POV-Ray : Newsgroups : povray.general : Spiral texture Server Time
28 Oct 2026 10:52:52 EDT (-0400)
  Spiral texture (Message 1 to 19 of 19)
Subject: Spiral texture
Date: 11 Dec 1998 21:16:01
Message: <3671d1e1.0@news.povray.org>
Does anyone know how to make a true spiral texture, like that of a candy
cane. I know you can use grandient x+y to simulate one but that only works
if you have the proper angle. I want to be able to animate it so I need it
to really spiral up the object.
Any help would be appreciated,
Thanks,
Darcy
Subject: Re: Spiral texture
Date: 11 Dec 1998 21:23:16
Message: <3671d394.0@news.povray.org>
How about spiral1 pigment type?  That should do the trick!
Lance.
For the latest MAX plug-ins, images and much more, go to:
The Zone - http://come.to/the.zone
Darcy Johnston wrote in message <3671d1e1.0@news.povray.org>...
>Thanks,
>Darcy
Date: 11 Dec 1998 21:54:08
Message: <3671dad0.0@news.povray.org>
Lance Birch wrote in message <3671d394.0@news.povray.org>...
Ok,  I think this puts me down under dink of the day. :)
I thought I had done a search in the pov manual for Spiral, but obviously, I
must have checked for some other word instead. Sorry about that.
Thank you very much.
Darcy
Date: 12 Dec 1998 05:29:46
Message: <3672459a.0@news.povray.org>
Darcy Johnston <dmj### [at] homecomNOSPAM> wrote:
: Does anyone know how to make a true spiral texture, like that of a candy
: cane. I know you can use grandient x+y to simulate one but that only works
: if you have the proper angle. I want to be able to animate it so I need it
: to really spiral up the object.
  Are you talking about a spiral shape or a helix shape? The spiral
texture is a spiral, not a helix, so it may not help you.
main(i){char*_="BdsyFBThhHFBThhHFRz]NFTITQF|DJIFHQhhF";while(i=
*_++)for(;i>1;printf("%s",i-70?i&1?"[]":" ":(i=0,"\n")),i/=2);} /*- Warp. -*/
Subject: Re: Spiral or helix?
Date: 12 Dec 1998 09:48:36
Message: <36728244.0@news.povray.org>
I understand what the difference between spiral and helix is
for POV, but I was just wondering what (as a language thing)
the difference between a "spiral" and a "helix" is. I always
thought they meant the same thing.
Julius
Date: 12 Dec 1998 11:33:22
Message: <36729ad2.0@news.povray.org>
Nieminen Mika wrote in message <3672459a.0@news.povray.org>...
works
it
I guess I mean a helix shape since I want the texture to spiral up a column.
Like I said, I want something like the stripe on a candy cane. I've been
able to simulate it as I mentioned above, but I'm looking for something that
I can view from all angles.
Date: 12 Dec 1998 11:42:18
Message: <36729cea.0@news.povray.org>
Ok, I went with the spiral1 pattern and I was able to get what I wanted.
Since I was using up = y, I had to rotate the pattern in order to get the
orientation right.
So by using
    pigment {swirl1 4 rotate x*90}
I was able to get the effect I wanted. Now all I need to do now is set the
pigment modifiers to get the right colors in there and scale it properly.
Thanks to everyone,
Darcy
Date: 12 Dec 1998 12:40:09
Message: <3672A9CC.C4336E49@bahnhof.se>
open textures.inc
scroll down
at almost the bottom,. you'll find the texture declared...
Copy that to your source, declare as MySprialThing or something, then change it...
//Spider
> orientation right.
> So by using
> Thanks to everyone,
> Darcy
Date: 14 Dec 1998 05:37:06
Message: <3674ea52.0@news.povray.org>
Julius Klatte <jku### [at] hotmailcom> wrote:
: I understand what the difference between spiral and helix is
: for POV, but I was just wondering what (as a language thing)
: the difference between a "spiral" and a "helix" is. I always
: thought they meant the same thing.
  Maybe I'm wrong, but this is what I have understood:
  AFAIK: A spiral is a line on a 2D plane which can be drawn this way:
start drawing a circle but increase the radius constantly. When you have
made a complete 360 degrees curve, you are a little bit farther away from
the center. Continue drawing and you get a spiral curve.
  A helix is a 3D line instead of 2D like the spiral. You can draw it this
way: start drawing a circle in the xy-plane, but instead of changing the
radius, keep it constant, but increase the z-coordinate, ie. the height.
When you have done a complete 360 degrees curve, you are still at the same
distance from the center axis, but a little bit higher from the plane.
Continue this way and you get a helix curve.
  A galaxy has typically a spiral shape, while a spring has a helix shape.
Date: 14 Dec 1998 07:01:37
Message: <3674FDE8.55CE1423@peak.edu.ee>
Actually, I believe a helix is a spiral, but a spiral is not a helix... Never
mind, though. You are correct.
So how do you call the shape where both the radius and the height increase?
Spiralling helix? Helical spiral? Just curious.
