POV-Ray : Newsgroups : povray.general : Media confusion Server Time
13 Sep 2025 00:44:21 EDT (-0400)
  Media confusion (Message 1 to 7 of 7)
Subject: Media confusion
Date: 7 Jul 1998 22:17:12
Message: <35A2C83E.1C69850D@pld.com>
I have just in the last few months gotten comfortable using 3.0's halo
function, and am now having fits trying to learn the intricacies of the
new media functions.  With halos, it is a relatively simple matter to
use scaling, turbulence, and partially transluscent/transparent color
maps to completely lose all indication of the shape of the container
object.  For example, I could easily create a dancing flame which
retained no semblance of the spherical container.  I have yet to figure
out how to do that using media.  All of my experimenting so far retains
(at least somewhat) the shape of the object.  Round clouds, explosions,
flames, etc. just don't work.  Maybe the method here is obvious, but I
haven't discovered it yet.  Any help, anyone?
Subject: Re: Media confusion
Date: 7 Jul 1998 22:26:01
Message: <35A2CAA9.780282BB@flash.net>
Consider such things as "density"; the "sphere", "box", etc
functions, density maps, color maps (in density statement),
and the rather promising voxel files.
All the old stuff is still there (plus more).... it's
just been reorganized.
Dan
http://www.flash.net/~djconnel/
Date: 8 Jul 1998 02:54:03
Message: <35A3186B.E2FCE36C@ltu.edu>
> Dan
Actually, that's not completely true.  Quite a bit has been
re-written, but the concept is the same.  One big difference
is that media IGNORES the transparant & filter channels of
its color maps.
To make a good looking flame you will probably want to use
two overlapping media.  The emitting one would contain a
color map that fades to black (black doesn't emit any light).
The second media would be absorbing and the color map colors
should probably be the compliments of the colors in the
emitting media (but still needs to fade to black).  The reason
that you'd use compliments is that you'd want to absorb the
colors other than the ones you are emitting.
I hope this helps.  The key is that you need to do a fade to
black instead of a fade to transparent (since transparency is
ignored).
-Nathan Kopp
Date: 8 Jul 1998 03:53:09
Message: <35a31755.0@news.povray.org>
Got an example to go with that :-(
Preferably with code ;-)
Bryan
Nathan Kopp <nk8### [at] ltuedu> wrote in message 35A3186B.E2FCE36C@ltu.edu...
>> Dan
>its color maps.
>ignored).
>-Nathan Kopp
Date: 8 Jul 1998 07:01:16
Message: <35A3431D.270D7E7F@pld.com>
This does make a great deal of sense.  Could you possibly supply an
example to get me started?  Thanks for the help!
> ignored).
> -Nathan Kopp
Date: 9 Jul 1998 07:04:09
Message: <35A495A2.A7BC0409@flash.net>
There is an example file in the standard 3.1 release called
"hollow3.pov" (scenes/interior/media/) with an example of
a media-generated flame.
Frankly, I'm still trying to figure it out myself, as I have
been unable to transfer it into my own object and get it
to visibly render.... still, it's there.
Dan
Date: 26 Jul 1998 08:18:18
Message: <01bdb887$127cb3a0$c742a8c2@wphnvffu>
Try this:
you need to scale the color map and make the first and last entries in the
color map 0
// Persistence Of Vision raytracer version 3.1 sample scene by Mike
Hazelgrove
// based on Hollow3 by Dieter Bayer.
// This scene shows a flame.
// by Mike Hazelgrove based on Hollow3
  location <-1.5, 30, -50>
  look_at <0, 25, 35>
  angle 35
background { color rgb<0.3,0.3,0> }
light_source { <100, 100, -200> color White }
sphere { 0, 1
  pigment {rgbf<1,1,1,1>}
  interior {
    media {
      emission 0.5
      intervals 20
      samples 1, 10
      confidence 0.9999
      variance 1/1000
      density {
       spherical
       scallop_wave
        turbulence 0.5
        color_map {
          [0.0 color rgb <0, 0, 0>] //You need this
          [0.25 color rgb <1, 0., 0>]
          [0.5 color rgb <1, 1, 0>]
          [0.75 color rgb <1, 0, 0>]
          [1.0 color rgb <0, 0, 0>]// you need this
        scale 0.5 //you need this
  scale 3
  scale <1,3,1>
  translate 25*y
  hollow
Dan Connelly <djc### [at] flashnet> wrote in article
<35A495A2.A7BC0409@flash.net>...
> Dan
