Hi 2 all 3d freaks!
I think the subject is clear.
When I use atmosphere in a scene, my sky-sphere isn't visible anymore.
It turned into black. Does someone know what to do about this?
Thank you.
Please mail your response to she### [at] pi net
Greetz, Stefan
Hi Stefan,
I'm not a 3d freak yet, though I intend to be at some stage, but I still may be able
to help out a bit.
Your sky sphere is at an infinite distance from the camera, so it has to be black
unless you change the colour statement of the atmosphere and set the transmit value to
something less than one.
Then if your scattering value is too high everything will be flushed white, lower it
until you get the desired effect.
All this also depends on the distance you use, experiment with these values.
I did a try with a sphere in the center, radius 6, camera at about 30 units away,
light sources at about 30 units away as well, a Blue_Sky sky sphere, all worked well.
You really have to experiment.
Try the following and adjust depending on what you want to get :
atmosphere
type 1
distance 150
scattering 0.003
colour rgbt <0.4, 0.4, 0.4, 0.99>
I hope this helps,
Al.
Stefan wrote:
> Hi 2 all 3d freaks!
> Thank you.
> Greetz, Stefan
ANTI SPAM / ANTI ARROSAGE COMMERCIAL :
Pour me répondre, veuillez enlever le Z de mon adresse.
To answer me, please take out the Z from my address.
