POV-Ray : Newsgroups : povray.general : Suggestion for new object Server Time
28 Oct 2026 21:17:16 EDT (-0400)
  Suggestion for new object (Message 1 to 22 of 22)
Subject: Suggestion for new object
Date: 5 Jul 1998 22:56:14
Message: <35a02ebe.0@news.povray.org>
Sorry for a second post but the last sentence was a bit confusing.
With POV-Ray 3.1 I think it would be possible to incorporate a new object.
Well, here's my two cents on the subject. The current box is probably one of
the most used objects in POV, but it has some drawbacks. The current syntax
only allows boxes with 90 degree corners. But if POV inwoked a new object
that lets the user define all eight corners of the box, it would among other
things help creating #while loops that have flat areas as complex matrix
transformations that are required with the current boxes coule be avoided.
Mikael Gustafsson
mik### [at] nettifi
Subject: Re: Suggestion for new object
Date: 6 Jul 1998 01:18:22
Message: <35A04FFC.DD7838CE@flash.net>
This is pretty trivial with #macro, union, and polygon.
for example (not debugged)
#macro metabox(P0, P1, P2, P3, P4, P5, P6, P7)
  union {
    polygon {5, P0, P1, P2, P3, P0}
    polygon {5, P4, P5, P6, P7, P4}
    polygon {5, P0, P1, P5, P4, P0}
    polygon {5, P1, P2, P6, P5, P1}
    polygon {5, P2, P3, P7, P6, P3}
    polygon {5, P3, P0, P4, P7, P3}
> Mikael Gustafsson
> mik### [at] nettifi
http://www.flash.net/~djconnel/
Date: 6 Jul 1998 17:08:28
Message: <35A12EB5.7BF2@merlin.net.au>
>   union {
> #end
> > Mikael Gustafsson
> > mik### [at] nettifi
But that can't be CSGd.
Date: 6 Jul 1998 19:06:53
Message: <35A1E46B.66EA@netvision.net.il>
> >   union {
> > #end
> > > Mikael Gustafsson
> > > mik### [at] nettifi
You could create the object with an intersection of planes. Then in
could be CSGd.
Guy
Date: 6 Jul 1998 21:19:29
Message: <35a16991.0@news.povray.org>
One could also use  matrix-shearing, but I still think a new object of the
kind described earlier would be cool and at least somewhat useful.
Guy Rauscher wrote in message <35A### [at] netvisionnetil>...
>could be CSGd.
>Guy
Date: 6 Jul 1998 22:28:34
Message: <35A179AE.62A93251@flash.net>
> >   union {
> > #end
You are absolutely correct : soon after firing off my reply in
my usual reckless fashion, I realized I was proposing a shell
and not a solid object... like Bezier patch objects.
Unfortunately, the solid object is harder to define.  First of
all, if the faces are planar, the vertices overspecify the problem,
as there is no guarantee that a plane can be defined which
intersects a given set of four points in 3-d space.
I believe the way to specify the object would need to be via
other parameters.  An example would be 6 normal vectors
from the origin to the planes... 6 points instead of 8.
Alternatively, the object can be specified in terms of 6
of the 8 vertices, such that each face has exactly 3 points
specified (each point shared by 3 planes).
The implementation becomes the intersection of 6 planes, with some
care taken to avoid "sign errors" in the CSG (if the normal
specification is used)... if the object
is constrained to include the origin, this is easy, otherwise
there is some bookkeeping to be done.
Dan
Date: 7 Jul 1998 18:46:52
Message: <35a2974c.0@news.povray.org>
Mikael Gustafsson <mik### [at] nettifi> wrote:
: But if POV inwoked a new object
: that lets the user define all eight corners of the box
  What does this kind of box look like?
metabox
{ <0,0,0>, <1,0,0>, <1,1,0>, <0,1,0>
  <0,0,1>, <1,0,1>, <1,1,1>, <0,1,0.5>
                                                              - Warp. -
Date: 11 Jul 1998 11:27:00
Message: <35A758E2.B905443A@geocities.com>
Perhaps the file below will do what you want; the syntax (after
including the file) is as follows:
   metabox (<Point1>, <Point2>, <Point3>, <Point4>, <Point5>, <Point6>, <Point7>,
<Point8>)
which creates a solid box with the vertices as specified.  Points 1 to
4 should specify one face of the metabox (in either clockwise or anti-
clockwise direction), with points 5 to 8 specifying the opposide side
of the box (specified in the same direction as the first face).