Margus
Date: 14 Dec 1998 12:02:02
Message: <3675448a.0@news.povray.org>
Yes, I thought it was something like that, but I believe one
can also call a 3D helix shape a spiral. Since pov uses
spirals as 2D textures (and hasn't heard from a helix in
it's entire life), maybe I'm wrong.
drawn this way:
When you have
farther away from
can draw it this
changing the
ie. the height.
still at the same
the plane.
a helix shape.
e(i=
Date: 14 Dec 1998 14:42:24
Message: <36756A02.3C48@pacbell.net>
> Thanks,
> Darcy
Since everyone else has suggested the spiral pigment
modifier I thought I would confuse the works now by
suggesting you also take a lood at the radial pigment
modifier.
Ken Tyler
Date: 14 Dec 1998 17:09:48
Message: <36758cac.0@news.povray.org>
Speaking of a Helix, where is a program (that exports to different formats)
that makes DNA type Helixes.
Date: 14 Dec 1998 17:48:08
Message: <36759573.13EF@pacbell.net>
Spiralizer makes some interesting shapes
It might do helixes but I don't remember.
It does do shell shapes, spirals and
has a couple of other useful functions.
It can be downloaded for free at:
http://www.armanisoft.ch/
If you go there also look at their Elephont
text utility. Good stuff !
There is another program I believe called Helixer
but I don't have the URL bookmarked. I think it's
a Mac utility which would explain why it's not been
bookmarked.
There is also an old dos command line utility named
Helix I have on CD I could send you if your interested.
It's fairly simple but it does as the name suggests.
Ken Tyler
Date: 14 Dec 1998 22:49:27
Message: <3675dc47.0@news.povray.org>
Not really.  You've got the spiral bit right, but a spiral doesn't have to
be 2D, it can be a helical spiral (increasing in height, constant radius).
A helix is really the path made by the end point of an unwrapping 2D shape.
Take a square for instance.  Pick the bottom right corner and swing it out
to 180 degrees with the left side, now swing this whole line out to 180
degrees to the top side and continue.  This will create a 2D path of the end
point of the unwrapping 2D shape, in the case of a square, it will look like
the side view of a sea shell.  At least that's what I was taught in graphics
class last month!  I think however that by the dictonary term you're right,
it says "A spiral of coil, such as a corkscrew".  Strange however that it
would use the word spiral in that description, because by the description of
a spiral and judging on the description it gave of a helix, a helix is
really a special type of spiral... Spiral "(1) A continuous curve moving
around a fixed point at a steadily increasing or decreasing distance, as a
watch-spring.  (2) A continuous curve winding round a central axis but
continually changing plane, as in a spiral staircase of the thread of a
screw."
So basically, a helix is a type of spiral.  But I'm open to other
interpretations.  I think what this all comes down to however is that the
original question in the thread was answered by "spiral1".  This produces
the effect needed.
Lance.
Nieminen Mika wrote in message <3674ea52.0@news.povray.org>...
Warp. -*/
Date: 15 Dec 1998 03:18:09
Message: <36761B0C.1E56@pacbell.net>
> bookmarked.
 Correction:
 Helixer is not a Mac utility and will run under
 Windows. I forgot it was installed on my system
 and found the address for you. Look to:
 http://www.evolve.co.uk/helixir/
 Sorry for the misinformation contained in my last response.
 Ken Tyler
Date: 15 Dec 1998 13:30:50
Message: <36739F96.778B261A@bigfoot.com>
> Julius
The first thought that comes is :
-o- a sipral is a figure in a plane where the radius keeps growing as
you change the angle.
-o- a helix is a figure in 3-d space where the radius is constant but
the height changes as you change the angle.
As it is the way I always used these in physics or biology.
But when looking up the dictionnary (British - Collins Cobuild) you
notice the spiral is actually both these meanings as well as other
figurative meanings, and you discover that the word helix is simply
not there !
Cherio,
Al.
ANTI SPAM / ANTI ARROSAGE COMMERCIAL :
Pour me répondre, veuillez enlever le Z de mon adresse.
To answer me, please take out the Z from my address.
Date: 15 Dec 1998 21:50:34
Message: <36771ffa.0@news.povray.org>
Helix is in mine (as I mentioned in an earlier post).  But a helix by CAD
and graphics terms is not 3D.  I can't remember the word for it, perhaps
someone else knows.  What is the word for the point that draws a path?
There is a special term for this, and a helix in the 2D sense is one of
these, where the point is the end of the perimeter of an unwinding 2D shape.
But, once again, a helix can be 3D.
Lance.
Date: 18 Dec 1998 14:08:21
Message: <3679BD0A.A0DADE7B@bigfoot.com>
If I understand the concept right, in 2D it would only produce a circle, thus of
little interest to the 2D world, that would be what one would call a degenerated
helix (mathematical expression, no bad thoughs there).
In 3D it makes , well a helix ...
Again, if I'm not mistaken, I think you call generally these type of functions
developpants, but a helix would be one case of them. But my maths are a thing of
the past, so there are not too reliable.
Cheers,
Al.
