POV-Ray : Newsgroups : povray.general : Stacking Balls Server Time
7 Nov 2026 02:34:41 EST (-0500)
  Stacking Balls (Message 1 to 15 of 15)
Subject: Stacking Balls
Date: 22 Aug 1998 02:48:34
Message: <35DE59F3.19A5CF68@geocities.com>
I've noticed a number of cool looking images rendered in POVRay that
involve balls/marbles/whatever stacket to look like a random pile (most
notably the image that's on the POVRay 3.02 splash screen). Each of
these images looks like the objects do not intersect but just touch. How
is this usually done? Should I do the math (seems complicated) or is the
only way to just guess and test-render? Maybe someone has a script?
Maybe I am missing the obvious and should just read the docs again?
Any help would be appreciated.
Chris Maryan
mailto:cma### [at] geocitiescom
My ideas are free,
Work is at least minimum wage.
Email me if you are interested in donating
to the Chris Maryan needs money fund.
Subject: Re: Stacking Balls
Date: 22 Aug 1998 03:31:40
Message: <35DE5764.4CCFA44A@pacbell.net>
> Chris Maryan
> My ideas are free,
  Please Add me to this list.
  Take a look at the while loop function described in the docs.
It's certainly not the only method but can save a lot of typing
and rendering time. There are also modelers that have a copy
and translate function. One that has this function is PovCad.
You can choose say a sphere for example and then choose the
copy and translate function. A window will pop up asking the
distance to translate, which direction, and the number of copies
desired. It's a pretty handy tool.
Here is an example of a while loop.
camera{location<0,0,-20>look_at 0}
light_source{<0,0,-100>rgb 1}
#declare Count = 0
#while  ( Count < 10 )
sphere{<0,0,0>,1 pigment{rgb 1} translate<-9+Count*2, 0, 0>}
#declare Count = Count+1
This will place ten spheres 5 left and 5 right centered on the screen.
Each touching but not over lapping each other. This also a great
function to accurately crate and rotate a large number of objects.
It certainly bears playing around with for a while to see what it
can do for you.
Happy rendering !
K.Tyler
Date: 24 Aug 1998 00:42:19
Message: <35E0E118.168F@lawson.appcomp.utas.edu.au>
if you create two spheres
sphere
	<0,0,0>, 1
sphere
	<0,0,2>, 1
	rotate whatever
then whatever the vector whatever is, the two spheres will always be
touching exactly. Obvoiusly it gets a bit harder when you try to put
more spheres.
Obviously this is just a partial solution and I don't really know what
I'm talking about. Oh well
Doug Partridge
Date: 24 Aug 1998 07:57:45
Message: <35e1472b.1055533@news.povray.org>
I think it's a big big problem with more spheres than 2. I wanted to
fill a transparent cylinder with lot of spheres randomly in POV-Ray -
but I gave up... ;-)
I think, one have to simulate each sphere falling from the sky on top
of the other spheres, which have to do a lot with physics. So it
probably can't be done with the script language of POV-Ray.
Bye,
Friedemann
Friedemann Schmidt
Fri### [at] Stonescom
Raytracing-Gallery: http://www.rz.fhtw-berlin.de/~s0049669/
Date: 24 Aug 1998 11:56:22
Message: <35E17EDC.FCDF8CCD@ragingbull.com>
With the array available, it may be possible.... The key is that you
have to store the sphere values and (radius and location) and check your
new sphere against those.  It would be time consuming... Otherwise, I
guess you could would with the distance formula and make each sphere
radius half the distance.  My suggestion would be to do it in a modeller
or by some systemating method that looks random.
Steve
Friedemann Schmidt wrote:
> Hi,
> Bye,
> Friedemann
> Friedemann Schmidt
Date: 24 Aug 1998 12:08:36
Message: <35E1558E.C0918AC9@xs4all.nl>
> Hi,
> Bye,
> Friedemann
> Friedemann Schmidt
If you have two spheres, and add a third touching the other two, you
have a triangle with 60° corners. This way you can easily fill a plan
with balls, simply by translating and rotating.
If you want to stack the balls, add a fourth to the first tree, just
touching. Again, this ball is merely translated and rotated. It
shouldn't be that hard to figure out. Obviously some bright minds (like
K. Tyler) have already figured it out, even with spheres of different
sizes.
