POV-Ray : Newsgroups : povray.general : Re: Trying to use an older version... Server Time
10 Sep 2025 21:39:13 EDT (-0400)
  Re: Trying to use an older version... (Message 1 to 3 of 3)
Subject: Re: Trying to use an older version...
Date: 17 Dec 1998 00:08:57
Message: <36789347.7ADE@iserv.net>
The web page said that you should be able to run the old, but the new
version prevents this.  I considered this as a bug.
And the "Use tiny captions" doesn't work.  There's a bug.    :)
I'll re-post in povray.general.  Thanks.
Date: 17 Dec 1998 00:12:23
Message: <36789415.680E@iserv.net>
The POV Home page makes metion that if you want to use some of the
features from 3.02, that you keep it installed.  I installed 3.1a into a
different directory, and now I can't run the older version.  I get a
"cannot find INI directory in expected location" error.  Any
suggestions?
Date: 19 Dec 1998 06:35:42
Message: <367b8f8e.0@news.povray.org>
> I get a "cannot find INI directory in >expected location" error.  Any
>suggestions?
This is due to a registry setting.  With two different POV home directorys,
the program is confused.  You can export one home directory and then you
would select a .reg file before you start each one.
Here is how you do it.  Start regedit through run in Windows.  Go to this
key.
HKEY_LOCAL_MACHINE\Software\POV-Ray\Windows.
Export this branch to a file.  Name the file something like
POV_versionname.reg.
While in that directory modify the home string for your other version.
Export your modified branch to a file.  When you have both exported all you
do is run one or the other reg file, before your start a version of POV-Ray.
You should export your entire registry for a backup in case you mess up.
It's a good idea to keep a backup of your registry if you don't do this as
well.
