POV-Ray : Newsgroups : povray.general : Area_lights and light fading? Server Time
12 Sep 2025 17:39:47 EDT (-0400)
  Area_lights and light fading? (Message 1 to 2 of 2)
Subject: Area_lights and light fading?
Date: 18 Aug 1998 21:18:15
Message: <35DA1911.111A@peak.edu.ee>
Hi.
This problem may have been addressed before...
Anyway, I have discovered a quirky thing I haven't noticed before about
area lights in POV.
It seems when using liht fading, the brightest spot, from where the
attenuation starts is the center of the area_light, i.e. the
illumination is not distributed evenly across the surface of the
area_light source.
This is especially anoying when using higly elongated light sources like
neon tubes with light fading - there is a bright spot of liht at the
nearby wall around the center of the tube, which does not look very
realistic.
I have included an example scene which demonstrates this well (uncomment
the media if U got the time):
/BEGIN SCENE/
camera {location <7,0,-10> look_at <0,0,0>}
light_source {<0,0,0> rgb <1,1,1>
             area_light y*5, x, 5, 2 adaptive 1 jitter
             fade_distance 2 fade_power 2}
//media {scattering {1 rgb .1}}
plane {z, 1 pigment {rgb .8} finish {ambient .2 diffuse .6} hollow}
polygon {4, <-.5, -2.5, 0>, <.5, -2.5, 0>, <.5, 2.5, 0>, <-.5, 2.5, 0>
         pigment {rgb 1} finish {ambient 1 diffuse 0} no_shadow}
/END SCENE/
Is this inherent in the way POV simulates area lights?
Is there a workaround for this problem?
Thanks.
Subject: Re: Area_lights and light fading?
Date: 18 Aug 1998 23:20:32
Message: <35da3670.0@news.povray.org>
Heh heh just what I was going to ask last night at 1:00 a.m. ( but I
postponed it until 5 a.m. since I went to sleep and I use a free i-net
account from 4 a.m. to 8 a.m. :-(
Seriously, I wanted to place several neon bulbs on the left wall of a tunnel
I am making. Did not work with area lights. Here's a workaround of the
problem (no adaptive 0 of course). Fix to suit your needs (use as an
area_light, spherical_light, my_girlfrend_shaped_light etc.)
Hope this helps.
--Peter
pet### [at] usanet
#declare Lamps=5
#declare Bulbs=5
#while (dummy<Lamps)
  #declare dummy1 = -div(Bulbs,2)
  #while (dummy1<=div(Bulbs,2))
    light_source
    { <-4.25,4.5,dummy*15+dummy1*3/Bulbs> color Gray50/Bulbs
      fade_distance 4
      fade_power 2.25 // not what you'll see in real life, but who cares?
    #declare dummy1=dummy1+1
  #declare dummy=dummy+1
Margus Ramst wrote in message <35D### [at] peakeduee>...
>Hi.
>area lights in POV.
>area_light source.
>realistic.
>/BEGIN SCENE/
>/END SCENE/
>Thanks.
