POV-Ray : Newsgroups : povray.general : How recursive are #macros ? Server Time
22 Mar 2026 02:35:59 EDT (-0400)
  How recursive are #macros ? (Message 1 to 10 of 12)
Subject: How recursive are #macros ?
Date: 15 Sep 1998 16:45:18
Message: <35fec3ce.0@news.povray.org>
As the subject indicates, I am curious just how many levels of recursion can
one do with a 3.1 #macro. I want to play around with the Mandelbrot / Julia
set, but POV crashes at higher iteration settings (50+). Has anyone explored
the depth of the problem and/or have a solution / workaround? Thanks in
advance,
Peter
Subject: Re: How recursive are #macros ?
Date: 15 Sep 1998 17:02:18
Message: <35fec7ca.0@news.povray.org>
>advance,
If macros are implemented in 3.1 in about the same way they are in the
isosurface patch, then the recursion limit on macros is the same as the
recursion limit on include files, so that (# of includes + # of macros)
can't be greater than 10.  Of course, there are significant differences
between the syntax of the two methods, so it's possible that the 3.1
implementation is more flexible.  It's also possible that they increased
the limit on the number of include files, since changing it is just a
matter of changing a single number in tokenize.h and recompiling.
Date: 16 Sep 1998 03:57:50
Message: <qqmbtogr1ci.fsf@goldach.fmi.uni-konstanz.de>
"Peter Popov" <pet### [at] usanet> writes:
> advance,
> Peter
(Since there isn't a Unix version of POV-Ray 3.1b, I can't try it myself.)
Is it possible to nest macro declarations with other declarations and
while-loops? Then you should try to implement the calculation of the
Mandelbrot/Julia set in a non-recursive way.
I hope this helps.
http://www.fmi.uni-konstanz.de/~willhalm
Date: 16 Sep 1998 09:36:50
Message: <35FFAF10.5DB9090E@xs4all.nl>
> recursion can
> Julia
> explored
> in
> advance,
> Peter
I still have to install 3.01 but my guess it is a similar problem as
with recursive programming: you simply use to much memory. I don't know
how this is with POV-macros. With C or Pascal it depends on the amount
of variables you want to pass recursively AND the depth.
Remco
Date: 16 Sep 1998 09:43:43
Message: <35FFB2CD.BF825C02@pacbell.net>
I seem to recall the docs stating you may nest any level of
macros you so desire, the same as you may with while loops.
Of course you can check the docs on this and try to disprove
what I've said here : )
Ken
> advance,
> Peter
Date: 16 Sep 1998 10:49:56
Message: <35ffc204.0@news.povray.org>
If they state this, either they're wrong or the implementation
of while loops has changed in 3.1.  In 3.02, the limit is 200
or so active conditionals, including ifs, ifdefs, and while loops.
Date: 16 Sep 1998 14:05:11
Message: <35ffefc7.0@news.povray.org>
Ken wrote in message <35FFB2CD.BF825C02@pacbell.net>...
>Ken
Docs are one thing and reality is always slightly differerent. It seems to
me #macros have the same problem as max_trace_level which causes crashes at
higher values, however the latter is documented. "The number of known bugs
is limited but not so with unknown ones which are, by definition, infinitely
many" (one of Murphy's laws regarding computers) What I am saying is that I
have read the docs and therefore happily went about doing an animated M set
like the one I posted in binaries.animation, but made of spheres or other
objects. The problem is, as I said, that higher levels of recursive calling
of a #macro calling causes a GPF. There's probably no solution to this
problem, but I found a workaround: I downloaded fractal.inc I found on
Twyst's site and it uses no #macro, so I guess I'll just have to take take a
serious look at the code and do something similar.
Thanks to all for your input.
Peter
P.S. My M-set problem is solved but the original question remains open. How
Date: 16 Sep 1998 14:22:16
Message: <35FFF416.8289C917@pacbell.net>
Peter Popov wrote:
> Peter
  What is the difference between nesting and recursion ?
I just looked at the docs and they state emphaticaly that
nesting macros is a no no.
Ken
Date: 16 Sep 1998 15:20:47
Message: <3600017f.0@news.povray.org>
Ken wrote in message <35FFF416.8289C917@pacbell.net>...
>Ken
//Nesting example:
#macro Marco1 ( center1, r1)
  sphere ( center1, r1 )
  #macro Macro2 ( center2, r1);
    cylinder { center1, center2, r2 }
  #local vector1 = center1 + 5*y;
  Macro2 ( vector1, r1 )
//And here's a recursion example
#macro Macro3 (n)
  #if ( n > 0 )
    #local m=n-1
    Macro3 ( m )
The first is forbidden, the second is allowed. Both are dumb and useless :)
Peter
Date: 23 Sep 1998 13:07:03
Message: <01bde307$ced53f40$8c00a8c0@shindo>
Peter Popov <pet### [at] usanet> wrote in article
<3600017f.0@news.povray.org>...
> >Ken
> //Nesting example:
>   #end
> #end
> #macro Macro3 (n)
>   #if ( n > 0 )
>     #local m=n-1
>     Macro3 ( m )
>   #end
> #end
	Neither are dumb nor useless, granted you can usually achieve the same
effect in a non-recursive or non-nested matter, but there are some
algorithms that are a nightmare to implement non-recursively, and nested
macros would be ideal in situations where you wanted to define a macro that
was only 'in-scope' for the duration of the parent macro.
Scott Hill
Sco### [at] DDLinkscouk
Software Engineer (and all round nice guy)
Author of Pandora's Box
Company homepage : http://www.ddlinks.demon.co.uk
"The best trick the devil ever pulled was convincing people he didn't
exist..."
								- Verbal Kint.
"the Internet is here so we can waste time talking about nothing in
 particular when we should be working" - Marcus Hill.