As has been mentioned in other messages, though, it is possible that
the points will specify a box with one or more faces not being flat.  In
this case, the macro will automatically create a metabox with bent faces
to fit all eight vertices.  Alternatively, you can create such metaboxes
directly using the flat_metabox macro:
   flat_metabox (<Point1>, <Point2>, <Point3>, <Point4>, <Point5>, <Point6>, <Point7>,
<Point8>)
or, you can create the boxes with smooth faces (that curve to fit the
vertices) using the smooth_metabox macro:
   smooth_metabox (<Point1>, <Point2>, <Point3>, <Point4>, <Point5>, <Point6>,
<Point7>, <Point8>)
Note that, unlike the solid metabox, the flat_metabox and
smooth_metabox cannot be used in CSG operations (although they can be
clipped).  However, they can be used as media containers, eg:
   object {smooth_metabox (
      <-1, -2, -1>, <1, -1, -1>, <1, -2, 1>, <-1, -1, 1>,
      <0, 2, -1>, <1, 1, 0>, <0, 2, 1>, <-1, 1, 0>)
      hollow
      pigment {rgbf 1}
      interior {media {.....}}
// -- Metabox.inc ----------------------------
#macro flat_metabox (FP1, FP2, FP3, FP4, BP1, BP2, BP3, BP4)
   mesh {
      triangle {FP1, FP2, FP3} triangle {FP1, FP3, FP4}  // Front
      triangle {FP1, BP1, BP2} triangle {FP1, BP2, FP2}  // Top
      triangle {FP1, FP4, BP4} triangle {FP1, BP4, BP1}  // Left
      triangle {BP1, BP4, BP3} triangle {BP1, BP3, BP2}  // Back
      triangle {FP4, FP3, BP3} triangle {FP4, BP3, BP4}  // Bottom
      triangle {FP2, BP2, BP3} triangle {FP2, BP3, FP3}  // Right
#macro metabox (FP1, FP2, FP3, FP4, BP1, BP2, BP3, BP4)
   #local _MB_normal1 = -vcross(FP1 - FP2, FP2 - FP3);
   #if (vdot(_MB_normal1, FP4 - FP1) != 0) #local _MB_warning = "point1, point2,
point3, and point4 are not co-planar" #end
   #local _MB_normal2 = -vcross(FP1 - BP1, BP1 - BP2);
   #if (vdot(_MB_normal2, FP2 - FP1) != 0) #local _MB_warning = "point1, point2,
point5, and point6 are not co-planar" #end
   #local _MB_normal3 = -vcross(FP1 - FP4, FP4 - BP4);
   #if (vdot(_MB_normal3, BP1 - FP1) != 0) #local _MB_warning = "point1, point4,
point5, and point8 are not co-planar" #end
   #local _MB_normal4 = -vcross(BP1 - BP4, BP4 - BP3);
   #if (vdot(_MB_normal4, BP2 - BP1) != 0) #local _MB_warning = "point5, point6,
point7, and point8 are not co-planar" #end
   #local _MB_normal5 = -vcross(FP4 - FP3, FP3 - BP3);
   #if (vdot(_MB_normal5, BP4 - FP4) != 0) #local _MB_warning = "point3, point4,
   #local _MB_normal6 = -vcross(FP2 - BP2, BP2 - BP3);
   #if (vdot(_MB_normal6, FP3 - FP2) != 0) #local _MB_warning = "point2, point3,
point6, and point7 are not co-planar" #end
   #ifdef (_MB_warning)
      #warning concat("metabox: ", _MB_warning, ", flat_metabox created.\r\n")
   #else
      #local _MB_axis = ((BP1 + BP2 + BP3 + BP4) / 4) - ((FP1 + FP2 + FP3 + FP4) / 4);
      #if (vlength(_MB_normal1 - _MB_axis) < vlength(-_MB_normal1 - _MB_axis))
         #local _MB_normaldir = -1;
      #else
         #local _MB_normaldir = 1;
      intersection {
         plane {_MB_normaldir * _MB_normal1, 0 translate FP1}
         plane {_MB_normaldir * _MB_normal2, 0 translate FP1}
         plane {_MB_normaldir * _MB_normal3, 0 translate FP1}
         plane {_MB_normaldir * _MB_normal4, 0 translate BP1}
         plane {_MB_normaldir * _MB_normal5, 0 translate FP4}
         plane {_MB_normaldir * _MB_normal6, 0 translate FP2}
#macro smooth_metabox (FP1, FP2, FP3, FP4, BP1, BP2, BP3, BP4)
   union {
      #local _MB_face = 0; #while (_MB_face < 6)
         #switch (_MB_face)
