POV-Ray : Newsgroups : povray.general : Planetary Heightfields: Now what? Server Time
31 Mar 2026 08:47:36 EDT (-0400)
  Planetary Heightfields: Now what? (Message 1 to 10 of 20)
Subject: Planetary Heightfields: Now what?
Date: 24 Aug 1998 13:11:13
Message: <35E19EF2.B57448B@istar.ca>
I've found tons of great heightmaps for planets, and moons at
http://bang.lanl.gov/solarsys/eng/homepage.htm
Since I've been playing around with planets lately, I'd love to use some
of these, as heightfields, or bumpmaps for spheres.
Problem: It uses a weird colour scale, that does not convert to
greyscale properly.
Any advice on using these?
(BTW: Look under Mars or Venus for good high res examples)
Simon
http://home.istar.ca/~sdevet
Subject: Re: Planetary Heightfields: Now what?
Date: 24 Aug 1998 17:28:28
Message: <35E1CBD8.B322778A@hotmail.com>
> greyscale properly.
> Simon
  Isn't there some palette included on this great page of yours? If not, you
could ask the creator for it. He should thank you for the advice.
JK
Date: 26 Aug 1998 00:16:41
Message: <35e37e19.0@news.povray.org>
It looks to me like these are not pure height fields, but rather, height
field renderings. If you look closely, you can see shadows around the
features, probably created by embossing the original height field data to
give this 3-D effect. If you try using these as height fields, you'll
probably be disappointed with the results.
Simon de Vet wrote in message <35E### [at] istarca>...
>greyscale properly.
>Simon
Date: 26 Aug 1998 10:43:53
Message: <35E41F6C.80D24035@istar.ca>
Still, they're a lot better than what I have right now.
For the record, what I have right now is absolutely nothing.
See what I mean? I'm not interested in making a topographical globe of Venus
to see door to door, I just want to play around with some heightfields based
on actual places, and these looked the most interesting....
Simon
Date: 26 Aug 1998 12:25:09
Message: <35e428d5.0@news.povray.org>
I should have said that you'd probably be better off using these as texture
maps than as height fields. The only drawback with this method (if this is
suitable for your application) is that since the renderings are embossings
of the flattened planet surface, when you wrap it around a sphere the
surface features shadows are inconsistent with the way the lighting should
follow the curvature of the planet.
However, if by "door to door" you mean that you're developing a VR model,
then texture mapping won't give you the elevation data you're looking for.
Have you tried contacting Calvin J. Hamilton, the site author, to ask him
where the original topo data that he used to make his images can be
acquired?
BTW, here's another site that has some good planetary maps:
http://maps.jpl.nasa.gov/
Hope this helps,
-- Dave
Simon de Vet wrote in message <35E41F6C.80D24035@istar.ca>...
Venus
based
>Simon
Date: 26 Aug 1998 19:09:30
Message: <35E495EC.5B2364BC@istar.ca>
I know.. I already have some image maps of planets, and I've already used them
in scenes.... And they have nicer colours than these :)
> acquired?
Well, by saying "see them door to door" (and that was a typo... I meant 'sell'
*sigh*) I was just baing a bit sarcastic. All I meant was that I didn't need
anything super scientificly accurate here, just something to play around with
that was not just generated at random....
I know. Love ths site! I made some custom planets using their maps, and a lot of
tweaking.
They're at:
http://home.istar.ca/~sdevet/Planet1.jpg
http://home.istar.ca/~sdevet/Planet2.jpg
http://home.istar.ca/~sdevet/Planet3.jpg
If anyone's interested.. just simple, silly little things.... but I like it.
I wanted the heightfields so I could render them with a waterlevel set, to
create realistic continents/oceans for custom planets, instead of relying on
flukes in the images to do the same..... that's all... :)
Subject: bump_maps [Re: Planetary Heightfields: Now what?]
Date: 26 Sep 1998 20:23:55
Message: <360D7843.5C6C8FB1@pacbell.net>
Hi Simon and David,
I noticed your thread on planetary renderings, and I'm
interested in this, too. I have a friends who's writing a
game and he asked me to render some planets for him.
I was looking through _The Science of Fractal Images_ by
Pietgen and Saupe, and In the color plates I saw a cosine-offset
surface generation method used by R.F. Voss. I looked at that
for a while and realized I could code something like that in
Perl and make a pgm output file and use that as a bump_map
on a sphere.
However, when I try to render it, I don't see any bumps
on the sphere. Do you see anything erroneous about this
bump map statement?
#declare PLANET=sphere { <0, 0, 0>, 1
	normal {
		bump_map {
			pgm "surfaces/jbrp.1.pgm"
			bump_size 10.0
			map_type 2
		Gray
		//image_map {
		//	pgm "surfaces/jbrp.0.pgm"
		//	map_type 1
		//	interpolate 2
	scale 6
	translate <0, 4, 0>
If that is correct, could you suggest anyother reason
I might not be able to display bumps on the sphere?
