POV-Ray : Newsgroups : povray.general : sphere Server Time
7 Nov 2026 02:16:36 EST (-0500)
  sphere (Message 1 to 15 of 15)
Subject: sphere
Date: 11 Sep 1998 23:06:31
Message: <35F9D5A6.ABA1C6E9@xs4all.nl>
I´m looking for a way to create a sphere, other then the ´sphere-way´.
I would like to build it from small parts like triangles and I know
there has to be a way but I can´t seem to figure it out. I was thinking
about a number of points randomly scattered over the surface and then
make triangles with those.
TIA
Remco de Korte
Subject: Re: sphere
Date: 11 Sep 1998 23:29:09
Message: <35F9DBF4.5F08A5C@pacbell.net>
> TIA
> Remco de Korte
    In a way isn't that what lathes, sors, and prisms do ?
    If that's not a satisfactory approach there is a great little
Dos utility called Geodome that creates shapes of the same
name.
    It offers some user options that allow you to control
the number of nodes, spherical or cylindrical shape, and
direction scaling.
    It's output spits out triangles and optionally cylinders, acting
as cross supports, and Pov spheres as node connection points.
    Geodome might do what you want. If not the triangles are
there and can be moved or removed as needed to get the shape
you want
    If you can't located geodome I think it's on the POV-Ray
ftp server. If not it's a small program which I have on CD
so I could send you a copy.
    I took the time once to hand code a sphere like object with
triangles and I definitely don't recommend others try this.
Ken
Subject: Re: sphere
Date: 12 Sep 1998 06:19:05
Message: <35FA3D53.E901A0FB@xs4all.nl>
> ´sphere-way´.
> thinking
> then
> > TIA
> > Remco de Korte
> name.
> direction scaling.
> you want
> Ken
Thanks, I'll try that.
Remco
Subject: Re: sphere
Date: 12 Sep 1998 18:07:27
Message: <35FAF06B.B75403C6@kosher.erols.com>
You could use my rock making .INC file.  It's at
http://www.erols.com/vansickl/rock.htm
John
Subject: Re: sphere
Date: 12 Sep 1998 18:23:54
Message: <35FAE6C2.B87E4C4D@iro.umontreal.ca>
There are numerous ways to do "spheres" with lots of polygons.The best I can
see is to use a "Buckminster-Fuller"-type polyedron.
You start with an icosaedron (20 faces... you know, d&d 20 sided
dice) then progressively divide the faces into 4 other triangles. You
keep dividing triangles until you've got a satisfying result.
IMHO, there's no real use to that. A sphere is much better repre-
sented when it's a z^2+y^2+X^2=r^2 form; especially if your
only goal is to render a simple sphere.
On the other hand, the buckminsterized sphere provide almost
uniform sampling points on the sphere; you dont have the point
concentration effect you have with polar/spheric coordinates. It
is also ideal for spheric fractals (or "rocks", either John's generator,
http://www.erols.com/vansickl/rock.htm, or my own generator,
http://www.iro.umontreal.ca/~pigeon/pub/PovPage/RockGen/RockGen.html
(with source included)).
I first buckminsterized spheres to do uniform sampling, in the
context of environment mapping (to reduce rendering time).
Then for to fractal planets.
Best,
    S.
Steven Pigeon                     Ph. D. Student.
University of Montreal.
pig### [at] iroumontrealca           Topics: data compression,
pig### [at] jspumontrealca          signal processing,
ste### [at] researchattcom           non stationnary signals
                                  and wavelets.
Subject: Re: sphere
Date: 13 Sep 1998 08:03:50
Message: <35FB3B0F.E99537E7@xs4all.nl>
> ´sphere-way´.
> know
> thinking
> then
> I can
> generator,
> Best,
>     S.
>                                   and wavelets.
I downloaded the program Ken mentioned (Geodome1). There's a really nice
image by the same name at the FTP-site.
I had a look at the program and though it does do what it's supposed to
do it wasn't exactly what I needed (my question was a bit vague). I had
a look at the source though and that brought me to the idea to do
something like you describe here: a recursive function, creating a
sphere with triangles, subdivided by triangles, etc. With this I could
do what I actually intended to: to blow up a sphere into fragments.
You're right that it wouldn't be very smart to use this method if you'd
just need a sphere. Even with smooth-triangles I found that there were
seams all over the object. But if you'd need any 'special effects' (
abump in a sphere) you could consider this (or use a blob).
Remco de Korte
http://www.xs4all.nl/~remcodek
Subject: Re: sphere
Date: 13 Sep 1998 09:30:16
Message: <35FBBABD.F9D5B5E6@flash.net>
For this application, also consider :
http://www.geocities.com/SiliconValley/Lakes/1434/explode.html
a generalized explosion macro by the incredible Chris Colfax
(who accomplishes with include files things for which normal folk
must hack the source....)
