoft certified system engineer
 http://home.pacbell.net/dcnblues
 remove "nospam" from domain when replying
Date: 10 Jan 1999 18:49:53
Message: <36993BC7.DAB2CFB9@bahnhof.se>
distance
of the
have to
> experiment.
also
Well, those are SUPPOSED to be infinite... The sphere was what confused me..
the
Show me the results, please..
//Spider
