POV-Ray : Newsgroups : povray.general : ANNOUNCE: Thoroughly Useful Macros! Server Time
26 Mar 2026 20:27:01 EDT (-0400)
  ANNOUNCE: Thoroughly Useful Macros! (Message 1 to 1 of 1)
Subject: ANNOUNCE: Thoroughly Useful Macros!
Date: 22 Oct 1998 21:45:18
Message: <362FDF34.2B460CD9@erols.com>
Thanks to the POV-Ray #macro directive and support for arrays,
operations that formerly had to be done with in-line code, #include files,
or even external programs, can now be done with simple macro calls. I put
several of these functions into an .INC file, which makes them a lot easier
to use.
  The file is available for download at:
http://www.erols.com/vansickl/macs.htm
  This is a bug fix that was uploaded at about 0200 Greenwich Time on
Oct 23, so if you have the older one already, update!
  The thoroughly usefule macros are:
Connect(StartPoint,StartRadius,EndPoint,EndRadius)
- This macro creates a cone object which will smoothly connect two spheres.
RoundedBar(StartCorner,EndCorner,Radius)
- This macro creates a bar with four of its edges rounded.
RoundedBox(StartCorner,EndCorner,Radius)
- This macro creates a box with all of its edges and corners rounded.
AxisRotate(Axis,Angle)
- This macro rotates an object (or texture component) by a given angle
  around an arbitrary axis.
Reorient(StartAxis,EndAxis)
- This macro takes something that lies along a given axis and turns it so
  that it lies along another.
FlipXY
FlipXZ
FlipYZ
- These three items are not macros, but because they are thoroughly useful
  I have included them. They are declared transforms, and do to an object,
  texture, or texture component what the name describes: It flips them
  along two of the axes, leaving the object unchanged along the third axis.
  Many objects in POV-Ray are oriented along the y or z axis by default;
  these transforms will orient them along the other axes as well. FlipYZ
  can also be used to change an object designed in a y-up scene to an
  object that will work fine in a z-up scene, and vice versa.
Transition(Start,End,Swerve,Phase)
- This is a "semi-spline" function, useful mainly for animation work. It
  facilitates moving objects smoothly from one point to another, and allows
  for movement to the side in mid-flight.
SmoothSeed(Array,Sequence)
SmoothRand(Array)
- This pair of macros will yield a random-number that varies smoothly over
  time.
Note:  This file uses the #macro directive, so you'll need version 3.1
for it to work.
Enjoy,
John
"Have the manners not to be hittin' the man until he's your husband, and
entitled to hit back!"
