POV-Ray : Newsgroups : povray.general : weird artifacts Server Time
27 Mar 2026 23:50:38 EDT (-0400)
  weird artifacts (Message 1 to 3 of 3)
Subject: weird artifacts
Date: 4 Aug 1998 22:11:20
Message: <35C7A21D.49ECB02B@biomed.med.yale.edu>
This program has probably been discussed before but I haven't
found any information on it. The basic problem is that when I have an
object with both a normal applied and reflection turned on I get
strange, ugly artifacts. Well, I'll include the source so you can see
for yourself. I'm using v3.02 for Win 95.
#declare theta=2*pi*clock
camera{
 location 3
 look_at 0
light_source{
 <5*sin(theta),5,5*cos(theta)>
 color White
 spotlight
 radius 15
 falloff 70
 tightness 50
 point_at 0
sphere{
 0,1
 texture{
  pigment{color Yellow}
  finish{
   reflection 1
   specular.8
   roughness .006
  normal{
   bumps .6
   scale .3
plane{
 y,-1
 texture{
  pigment{
   checker color Red, color Blue
Subject: Re: weird artifacts
Date: 4 Aug 1998 22:30:24
Message: <35C7B5A6.3148D488@flash.net>
Wierd.  It seems to me to be some sort of self-reflection
due to problems with the normal calculation applied to
rays of near-grazing incidence.
It seems to be eliminated by using ambient 0 diffuse 0 --
a perfectly reflecting surface is what you want, right?
Dan
P.S. A more direct way to rotate the light is to put
a "rotate" statement in the light rather than explicit
sin and cos calculations.... it comes down to preference,
I suppose.
http://www.flash.net/~djconnel/
Date: 4 Aug 1998 22:35:52
Message: <35C7A8B1.EE4CC6C3@pacbell.net>
    I played around with your scene for a little while and I think what you
are seeing is not an artifact, but rather the normal is giving you what your
asking it to do. With the single light source, a high degree of reflection, and
few if any other objects in the scene to be reflected in the surface finish, you
are seeng the true perturbance function of the normal.
    I did notice that changing the bumps statement to a dents statement with the
same value and scale produced a pretty good perturbed surface without the
"artifacts" your seeing.
K.Tyler