            #case (0) #local P1 = FP1 * <1, 1, 1>; #local P2 = FP2 * <1, 1, 1>;
               #local P3 = FP3 * <1, 1, 1>; #local P4 = FP4 * <1, 1, 1>; #break
            #case (1) #local P1 = FP1 * <1, 1, 1>; #local P2 = BP1 * <1, 1, 1>;
               #local P3 = BP2 * <1, 1, 1>; #local P4 = FP2 * <1, 1, 1>; #break
            #case (2) #local P1 = FP1 * <1, 1, 1>; #local P2 = FP4 * <1, 1, 1>;
               #local P3 = BP4 * <1, 1, 1>; #local P4 = BP1 * <1, 1, 1>; #break
            #case (3) #local P1 = BP1 * <1, 1, 1>; #local P2 = BP4 * <1, 1, 1>;
               #local P3 = BP3 * <1, 1, 1>; #local P4 = BP2 * <1, 1, 1>; #break
            #case (4) #local P1 = FP4 * <1, 1, 1>; #local P2 = FP3 * <1, 1, 1>;
               #local P3 = BP3 * <1, 1, 1>; #local P4 = BP4 * <1, 1, 1>; #break
            #case (5) #local P1 = FP2 * <1, 1, 1>; #local P2 = BP2 * <1, 1, 1>;
               #local P3 = BP3 * <1, 1, 1>; #local P4 = FP3 * <1, 1, 1>;
         #local PA = (P2 - P1) / 3;
         #local PB = (P4 - P1) / 3;
         #local PC = (P3 - P2) / 3;
         #local PD = (P3 - P4) / 3;
         #local PE = (P1 + PB); #local PF = P2 + PC; #local PG = (PF - PE) / 3;
         #local PH = P4 - PB; #local PI = P3 - PC; #local PJ = (PI - PH) / 3;
      bicubic_patch {type 1 u_steps 2 v_steps 2 flatness .01
         P1,  P1+PA,  P2-PA,  P2,
         PE,  PE+PG,  PF-PG,  PF,
         PH,  PH+PJ,  PI-PJ,  PI,
         P4,  P4+PD,  P3-PD,  P3}
      #local _MB_face = _MB_face + 1; #end
// -- End File --------------------------------
Date: 11 Jul 1998 16:31:04
Message: <35A7BD69.E25D5B72@flash.net>
Nice post!
However, the following test may well yield false warnings due to
floating point rounding problems, I suspect.
I more careful approach might be to normalize the dot product
by the magnitude of the cross product, take the magnitude of
the difference, and compare it against a small positive number,
taking care to avoid singularities.
Dan
Date: 11 Jul 1998 19:13:43
Message: <35a7e397.0@news.povray.org>
Wow, thank you very much. Works great judging on a few quick tests.
Mikael Gustafsson
mik### [at] nettifi
Chris Colefax wrote in message <35A758E2.B905443A@geocities.com>...
<Point7>, <Point8>)
Date: 13 Jul 1998 04:35:32
Message: <35A9B8B7.F51BBA9B@usa.net>
IMHO, it might be both easier (well okay, slightly easier) and more helpful to
add a new object with four corners instead of eight. Yes, we can currently
just take the intersection of some planes, but that's true of the box object
also... Anyway, it would be nice to not have to figure out the vector normals
for the planes for each object. (Chris Colefax's example is slick, but still
looks a bit daunting to me.)
I know it's too late for this to be added to v3.1, but I might as well add it
now to the (steadily increasing) wish-list :)
Date: 13 Jul 1998 08:43:14
Message: <35A9F2DE.1EB177EA@flash.net>
I think, Mark, you mean 6 corners here, as this is the required
number to fully specify the planar-face structure.
Actually, I thought Chris's structure (with the exception of the
possible problem associated with the coplanarity test via
the equality test for functions of floats) was nicely elegent.
The file itself serves as a nice little tutorial on the behavior
of patches, which aren't really well explained in the documentation.
There are only two issues I can see:
1. while 8 points overspecifies a planar face object, it underspecifies
   a generalized smooth face object.   Thus Chris made assumptions
   about the nature of the nonplanar faces.
