POV-Ray : Newsgroups : povray.general : Help needed with texture mapping Server Time
7 Nov 2026 02:56:47 EST (-0500)
  Help needed with texture mapping (Message 1 to 13 of 13)
Subject: Help needed with texture mapping
Date: 10 Jul 1998 07:41:10
Message: <35a5efc6.0@news.povray.org>
Hi!
Can anyone help me to solve the following problem: I know the coordinates of
a cylinder and I want to map a radial y pigment on it. I want to define the
texture at the origin and then translate it. Or define a unit cylinder and
somehow fit it into the coordinates I have.
10x.
pet### [at] usanet
Subject: Re: Help needed with texture mapping
Date: 10 Jul 1998 09:16:29
Message: <35A60621.4087CF56@flash.net>
Peter Popov wrote:
> Hi!
I am afraid I don't understand the question completely, but in
general to place a texture there are two options:
* define the object in texture coordinates, then scale and/or translate
  both.
   example (not debugged) :
   cylinder {
     <0, 0, 0>,
     <1, 1, 1>,
     1
     texture { CylinderTexture }
     // the following transformations apply to the texture
     // and the object:
     scale S       // S : a scalar or vector
     rotate T      // T : a vector
     translate V   // V : a vector
* define the texture, then scale it and/or translate it to match
  the object location.
   cylinder {
     V,              // V:  a vector
     V2,             // V2: a vector
     R               // R : a scalar
       CylinderTexture
       // only :
       #declare H = vlength(V2 - V);
       #declare T = <atan2(...),atan2(.....),...>;  // math LAAEFTR :)
       scale <R, H, R>
       rotate T
       translate V
I am not implying the texture must always be matched to the
object in the manner shown... they are just typical examples.
Dan
http://www.flash.net/~djconnel/
Date: 10 Jul 1998 13:27:51
Message: <357D62D7.5AA9371C@skynet.be>
Peter Popov wrote:
> Hi!
> 10x.
> pet### [at] usanet
"matrix"  is what you need; I'm not familiar enough with it to explain,
but there is a good tutorial about it :
http://www.erols.com/vansickl/matrix.htm
Date: 10 Jul 1998 18:07:58
Message: <35a682ae.0@news.povray.org>
I know I (probably) need the matrix keyword (I'm not *that* new to POV).
Problem is, I am not good in math either. So far I was able to match the
texture to the cylinder, but by shearing it and not rotating it. Thanks for
the URL, though. I'll be surfing in a sec, hope it helps.
--Peter
Fabien Mosen wrote in message <357D62D7.5AA9371C@skynet.be>...
Date: 10 Jul 1998 18:14:11
Message: <35a68423.0@news.povray.org>
Dan Connelly wrote in message <35A60621.4087CF56@flash.net>...
>I am afraid I don't understand the question completely...
I think you got it perfectly right,
>...       #declare T = <atan2(...),atan2(.....),...>;  // math LAAEFTR :)
though I'm having problems with LAAEFTR, being absolutely new (a week or so)
in the 'Net :(  Not being that good in math either, I would guess the ... in
atan2(..) should be replaced with ...?
10x
>Dan
Date: 10 Jul 1998 18:34:15
Message: <35a688d7.0@news.povray.org>
Left As An Exercise For The Reader.  Not really a net thing, more of a math
thing.  And the ...'s are English, not math, for "fill this part in
yourself."
Date: 10 Jul 1998 18:50:01
Message: <35a68c89.0@news.povray.org>
Checked the site, it's great! Suits me just fine. 10x for the info.
Happy tracing.
--Peter
Date: 10 Jul 1998 18:50:04
Message: <35a68c8c.0@news.povray.org>
>yourself."
Facing the threat of flaming someone by repeatedly asking stupid questions,
what scalar values should I enter for the three atan2 fxns? Two months and I
still can't figure it out :(
--Peter
Date: 10 Jul 1998 19:05:11
Message: <35a69017.0@news.povray.org>
On Fri, 10 Jul 1998 07:16:33 -0500, Dan Connelly <djc### [at] flashnet> wrote:
>Peter Popov wrote:
>> Hi!
