Does anyone know a way to create "rounded off" text?
When I create a text object using a TTF the edges of the letters are sharp
and I would like to create a rounded or smooth edge to the letters. Is
there a command/parameter or some way to do this?
Patrick Dugan
Antialiasing would seem to be the preferred technique. I don't know if
there is a way to do this regionally in POV however.
Jim
Patrick Dugan wrote in message <36533ae4.0@news.povray.org>...
> Patrick Dugan
My recommendation is to check out Elefont. It exports in Moray UDO format
and Pov-Ray INC format. It has many ways of bevelling text.
It's a Win95 application, tho..
check out http://www.armanisoft.ch
Twyst
for pov-ray news, reviews, and tutorials
http://twysted.net
e-mail: twy### [at] twysted net
letters are sharp
letters. Is
There is no built-in function in POV to do something like
this. POV just uses the font in a way like heightfields. If
you really want smooth edges and a font that is not easily
recreated in CSG, maybe you should try to place multiple
versions of the textstring in your scene, scaled in a way
that the edges seem round...
Happy tracing
Julius
I would recommend this too. Elefont meshes will usually render faster than
POV text objects.
-Mike
In article <36533ae4.0@news.povray.org>, "Patrick Dugan"
If you mean beveled text, try the following macro. The code is modified
from some that Michael Lundahl posted to
comp.graphics.rendering.raytracing a few months ago. 'nbr_of_objects' is
actually the 'smoothness' of the beveling; think of it as anti-aliasing.
bevel_text("Courier","I Want My MTV",0.02, 1.0, 10)
//creates beveled text
#macro bevel_text (bevelFont, bevelText, bevel_depth, text_depth,nbr_of_objects)
union {
#local i = 0;
#while (i < 1)
//This is the bevel itself
text {
ttf bevelFont, bevelText, bevel_depth, <bevel_depth,0,0>
matrix < 1, 0, 0,
0, 1, 0,
cos(i*2*pi), sin(i*2*pi), 1,
0, 0, 0 >
//This is what is behind the bevel.
//Set text_depth to 0 if you only want the bevel.
#if (text_depth > 0)
text {
ttf bevelFont, bevelText, text_depth, <bevel_depth,0,0>
translate <cos(i*2*pi)*bevel_depth,
sin(i*2*pi)*bevel_depth,
bevel_depth>
#declare i = i + 1/nbr_of_objects;
jer### [at] hoboes com
http://www.hoboes.com/jerry/ e-mail hel### [at] hoboes com
What Your Children Are Doing: http://www.hoboes.com/html/NetLife/Children/
> Patrick Dugan
Not my invention and not a very fast method but easy to tweak:
use a graphics program like PaintShop to create an image of the text, blur it,
then use that as a heightfield. Use the water level to cut of the background.
Use the same heightfield inversed to give the text a backside.
Not long ago there was an example doing this in the binaries-images group (with
the SGI-logo), but I can't remember by who.
Good luck,
Remco
If what you are talking about is like "beveled" text, go to dejanews and
look for bevel in the POV-Ray newsgroup. There are at least two examples
there, one for POV 3.0 and one for POV 3.1.
Jerry
> Jerry
There better not be any reference to a pov-ray newsgroup
at dejanews. This is a closed server and does not appear
on usenet. If it does someone should report it to the povray
admin team immediatly. Perhaps you mean c.g.r.r. or one of
the other subject groups on this server ?
Ken Tyler
Dejanews accumulated an archive from the period when there
was a USENET leak on the povray news server. This was later
currected, so the Dejanews archive terminates in September.
Dan
> > Jerry
> Ken Tyler
http://www.flash.net/~djconnel/
In article <36646603.31F68562@pacbell.net>, Ken <tyl### [at] pacbell net> wrote:
I meant comp.graphics.rendering.raytracing. Which is not a POV-Ray
newsgroup (although POV-Ray is on topic within it) and I have no idea why
I used that phrase.
Jerry
Ken is getting sloppy in his high output volume.
Of course there are references to news.povray.org in dejanews. A quick check will
reveal
that. They were archived during the leak, which was acknowleged and fixed
by the administrators. But it will take years for that section of the archive to
be purged.
Dan
> I used that phrase.
> Jerry
Say WHAT ? I thought it was a fair and reasonable warning and
also appended the statement saying I thought Jerry had simply
made a mistake in his reference to the newgroup in question.
It appears I have been vendicated since that is indeed what
heppened.
reveal
> be purged.
> Dan
It is because of that snafu that I took the defensive on the
Pov teams behalf.
Getting sloppy my rendered tush !
Ken Tyler
> Pov teams behalf.
Ahh -- you said there should be "no reference" to povray newsgroups....
I did a quick search for text references as follows :
http://www.dejanews.com/dnquery.xp?ST=PS&QRY=text&defaultOp=AND&DBS=1&format=terse&showsort=score&maxhits=25&LNG=ALL&subjects=&groups=povray.*&authors=&fromdate=&todate=
... plenty of matches. It is true there should be no references to recent articles,
but
I still maintain your statement was a bit hasty.
Granted -- you were correct that the original recommendation was a typo. I'm just
being picky because I have too much to do at work and need to get out my frustrations
Dan
I remember clearly that I typed it slowly.
frustrations
Just keep saying to yourself "I am not a machine ! I am not a machine !".
Ken Tyler