2. A solid nonplanar-face object could be constructed as well using
   CSG.... I don't volunteer, though :).
Dan
Date: 13 Jul 1998 09:58:59
Message: <35aa0493.0@news.povray.org>
Chris Colefax <cco### [at] geocitiescom> wrote:
:       intersection {
:          plane {_MB_normaldir * _MB_normal1, 0 translate FP1}
:          plane {_MB_normaldir * _MB_normal2, 0 translate FP1}
:          plane {_MB_normaldir * _MB_normal3, 0 translate FP1}
:          plane {_MB_normaldir * _MB_normal4, 0 translate BP1}
:          plane {_MB_normaldir * _MB_normal5, 0 translate FP4}
:          plane {_MB_normaldir * _MB_normal6, 0 translate FP2}
  Wouldn't it be a good idea to bound that object with a bounding box?
  I have understood that povray tests the intersection of the viewing ray
with each one of those planes for each pixel since they are infinite shapes
(well, I don't know if pov3.1 has a better automatic bounding box generation
routine). A bounding box should speed up raytracing.
  I haven't tested this on pov3.1, so I'm sorry if this message is useless.
                                                              - Warp. -
Date: 13 Jul 1998 16:55:03
Message: <35AA6603.80CDBCD1@usa.net>
No, I'm fairly sure I meant (and mean) four; a tetrahedron. I wasn't thinking
of the box so much as a 3D object that's a bit more flexible. The metabox (the
flat one, anyway) could be made from a union (or merge, etc.) of a few
tetrahedrons but there would be many other uses, e.g. most meshes could be
made solid(!) by adding a fourth point (somewhere in the middle of the
mesh--the number of extra points needed would depend on the mesh's shape) to
each triangle and making them tetrahedrons instead.
I guess the prism object would work here too, with some work, but that's still
not as nice as just having the object itself.
just a thought :)
Date: 13 Jul 1998 21:56:27
Message: <35AAACB1.A8FF6B16@flash.net>
Oh -- I apologize!  I read your original post too quickly.
I agree : the tetrahedron is the fundamental building block
of 3-dimensional solids.  It would be a wonderful addition
to the primary object set.
Dan
Date: 14 Jul 1998 18:09:00
Message: <35abc8ec.0@news.povray.org>
Believe it or not, I have been thinking in the same way.
Indeed, assume a tetraeder object, defined by the four corners, that can be
CSG'ed. From this a body with 5 cornerpoints can be defined as the union of
two tetraeders: the first one defined with the first 4 vertices, and the
second one with the first three and the fifth
vertex. This pattern can easily be extended to form objects with 6 7, 8, and
so on corners.
The only difficulty will be the numbering of the vertices, but I am sure
there is some nice mathematical rule for this, and for the obvious case of
the octaeder a macro wrapper can be written.
The advantage is that the space described by the object can be concave (not
possible using a union of planes), and that the object can be of any
complexity.
But, so thinking further, what is the actual reason that a mesh can not be
used for CSG? I assume this is because :
1 - there is no guarantee that a mesh describes a closed surface, so no
'real' inside or outside
2 - there is no guarantee that all triangles are consistently defined with
their corner vertices arranged such that a normal vector defined by the
right hand rule points outward. (or was it the left hand rule?  with POV you
never know).
3 - there is no guarantee that the surface does not intersect itself,
exposing the inside surface to the outside, and having the normals pointing
inward. (hard to tell this in words, but no time to render an image)
But, what if we would allow meshes that are closed, consistently defined,
and not self-intersecting to engage in CSG?
A practical solution would be to add a keyword 'CSG' to the definition of
the mesh, like:
   mesh {
      CSG       // I, user, herewith declare and confirm that the follwing
mesh definition complies with the THREE RULES
#end          // with many thanks to Chris Colefax !!
In adding the CSG keyword the USER would assure that the above conditions
are fulfilled, and POV can just do its work.  If the mesh is not compliant,
the user may end up with errors in his picture, and probably some warnings
or messages from POV. Too bad for him. This approach would minimize the task
of the highly praised and overworked POV team.
An algorithm to check a mesh for the above conditions is not so difficult.
It comes down to checking that:
Condition 1 - a ray fired at the object from far away hits the surface on
what we want to be the outside, typically this can be judged by checking the
sign of the scalar product of the ray vector and the normal. When the object
appears to be 'reversed', the checker may be of use to 'flip' it (i.e.
reverse the two first vertices in each triangle)
Condition 2 - all edges are used exactly two times, in opposite directions,
so in the above example: side FP1, FP2 must have a counterpart FP2,FP1. This
means that there are no free edges, and the edges are used to bound two
triangles defined in the same direction.