>   cylinder {
>     V,              // V:  a vector
>     V2,             // V2: a vector
>     R               // R : a scalar
>     texture {
>       CylinderTexture
>       // only :
        #declare DX = V2.x-V.x;
        #declare DY = V2.y-V.y;
        #declare DZ = V2.z-V.z;
        #declare RX = atan2( DZ, DY );
        #declare RZ = atan2( DX, DY );
>       scale <R, H, R>
        rotate RX * x
        rotate RZ * z
>       translate V
I haven't tested this, and I'm not sure it's quite right.  In particular,
the terms inside the atan2 might be different than I have here.  For example,
where I have DY, you might really need -DY.  If it doesn't work, try
different combinations of signs.  I'm also assuming that the axis of your
texture lies along the +Y axis.
Date: 10 Jul 1998 19:17:15
Message: <35a692eb.0@news.povray.org>
>from Ron Parker...
example,
OK, I'll try that tomorrow (today, by local time). I have an exam in eight
hours, so I won't bother you again for at least 24 hours :) Anyway, +Y it
is, and I'll just write a #while to check all combinations at once.
Date: 10 Jul 1998 19:24:47
Message: <35A694A4.3443F0D4@flash.net>
> >Peter Popov wrote:
> >> Hi!
> >   cylinder {
> >     V,              // V:  a vector
> >     V2,             // V2: a vector
> >     R               // R : a scalar
> >     texture {
> >       CylinderTexture
> >       // only :
> >       scale <R, H, R>
>         rotate RX * x
>         rotate RZ * z
> >       translate V
The solution key is to realize you need to set one coordinate in the
first rotation, leaving two to the other leg of the triangle, then
set one of the remaining, leaving the third to the other leg of the
second triangle.
One of 3 possibilities (for x->y->z ordering) (not debugged) :
#declare RX = degrees ( atan2 ( DZ, vlength( <DX, DY, 0> ) ) );
#declare RY = degrees ( atan2 ( DX, DY ) );
rotate <RX, RY, 0>
Dan
Date: 10 Jul 1998 19:51:47
Message: <35A69AF8.423D4CA5@flash.net>
> rotate <RX, RY, 0>
Correction (sorry...) :
#declare RY = degrees ( atan2 ( DX, DZ) );
Date: 11 Jul 1998 11:26:57
Message: <35A6F611.15DF383B@geocities.com>
Perhaps something like the below file will fit your needs; the syntax
(after including the file) is as follows (note that standard brackets
() are used, not {} braces):
   Textured_Cylinder (<Base Point>, <Cap Point>, Radius, texture {...})
or:
   Textured_Disc (<Centre>, <Normal>, Radius, texture {...})
where the texture {...} is aligned as desired along the +y axis.  Other
shapes can be textured using the Fit_Texture_to_Cylinder macro, eg:
   cone {<-5, -4, -2>, 2, <5, 4, 1>, 1 open
      Fit_Texture_to_Cylinder (MyTexture, <-5, -4, -2>, <5, 4, 1>, 2)}
One thing to note - I've had to write out the second atan2 () function
in the first macro in full (it looks as though the fix I sent the
POV-Team got somewhat lost in the translation!), to avoid the irritating
Domain Error crash.
// -- CylTex.inc -----------------------------
#macro Fit_Texture_to_Cylinder (cyltexture, point1, point2, cylradius)
   #local _CT_axis = (point2 - point1) * <1, 1, 1>;
   #if (vlength(_CT_axis) = 0) texture {cyltexture} #else
   #local _CT_rotx = degrees(atan2(vlength(_CT_axis * <1, 0, 1>), _CT_axis.y));
   #if (_CT_axis.x = 0) #if (_CT_axis.z >= 0) #local _CT_roty = 0; #else #local
_CT_roty = 180; #end
      #else #if (_CT_axis.z = 0) #if (_CT_axis.x > 0) #local _CT_roty = 90; #else
#local _CT_roty = -90; #end
         #else #local _CT_roty = degrees(atan2(_CT_axis.x, _CT_axis.z)); #end #end
   texture {cyltexture
      scale <cylradius, vlength(_CT_axis), cylradius>
      rotate <_CT_rotx, _CT_roty, 0>
      translate point1}
#macro Textured_Cylinder (point1, point2, cylradius, cyltexture)
   cylinder {point1, point2, cylradius
      Fit_Texture_to_Cylinder (cyltexture, point1, point2, cylradius)}
#macro Textured_Disc (disccentre, discnormal, discradius, disctexture)
   disc {disccentre, discnormal, discradius
      Fit_Texture_to_Cylinder (disctexture, disccentre, disccentre + discnormal,
discradius)}
// -- End File -----------------------------
