![](/i/fill.gif) |
Philippe Debar wrote:
> Well, that's not important: file/open CRASH... ? ... drats
> It happens.
> Launch POV - hey the toolbar is grayed-out ?
> file/ope...?? what's this ? I only got file/exit.
> Well - I was warned, so exit, regedit: blast HKEY (...) POV-Edit
> Reload povwin... same: can't open no file.
Was there really need to reinstall PovRay or tinkle with registry? Did
You tried to set option "Use editor"? It's under "Options/Other
settings". Other possibility was to edit main menu of PovRay.
If editor use is disabled, then there is indeed only exit option under
file menu.
Hope this helps, beta 6 is worth of trying (only editor is worth of it).
![](/i/fill.gif) |