Attached is my surface map. Would you mind taking a look
at it?
Much appreciated
--jed
# Jed Reynolds, mailto:jed### [at] surfsoftcom http://www.surfsoft.com/~jed
# "...I've seen the old geeks talk to the young geeks, and they speak
# the same language. There's no age gap or anything." --Steve Wozniak
Download 'us-ascii' (177 KB)
Subject: Re: bump_maps [Re: Planetary Heightfields: Now what?]
Date: 26 Sep 1998 20:49:26
Message: <360D7DAF.49BA531A@pacbell.net>
From what I see you are making you bump map to
big for the sphere size your using. Try a range between
0 - 1 to start with. Try the following and see if it makes
a difference:
  normal {
    bump_map {
         bump_size 0.5
            map_type 1 }
// scale <0,0,0,> // try adding scaling here
Also I believe the map_type 2 is cylindrical and not spherical.
Check the docs. The image you provided looks like it should
do something even if it's wrong. When I get off line I'll
take a closer look at it and will let you know if I find anything
that wll work for you.
    Please in the future post images like this in one of the
binaries groups. There are several people on this NG that
pay for their internet connection on a time basis and can't
afford to wait for your message to load. One of the Pov Team
members, who frequents this group, points this out regularly.
Ken Tyler
Jed Reynolds wrote:
> Hi Simon and David,
> on a sphere.
> bump map statement?
>         normal {
>                 bump_map {
>                         bump_size 10.0
>                         map_type 2
>         pigment {
>                 Gray
>                 //image_map {
>                 //      map_type 1
>                 //      interpolate 2
>         scale 6
>         translate <0, 4, 0>
> at it?
> Much appreciated
> --jed
Date: 26 Sep 1998 22:05:57
Message: <360D8F65.EAFCBFDC@flash.net>
I had no problem seeing features.... but I suggest
the following changes :
1. The map field is defined from y=0 to y=1.  You want
   y=-1 to y=+1.  Therefore you need to apply a translation
   and a scale.
2. specify a finish.
3. Your filename is different than the one you posted (jbrp.0.pgm).
   This may be an issue.
4. "interpolate 2" should almost always be used with bump maps
   to prevent pixellization artifacts.
Consider the following scene :
   normal {
     bump_map {
       pgm "c:\tmp\jbrp.0.pgm"       // adjust this line
       bump_size 10.0
       map_type 2
       interpolate 2                 // this is important
     translate -0.5 * y
     scale 2 * y
     color rgb 0.5
   finish {
     ambient 0.2 diffuse 0.8 specular 0.25 roughness 0.02
  location -3 * z
  look_at 0
light_source {
  <50, 50, -100>
  color rgb 1
> bump map statement?
>         normal {
>                 bump_map {
>                         bump_size 10.0
>                         map_type 2
>         pigment {
>                 Gray
>                 //image_map {
>                 //      map_type 1
>                 //      interpolate 2
>         scale 6
>         translate <0, 4, 0>
http://www.flash.net/~djconnel/
Date: 27 Sep 1998 00:43:59
Message: <360DB4AC.F5E6859B@pacbell.net>
I took the liberty of playing around with it for a while
and I think you will like what I have come up with.
Anyway take a look and see what you think.
I used the bump map image as an image map to add
highlighting. The filtered white layer on top was needed
becasue the pgm file had too many dark areas to get
much surface definition (try removing it and you'll see
what I mean). The filtering lets the underlying surface
show through and really adds to the appearance of depth.
I still don't know if this is what you wanted the final image
to look like but it's definately interesting looking.
camera{location z*-3 look_at 0}
light_source{<0,30,-3>rgb 1}
sphere{<0,0,0>,1
  normal{
   bump_map{pgm "surfaces/jbrp.1.pgm"
    bump_size 50 map_type 1 interpolate 2}
      translate -.5 scale 1}
pigment{
 image_map{pgm "surfaces/jbrp.1.pgm"
pigment{rgb 1 filter .8}
 finish{ambient .3 diffuse 1}
Ken Tyler
Jed Reynolds wrote:
> Hi Simon and David,
> on a sphere.
> bump map statement?
>         normal {
>                 bump_map {
>                         bump_size 10.0
>                         map_type 2
>         pigment {
>                 Gray
>                 //image_map {
>                 //      map_type 1
>                 //      interpolate 2
>         scale 6
>         translate <0, 4, 0>
> at it?
> Much appreciated
> --jed
>    jbrp.0.pgm       Type: PGM Image (image/x-portable-graymap)
>                 Encoding: 7bit