Remco de Korte
http://www.xs4all.nl/~remcodek/
Date: 24 Aug 1998 13:32:30
Message: <35E1873B.C085A853@pacbell.net>
> Hi,
> Bye,
> Friedemann
> Friedemann Schmidt
  I once asked if anybody had developed a routine for object collision
avoidance which I believe is what you will need to fill a cylinder or
any other shape without them overlapping. Dan Connely replied that
he had seen one recently but I can't remember where the posted reply
is located at. Dan if your out there could you fill in the blanks.
K.Tyler
Date: 24 Aug 1998 15:46:21
Message: <35e1b4f5.29165353@news.povray.org>
I just wrote a little macro which fills a cylinder with spheres
randomly without overlapping. The problems are, that it takes a long
time to render for many spheres in a small cylinder and that the
spheres doesn't contact each other. So it can only be used to fill a
shape in space without gravitation ;-)
The parameter variables are:
  SeedNr: value for initializing the random stream
  CylRadius: Radius of the cylinder
  CylHeight: Height of the cylinder
  Count: The number of spheres to create
  MinSize: Minimum size of a sphere
  MaxSize: Maximum size of a sphere
  MaxLoops: After this number of loops the macro will be interrupted
if no new position for a sphere can be found.
The cylinder is based on the X-Z-floor.
Example:  FillCylinder(1, 1, 2, 500, 0.1, 0.1, 100)
(It took 50 seconds on my computer by parsing...)
A macro for filling a sphere or a box could be written easily by the
same way.
By the way, the macro can also be used by
union {
  rotate...
  translate ...
#macro FillCylinder(SeedNr, CylRadius, CylHeight, Count, MinSize,
MaxSize, MaxLoops)
  #local Seed = seed(SeedNr);
  #local Pos = array[Count]
  #local Size = array[Count]
  #local i = 0;
  #local Loops = 0;
  #while (i < Count & Loops < MaxLoops)
    #local Size[i] = rand(Seed)*(MaxSize-MinSize)+MinSize;
    #local Break = false;
    #while (Break = false)
      #local X = rand(Seed)*(CylRadius-Size[i])*2-(CylRadius-Size[i]);
      #local Z = rand(Seed)*(CylRadius-Size[i])*2-(CylRadius-Size[i]);
      #if (vlength(<X, 0, Z>) <= CylRadius-Size[i])
        #local Break = true;
    #local Y = rand(Seed)*(CylHeight-2*Size[i])+Size[i];
    #local Pos[i] = <X, Y, Z>;
    #local ShowIt = true;
    #local j = 0;
    #while (j < i & ShowIt = true)
      #if (vlength(Pos[j]-Pos[i])-Size[j]-Size[i] < 0)
        #local ShowIt = false;
      #local j = j + 1;
    #if (ShowIt = true)
      #debug concat("Sphere ", str(i+1, 0, 0), "\n")
      sphere {
        Pos[i], Size[i]
        pigment { color rgb <1, 0, 0> }
      #local i = i + 1;
      #local Loops = 0;
    #else
      #local Loops = Loops + 1;
  #if (Loops > 0)
    #debug concat(">>> Break after ", str(Loops, 0, 0), " loops!\n")
Bye,
Friedemann
Friedemann Schmidt
Date: 24 Aug 1998 15:46:30
Message: <35e1b50f.29191907@news.povray.org>
the problem is, that this won't fill a shape randomly. It looks very
regular, doesn't it?
Bye,
Friedemann
Friedemann Schmidt
Date: 24 Aug 1998 18:33:47
Message: <35E1DD33.271759D5@xs4all.nl>
> Hi,
> Bye,
> Friedemann
> Friedemann Schmidt
Yep, like if you filled a tube with identical sized marbles they would
fall neatly in a pattern if it weren't for the tube. I never tried
stacking marbles on an open surface, I think it would be very hard, and
then I guess you could also forget about the randomness. I might be
mistaken but I think that randomness in a stack of marbles (of the same
size) is not very realistic.
