I tried what ... suggested... The texture doesn't move anymore
thanks, but my blob is not textured well ! The result is very
strange (try rendering the scene where I deleted the redundant
texture declaration). The top of the leg is good but the
bottom doesn't look as expected ! I managed to solve the
problem:I made three blobs instead of one. But if someone
could explain me what is wrong with the other method, I will
be very happy (Maybe, I'll do the same error(?) the next time
I will use blobs !)
David.
Matthew Bennett a écrit:
> You problem is the very last texture definition at the end of your pette.inc
> file. It's re-defining a texture that then overrides all the rotated
> textures you declared previously. Simply remove the final texture
> definition found in the last three lines in your file:
> from:
> texture {Text_Patte}
> to:
> Hope that helps :)
> Matt
Download 'us-ascii' (4 KB)