Condition 3 - no edge of any triangle passes trough another triangle. This
check is not difficult, but just a load of work,that needs to be done only
once. One more reason to have a separate mesh-checker.
By the way, meshes converted from say Autocad or 3DS files, do they normally
comply with these Rules?
And: a mesh usually renders more quickly than a complex union of solids.
Frans
Date: 14 Jul 1998 18:56:14
Message: <35abd3fe.0@news.povray.org>
On Tue, 14 Jul 1998 23:04:15 +0200, F.VERBAAS <106120,444### [at] COMPUSERVECOM> wrote:
True.
>never know).
I've never understood this rule.  While it can make the job of determining
insideness easier, it's not really necessary.  All you have to do is shoot
a ray in an arbitrary direction and count how many times it intersects the
mesh surface.  If it intersects at a boundary between two or more triangles,
you'll need to shoot another ray, but I believe this condition is easy to
detect, as the intersection queue will contain a duplicated point.
If you don't care about the surface normals, self-intersecting but otherwise
closed meshes have insides.  Yes, even a 3d representation of a Klein bottle
has a well-defined inside.
>the mesh, like:
An even more practical solution is to only use "good" meshes in CSG
operations.  If you get strange results because you gave it a strange mesh,
that's your problem, just as it is now if you use an open cylinder or SOR
in a CSG.  Perhaps a keyword to declare that your normals are all
well-behaved, as in your point 2, would be useful to speed up calculations
for such meshes.
Date: 15 Jul 1998 23:26:58
Message: <35AD650C.201A891A@usa.net>
Here's a rather altered version of Colefax's metabox macro, which I changed to
work create a tetrahedron. I haven't tested it a whole lot and I'm not certain
that the signs in front of the 'vcross' functions are right all the time--I
arrived at this by more trial and error than I would like--but it *seems* to
work. Anyway, the syntax would be
tetrahedron (P1, P2, P3, P4)
and as far as I can tell, the order of the points doesn't matter.
//-----------Tetrahedron Macro
#macro tetrahedron (P1, P2, P3, P4)
	#local _TH_centroid = (P1 + P2 + P3 + P4) / 4;
	#local _TH_normal1 = vcross(P2 - P3, P2 - P4);
	#local _TH_normal2 = -vcross(P1 - P3, P1 - P4);
	#local _TH_normal3 = vcross(P1 - P4, P2 - P4);
	#local _TH_normal4 = -vcross(P1 - P3, P2 - P3);
#if (vdot(_TH_normal1,_TH_centroid) > vdot(_TH_normal1,P2))
	#local _TH_normal1 = 0 - _TH_normal1;
#if (vdot(_TH_normal2,_TH_centroid) > vdot(_TH_normal2,P1))
	#local _TH_normal2 = 0 - _TH_normal2;
#if (vdot(_TH_normal3,_TH_centroid) > vdot(_TH_normal3,P2))
	#local _TH_normal3 = 0 - _TH_normal3;
#if (vdot(_TH_normal4,_TH_centroid) > vdot(_TH_normal4,P2))
	#local _TH_normal4 = 0 - _TH_normal4;
intersection {
  plane {_TH_normal1, 0 translate P2}
  plane {_TH_normal2, 0 translate P1}
  plane {_TH_normal3, 0 translate P1}
  plane {_TH_normal4, 0 translate P1} }
Date: 16 Jul 1998 06:27:18
Message: <35ADC76A.A811AD59@flash.net>
There is an include file devotes completely to tetrahedra
at:
http://quark.vpplus.com/~redbeard/raytrace/POVRay-Util.html
called :
http://quark.vpplus.com/~redbeard/raytrace/utils/pyramid.zip
I haven't tried it, though.... it advertises offering
pyramids in a variety of coordinate specifications.
It is dated 27 Oct 1996, so will need macro conversion
to make it competitive with Mark's version.
Dan
Date: 16 Jul 1998 12:24:24
Message: <35AE1B27.17A81DF0@ecs.soton.ac.uk-NOSPAM>
> Mikael Gustafsson
> mik### [at] nettifi
I've always thought when making 'warped' boxes that if you could define
a plane in terms of three points that lie *on* the plane and one that
lies outside it, it would be a lot easier to use CSG's of six planes or
more to create complex solid shapes. Calculating normals or using
rotations is time-consuming and it makes my brain hurt after a while -
with a 3+1 point plane, you'd just give the locations of three corners
of each side, and another point to indicate which side is the inside and
which is the outside. The eight-point metabox would probably be easier,
but the 3+1 plane would possibly be more versatile. Opinions?
