POV-Ray : Newsgroups : povray.general : Best Platform ? Server Time
27 Mar 2026 23:52:26 EDT (-0400)
  Best Platform ? (Message 1 to 10 of 18)
Subject: Best Platform ?
Date: 24 Jul 1998 21:39:54
Message: <35B99A84.91DEC51D@kjopen.globalnet.co.uk>
Which platform would have the faster rendering times,
A Sun Workstation (or SGI machine)
or
A Top end PC
Subject: Re: Best Platform ?
Date: 25 Jul 1998 13:44:48
Message: <35B9C5E7.99BC855A@mail.minnehaha.pvt.k12.mn.us>
That really depends on how much money your willing to spend.  In the
same price range, for pure rendering speed a PC is going to beat both
out, because you can get other cheap components, and dual PIIs or
something.  If your comparing the best PC to the best sun or SGI, a 64
R10k SGI Oynx2 Reality Monster can't be beat by anything other than a
Cray.
Date: 25 Jul 1998 18:46:40
Message: <35BAC36C.3D0F4654@kjopen.globalnet.co.uk>
I'm thinking about;
Sun Ultra 10 or 30, with Creater 3D possibly Elite 3D, UltraSPARC 300MHz
(possible *2 CPU).
With a dual PII 300Mhz, etc.
Neil
Date: 25 Jul 1998 19:14:54
Message: <35ba58de.0@news.povray.org>
In article <35BAC36C.3D0F4654@kjopen.globalnet.co.uk> , Nei### [at] kjopenglobalnetcouk
wrote:
>I'm thinking about;
>(possible *2 CPU).
>Neil
Just remember, the official POV-Ray rendering speed will not increase with two CPUs!
Thorsten
Thorsten Froehlich
e-mail: Tho### [at] csicom
Date: 25 Jul 1998 19:38:04
Message: <35BACF75.B48BCB21@kjopen.globalnet.co.uk>
> Thorsten
So does that mean, the faster the CPU (higher MHZ) the faster the rendering time ?
Neil
Date: 25 Jul 1998 19:41:24
Message: <35BAD03F.69A60413@kjopen.globalnet.co.uk>
I mean
    one 333MHz CPU would render faster than
    two 300MHz CPU's    ?
Neil
Date: 25 Jul 1998 20:37:28
Message: <35BA6D8D.83FD2633@uchicago.edu>
> or
> A Top end PC
I think I heard once that POV supports network-based rendering (i.e.
mulitiple machines chugging away). If I'm right, then I think any group
of fast machines would be adequate.
Josh
Date: 25 Jul 1998 20:56:05
Message: <35ba7095.0@news.povray.org>
Nei### [at] kjopenglobalnetcouk wrote in message
<35BAD03F.69A60413@kjopen.globalnet.co.uk>...
>I mean
>    two 300MHz CPU's    ?
>Neil
At least on a WinNT machine, because it does not have native support for
multi processing, and the
POV-Ray code doesn't support it natively either (I think, someone correct me
if I'm wrong).
Date: 25 Jul 1998 21:01:03
Message: <35BA71C1.B759B143@flash.net>
With a multiprocessor machine, however, if you have the memory
to handle two jobs, then simply run two instances of POVRAY,
partitioning the image into segments using +SR and +ER.
I'll take the pair of 300MHz machines... with 256MB of memory to handle
the two jobs.
Dan
http://www.flash.net/~djconnel/
Date: 26 Jul 1998 04:48:28
Message: <35badf4c.0@news.povray.org>
In article <35BACF75.B48BCB21@kjopen.globalnet.co.uk> , Nei### [at] kjopenglobalnetcouk
Well, MHz is not all, but a single Pentium-II 400 MHz will be faster than any dual
P-II if you use one POV-Ray thread (of course you can start it more than once and the
operating system (WinNT!) should make POV-Ray use the second CPU, but I never did it -
I don't have a dual CPU machine).
Thorsten
Thorsten Froehlich