Dan
http://www.flash.net/~djconnel/
Subject: Re: sphere
Date: 13 Sep 1998 10:14:03
Message: <35FBC490.FCEDA158@pacbell.net>
> Dan
Can people who sit around designing computer graphic images
using POV-Ray be concidered normal folk ?
Ken
Subject: Re: sphere
Date: 13 Sep 1998 16:24:06
Message: <35FC1C21.738B43C2@iro.umontreal.ca>
> > Dan
> Ken
No, of course not :-) Especially those who have their own
builds and home-made companion programs ...!
Best,
    S.
                                  and wavelets.
Subject: Re: sphere
Date: 14 Sep 1998 02:13:51
Message: <35fca60f.0@news.povray.org>
Ken wrote in message <35FBC490.FCEDA158@pacbell.net>...
>Ken
I hear this question, but more specifically asked than here, about a dozen times every
day. My mother, my father, my brother, all my friends, my girlfriend... Now I hear it
from a fellow POVer. They can't be all wrong, you know. I guess I'll have to admit I'm
"kinda nuts".
Peter
Subject: Re: sphere
Date: 16 Sep 1998 07:14:36
Message: <35ff8f8c.0@news.povray.org>
Same here ;-)
Sad isn't it? ;-)
I'm sitting here (and have been for the last 4 hours) stairing at my
computer, 3DSMAX and Riven boxes, my real-life "Elwood" figurine, several
CD-R and CD-RWs, two massive Escher prints, my scanner and printer, a
decoded Playstation Lara Croft animation from TR-II, an 8-inch high set of
3DSMAX tutorials and manuals (oh the upgrade tromurs!) and a stack of CDs
numbering about 50. (listening to Chroma Key, http://www.chromakey.com)
WHAT AM I DOING WITH MYSELF WHEN THE BEACH, SUN, SAND AND OCEAN IS JUST A 50
METRE WALK AWAY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
And yet, strangely, I fell comforted by my room [SLAP!!!!!!!!] "GET A
GRIP!!!" :-)
Lance.
P.S.  I haven't been able to receive any emails for the last 4-5 days (and I
still can't), so if you've mailed me and I didn't reply, that's why!
For the latest MAX plug-ins, images and much more, go to:
The Zone - http://come.to/the.zone
Subject: Re: sphere
Date: 16 Sep 1998 09:36:39
Message: <35FFAE5D.8F6992F4@xs4all.nl>
Lance Birch wrote:
> Same here ;-)
> Sad isn't it? ;-)
> several
> set of
> CDs
> JUST A 50
> METRE WALK
> GRIP!!!" :-)
> Lance.
Oh, man, I could do with some sunny beach!
I was just of on a holiday which basically came down to a weeks worth of
rain and I must admit I was glad I could return to my digital addiction.
But if you could render me some sunshine I'd be most pleased ;-)
Remco
Subject: Re: sphere
Date: 16 Sep 1998 14:12:27
Message: <35fff17b.0@news.povray.org>
Remco de Korte wrote in message <35FFAE5D.8F6992F4@xs4all.nl>...
>Remco
I went to the seaside this summer with an experiment in my head. I went
there with a group of computer illiterates (i.e. normal ordinary sane
people), I had my guitar and I wanted to see how long could I stand without
my computer. Well, I had to take this for ten horrible sunny days and when I
came back I had filled about fifty pages of POV code in a notebook, I had
grown two more centimeters of beard, and my hands were trembling <G>. The
guys were bored to death with Bill Gates jokes and "you know you've been
raytracing too long if..." stuff and couldn't dig why this nutter had
collected about 500 seashells just to try to write a generalized .inc (I
gave up on that), whatever that is. They all agreed he needed a nice white
room in a quiet place with a lot of trees and nice calm doctors all around
the place. I guess this says it all...
Peter
Subject: Re: sphere
Date: 16 Sep 1998 14:28:11
Message: <35FFF578.C181215E@pacbell.net>
I don't look out the window at the sky anymore because it no longer
looks realistic and "they" won't allow me to change it. Sigh !
Ken
> Peter
Subject: Re: sphere
Date: 16 Sep 1998 17:05:21
Message: <36001A07.70B3B525@dhol.com>
From "Fractals, Chaos, Power Laws" by Manfred Schroeder (1990):
"Color Plate 5 shows a photograph, taken by the author, of a natural
cloud that rivals the realism of computer-generated nebulosities."
Jerry Anning
cle### [at] dholcom