Cheers,
Dylan
Dylan Beattie               dmb### [at] ecssotonacuk-nospam
Electronics & Computer Science, University of Southampton
Date: 16 Jul 1998 15:52:13
Message: <35ae4bdd.0@news.povray.org>
On Thu, 16 Jul 1998 16:24:24 +0100, Dylan Beattie
//   File: plane3.inc
// Author: Ronald L. Parker
//   Date: 16 July 1998
// Requires POV Version 3.1 or newer
// This macro creates a plane that passes through points A, B, and C and
// has a normal such that Outside is outside the plane.  If you know a
// point inside the plane instead, use the inverse keyword in your object
// definition.
// Use of collinear points for A, B, and C will cause a degenerate normal.
// To use this macro, create an object like so:
//   object {plane3(Q1,Q2,Q3,Q4) texture{ ... } }
// If you're not going to specify a texture or other modifiers such as
// inverse or hollow, you may leave off the enclosing object{}.
#macro plane3( A, B, C, Outside )
  #local N=vnormalize(vcross(B-A,C-A));
  #if ( vdot( Outside-A, N ) < 0 )
    #declare N=-N;
  plane { N, vdot(A,N) }
Date: 16 Jul 1998 23:54:53
Message: <35AEBE2B.B9448F52@hal-pc.org>
Dylan:
When I was modeling the new sanctuary that my church built I found a
need to define many walls (planes). I read the blueprints and discovered
that with the many oddly angled planar surfaces it had, I needed to find
a way to give me the planes based on three points. The three points were
based on an arbitrary coordinate system that I defined for the
blueprint. All I needed to do was to specify the three coordinates and
the program spits out the normal and the distance from my origin. I have
included the source code below. It compiles under Borland C++ 5.0, I
believe, and hopefully under anything else. It's just basic C stuff. I
have the .exe if you want it. I hope this is useful to you.
Jon Berndt
--- start ---
#include <stdio.h>
#include <stdlib.h>
#include <math.h>
#include <string.h>
main()
  float pt[3][3];
  float vec[2][3];
  float res[3];
  float len;
  float len2;
  float len2root;
  int i, j;
  start:
  printf("\nEnter x, y, z coords of plane base vector start point: ");
  scanf("%f %f %f",&pt[0][0],&pt[0][1], &pt[0][2]);
  printf("\nEnter x, y, z coords of plane base vector end point: ");
  scanf("%f %f %f", &pt[1][0],&pt[1][1], &pt[1][2]);
  printf("\nEnter x, y, z coords of plane second vector end point: ");
  scanf("%f %f %f",&pt[2][0],&pt[2][1], &pt[2][2]);
  for (j=1;j<3;j++) {
	for (i=0;i<3;i++) {
	  vec[j-1][i] = pt[j][i] - pt[0][i];
  res[0] = vec[0][1]*vec[1][2] - vec[0][2]*vec[1][1];
  res[1] = vec[0][2]*vec[1][0] - vec[0][0]*vec[1][2];
  res[2] = vec[0][0]*vec[1][1] - vec[0][1]*vec[1][0];
  len = res[0]*pt[0][0] + res[1]*pt[0][1] + res[2]*pt[0][2];
  len2 = res[0]*res[0] + res[1]*res[1] + res[2]*res[2];
  len2root = sqrt(len2);
  printf("For a plane with collinear points:\n\n");
  printf("     %7.3f  %7.3f  %7.3f\n", pt[0][0], pt[0][1], pt[0][2]);
  printf("     %7.3f  %7.3f  %7.3f\n", pt[1][0], pt[1][1], pt[1][2]);
  printf("     %7.3f  %7.3f  %7.3f\n\n", pt[2][0], pt[2][1], pt[2][2]);
  printf("The normal is:\n\n");
  printf("     (%7.3f)i + (%7.3f)j + (%7.3f)k\n\n",res[0]/len2root,
                                     res[1]/len2root, res[2]/len2root);
  printf("Distance from origin is: %7.3f\n\n", len/len2root);
  goto start;
--- end ---
Download 'smime.p7s.dat' (3 KB)
