POV-Ray : Newsgroups : povray.general : Version 3.1 Beta crashes sometimes Server Time
28 Mar 2026 02:02:16 EDT (-0400)
  Version 3.1 Beta crashes sometimes (Message 1 to 4 of 4)
Subject: Version 3.1 Beta crashes sometimes
Date: 21 Jul 1998 12:33:46
Message: <35b4b4da.0@news.povray.org>
I have a Problem with the 3.1 Beta, it sometimes crashes during rendering,
but it is not the fault of the scene, because when i reopened Povray, and
render the same File with the same options there is no crash.
The crash also happend when rendering an Animation, in one of the later
Frames.
I don't have the Problems under Version 3.0.
E-MAIL : spa### [at] snafude ( remove spam. )
Homepage : http://www.snafu.de/~lars.wolter
ICQ-UIN : 4137784
Subject: Re: Version 3.1 Beta crashes sometimes
Date: 21 Jul 1998 13:00:35
Message: <35b4bb23.0@news.povray.org>
>Frames.
I have had this problem, too.  After rendering the same scene about half a
dozen times, PVEngine will crash.  Restart it, and you get another half-dozen
tries before it crashes again.  If a stack traceback, register dump, or other
debugging information would be helpful, I can make it crash again and get the
required information.
Speaking of making POV crash, I can make 3.1b4 crash repeatably when I stop a
render and attempt to clear the message window by right-clicking on the small
part of the message window visible below the editor pane.  The error is:
  Application Error
  Exception EInvalidOperation in module EDITDLL.DLL at 0001403A.
  Control 'Editor1' has no parent window.
If I then press the OK button, it terminates PVEngine.  When I restart
PVEngine, I get an access violation (NT STATUS_ACCESS_VIOLATION, Win95
probably calls it an Exception 0D) at PVENGINE!AUTO+2D6E4.  If I ignore
the error, it fixes itself and goes on.
Since the editor in the beta version isn't the same as the one in the final
version, it probably isn't a problem, but someone should take a look at it
just in case.  For what it's worth, the problem did not exist in 3.02.
Date: 24 Jul 1998 16:38:02
Message: <35b8e29a.0@news.povray.org>
In article <35b4bb23.0@news.povray.org>, ron### [at] rongwmicrocom says...
The DOS version hasn't that problem, so it should be due specifically
to the Win version.
Cheers,
Fabien.
Date: 28 Jul 1998 13:19:37
Message: <35bdfa19.0@news.povray.org>
On 24 Jul 1998 15:38:02 -0500, Fabien Mosen <101### [at] compuservecom> wrote:
>to the Win version.
The DOS version can't have that problem, because it exits after each render.
