POV-Ray : Newsgroups : povray.general : Testing object intersections. Server Time
7 Nov 2026 03:39:01 EST (-0500)
  Testing object intersections. (Message 1 to 9 of 9)
Subject: Testing object intersections.
Date: 26 Mar 1998 21:27:44
Message: <351B0EA0.1E@wf.net>
Does POV provide any means where I can test for the intersection between
two objects?
Subject: Re: Testing object intersections.
Date: 31 Mar 1998 02:48:08
Message: <6fq79t$ccu$1@oz.aussie.org>
No, not unless you're prepared to jump into the code and try to find some
means of it.  I wonder whether there is a modified version of POV-Ray to do
this?  Can you be a little more specific?  (If you only need a recursive
sphere type detection I might be able to help)
Lance Birch
Remove the smiley to e-mail.
http://www1.tpgi.com.au/users/ambient/lance
Date: 31 Mar 1998 10:18:43
Message: <35210953.3732@wf.net>
I want to define limits for object interaction. Instead of having one
object pass into and through another, I want to have either the smaller
object leave a hole in the larger, or for the two objects bounce off
each other.
Concepts that I'm thinking of include animating wind blowing trees.
Branches should not pass through each other, while loose leaves should
not pass through the trees.
Date: 1 Apr 1998 13:37:30
Message: <1d6rw7q.1aocrp0wrr0scN@dialup168-1-19.swipnet.se>
> each other.
Hi!
Actually I think what you are describing is a *very* difficult problem,
from a mathematical point of view. Since objects can be described by at
least a fourth grade polynomial, you are asking for the solution space
of two fourth grade polynomials *or worse*.
With that said we can be satisfied with a heuristic algorithm for your
problem, such as just throwing away a couple of rays from the center of
one of the objects and see if they hit the intersection of the two
objects (which actually is a simple problem to solve). Now one way to
implement this would be to hardcode it into povray. Or better yet, we
can add a function to povray which allows one to get the next
intersection of a specified ray with a set of objects. The later
solution would be preferable since it could be used for a lot of things
(if think it have been suggested before in povray.programming).
Does anyone feel the surge to implement this and to specify a nice
syntax for it? (And while your at it, why not throw in a function to
get the gradient at a specified point for a given object...)
/ Mathias B.
Date: 1 Apr 1998 16:58:22
Message: <3522b674.31204900@10.0.2.33>
On Wed, 1 Apr 1998 20:37:30 +0200, mbr### [at] swipnetse (Mathias Broxvall)
wrote:
>Or better yet, we
I'm the one who suggested this on povray.programming.  I've kinda
halted efforts on my superpatch project until V3.1 comes out, but I
was planning to include such a thing in it.  It's not that difficult
to do, and if someone really, really needs it I can take a couple of
hours and code it up.
>syntax for it?
I like trace( <origin-vector>, <direction-vector> ) or the alternate
form, trace( <origin-vector>, <direction-vector>, <#declared-object>).
This way, you can check for any intersection, or just ones with a
specified object.
Assuming you really meant to say the normal vector, this isn't too
bad, either.  The syntax would be something along the lines of
normvect( <#declared-object>, <point-vector> ).  I'm not happy with
the "normvect" word, but "normal" is already taken.
Date: 2 Apr 1998 01:22:20
Message: <6fvau5$jvr$1@oz.aussie.org>
It'd be great if you could go ahead and add those features, even without the
superpatch.  Also CC the code to the pov team in case they would consider
adding it to pov 3.1.  I think it would facilitate a lot of fancy includes
such as crude physics models for animations.
Ken
Ronald L. Parker wrote in message <3522b674.31204900@10.0.2.33>...
>specified object.
Date: 2 Apr 1998 09:22:10
Message: <1d6uri0.ezhwak4zbls0N@dialup190-1-25.swipnet.se>
> specified object.
Hmm, I like the later one better than the first one (of course the
object can be a union/merge!?) since it could cause some
missunderstandings regarding *what* we are tracing otherwise.
(You have to "know" what objects already have been parsed etc...)
But otherwise I'd realy like it if you could implement this.
Yepp, I do. With these additions and the macro facility from the
isosurface patch one can make some realy *cool* include files.
Btw, I'd be glad to compile a macintosh port of your work when
you are finished (I assume you are using pc and/or unix) if you
like to (both of "this" and the "superpatch").
/ Mathias Broxvall.
Date: 2 Apr 1998 14:03:23
Message: <3523dd8e.106750739@10.0.2.33>
On Thu, 2 Apr 1998 16:22:10 +0200, mbr### [at] swipnetse (Mathias Broxvall)
Now that will require the "superpatch", or at least part of it.  I
think I would also have to add extra code to the macro parser to
handle any new functions I might add, and I'm not sure of the
complexity of that part.
That would be "and," though my puny 486/33 running FreeBSD isn't quite
powerful enough to build POV, and I haven't kept the makefiles
up-to-date.
Date: 30 Aug 1998 17:25:38
Message: <35E9B579.667C3BCC@erols.com>
> each other.
Unfortunately there is no general formula or algorithm for determining
if two objects intersect.  One fellow asked me about two months ago
how to determine if two boxes intersect; I'm still working on it.
John
"What can I say?  Everyone likes flowers, even us evildoers." -- Zorak
