POV-Ray : Newsgroups : povray.general : Butted transparency bug? Server Time
12 Sep 2025 22:32:14 EDT (-0400)
  Butted transparency bug? (Message 1 to 1 of 1)
Subject: Butted transparency bug?
Date: 12 Jul 1998 08:10:24
Message: <35A8999D.A5C32AA3@flash.net>
The following scene results in notable artifacts between
the transparent layers.  Separating these butted boxes
by a small gap makes things worse.  Overlapping the boxes
doesn't help.
In each case those interfaces viewed from the top are
visible.
I don't get it.... is this a bug?
Note: the details of the "media" are not important --
it is an attempt to approximate an exponential density
function with gradient y piecewise-linear segments.
#declare Camera_Location = <1.5, 0.7, -2>;
  location Camera_Location
  look_at <0, 0.5, 0>
light_source {
  Camera_Location
  color rgb 0.5
light_source {
  <-100, 100, -100>
  color rgb 0.5
merge {
  #declare Ny = 8;
  #declare Alpha = 0.5;
  #declare Factor = 1;
  #declare dY = 1 / Ny;
  #declare Y = 0;
  #while (Y < 1 + dY/2)
    box {
      <-0.5, 0, -0.5>,
      <0.5, dY, 0.5>
      hollow
      pigment { rgbf 1 }
      interior {
        media {
          absorption color rgb <1, 1, 0>
          scattering { 3, color rgb <0, 0, 1> }
          density {
            gradient y
            translate <0, Factor, 0>            // d(y=0)=Factor, d/dy = -1
            scale dY / ( Factor * (1 - Alpha) ) // d(y=0)=Factor,
                                                // d(y=dY) = Factor - Factor (
1 - alpha ) = Factor * alpha
      translate Y * y
    #declare Y = Y + dY;
    #declare Factor = Factor * Alpha;
plane {
  y,
  0
    checker
    color rgb <1, 1, 1>
    color rgb <1, 0.9, 0.8>
sky_sphere {
  pigment { color rgb 1 }
http://www.flash.net/~djconnel/