Remco de Korte
'the iceman cometh' as K. Tyler once said ;-) at
http:www.xs4all.nl/~remcodek/
Date: 24 Aug 1998 20:41:40
Message: <35E1FA2D.C257F9F2@flash.net>
K. Tyler wrot
Nathan O'Brien's "Nature" entry in the IRTC:
http://www.irtc.org/ftp/pub/stills/1998-06-30/13nature.zip
BTW, this problem is non-trivial, as it will likely not be
the case that an integral number of unit cells in the
hexagonal-close-packed latticed formed by the balls will
fully fill the container.  Thus the ball positions will not
be fully constrained, and some balls may end up wedged
into nonequilibrium positions... Modeling the formation of
these stacking faults would make an interesting project.
Consider, for example, placing the balls in a spherical "bowl".
The first marble "plane" won't be planar at all, but will conform
to the bottom of the bowl.  This will make the formation of
a well-behaved lattice impossible.
Dan
http://www.flash.net/~djconnel/
Date: 25 Aug 1998 09:37:56
Message: <35e2b024.0@news.povray.org>
You're talking about SUDS right?  What you do is this:
Create an array which holds position values and radii for the spheres (one
entry for each sphere).  Then as you create each new sphere test it against
all previously created spheres to make sure it doesn't touch.  If it doesn't
touch add it, if it does, discard it and try another one.
In Psuedo-Code:
for noofspheres = 0 to 1000
NextRandomSphere:
x1 = rand * 100
y1 = rand * 100
z1 = rand * 100
rad1 = rand * 3
passed = 0
    for csphere = 0 to upperbound of sphereset
        x2 = sphereset(csphere).x
        y2 = sphereset(csphere).y
        z2 = sphereset(csphere).z
        rad2 = sphereset(csphere).r
        d = sqrt((x2-x1)^2+(y2-y1)^2+(z2-z1)^2)
        if d > rad1+rad2 then
            passed = passed + 1
        endif
    next csphere
if passed = 0 then
    redimension sphereset (upperbound of sphereset + 1) preserve
    sphereset(upperbound of sphereset).x = x1
    sphereset(upperbound of sphereset).y = y1
    sphereset(upperbound of sphereset).z = z1
    sphereset(upperbound of sphereset).r = rad1
else
    go back to NextRandomSphere
endif
next noofspheres
This will create an array of 1000 positions and radii of spheres that are
not neccessarily tangential (or though I'm sure you could do that easily
enough, i.e. modify the creation of the xyz and radius to be tangential to a
randomly selected sphere from the array) but don't touch.
Should work, haven't tested it though.  I did this once with candles of
different heights and radii to create a 'floor' full of lit candles.  Looked
really cool, took AGES to render.  Have fun.
Lance Birch
http://come.to/the.zone
Remove the smiley to e-mail.
Date: 25 Aug 1998 10:13:48
Message: <35e2b884.14578999@news.povray.org>
My above posted macro should do exatly this job to fill a cylinder.
BTW, what does your code do if there's no place for a new sphere? It
hangs up, doesn't it? ;-)
Bye,
Friedemann
Friedemann Schmidt
Date: 26 Aug 1998 02:44:32
Message: <35e3a0c0.0@news.povray.org>
No, it loops back and trys a new position and a new size.  As you can see,
it *eventually* will create 1000 spheres.  I think with a grouping area of
that size (100x100x100) and a max radius of 3 it should be able to create
1000 sphere (actually, not should, will).
Lance Birch
Date: 7 Oct 1998 00:26:45
Message: <361AB539.2B7E@spamBgone.nbnet.nb.ca>
> only way to just guess and test-render?   [... snip]
One place to look for something like this might be Benoit B.
Mandelbrot's
(yes - _the_ Mandelbrot) book "The Fractal Geometry of Nature", chapter
18,
where, among other things, he discusses "Apollonian packing". This is a
situation where you fill a space with the largest circle that can fit in
some space (say, a triangle) and continue filling the remaining smaller
spaces with the largest circles possible, which are, of course, smaller
and smaller with each iteration. Ideally, with an infinite number of
circles,
the space is completely filled (in the fractal sense) with circles
It doesn't have anything in the way of an actual algorithm, but it might
provide a few keywords to search for in other sources.
That book is published by W. H. Freeman and Company, New York, NY, USA.
The ISBN is 0-7176-1186-9
It's a fascinating read, even if it doesn't directly help you out with
the
spherical packing problem.
-jr-
* Delete "spamBgone." to get my real address *
