POV-Ray : Newsgroups : povray.general : fatal text message stream? Server Time
12 Sep 2025 15:30:53 EDT (-0400)
  fatal text message stream? (Message 1 to 2 of 2)
Subject: fatal text message stream?
Date: 30 Aug 1998 15:43:19
Message: <35e99d47.0@news.povray.org>
 Does the #fatal stream exist ?
Can anybody proove or disproove its existence? It is documented,
but... (1) pov-ray doesn't know it ('undeclared identifier'),
(2) it is not in the list of pov reserved keywords (in the doc)
(3) it is not syntax-highlighted in the wonderfull new povwin
editor.
By the way, did you know that...
\a does not beep
You do not need to type "\\" to get a backslash. "\$", where $
is any character but the formatting ones, produce the backslash.
e.g. #render "Some \Text" actually displays "Some \Text" (\T is
not a formatting character; but \t is a tab).
You do not need "\'" to get a ' : "'" works perfectly
   POV INFO
POV-Ray for Windows
Version 3.1.beta.6.watcom.win32 [Pentium II optimised]
   SYSTEM INFO
MS Windows 95 4.00.950 B
IE 4.0 4.711712.6
Pentium Pro 233MHz
64MB RAM
thank you  thank you  thank you  thank you  thank you  thank you
 THANK YOU FOR MAKING POV-RAY
 IT IS WONDERFULL
   Sincerely,
   Philippe
Subject: Re: fatal text message stream?
Date: 30 Aug 1998 17:11:18
Message: <35E9B1DF.1124EC3E@flash.net>
#error is used to send to the fatal stream.
Dan
http://www.flash.net/~djconnel/
