POV-Ray : Newsgroups : povray.general : POV on AMD 64bit CPU Server Time
22 Aug 2025 22:05:40 EDT (-0400)
  POV on AMD 64bit CPU (Message 1 to 10 of 14)
Subject: POV on AMD 64bit CPU
Date: 21 Jan 2003 06:16:17
Message: <2naq2vsm7uh5urj230qfohibje9g1dqdts@4ax.com>
Came across this article http://www.ct.heise.de/ct/english/02/26/018/
that tests AMD's 64bit CPU against Athlon XP and Pentium 4. POVRay was
among the other apps in the test. See table at the end for results.
Scott
Subject: Re: POV on AMD 64bit CPU
Date: 21 Jan 2003 07:09:18
Message: <3e2d386e$1@news.povray.org>
Hmmm
PGP Public Key
Date: 21 Jan 2003 07:39:31
Message: <3e2d3f83@news.povray.org>
In article <2naq2vsm7uh5urj230qfohibje9g1dqdts@4ax.com> , Scott Moore
That way one will miss the most important point of the article!!!
They clearly say in the text that the Athlon 64 is a development version
clocked only at 1.2 GHz while AMD will ship with 2 GHz.  So you have to
multiply all (POV-Ray) results by 1.6 and not jump to conclusions based on
raw numbers without knowing the context!
    Thorsten
e-mail: tho### [at] trfde
Date: 21 Jan 2003 07:50:25
Message: <g5gq2vk506v8t4q9eiag22hk4cg3smbmhp@4ax.com>
On Tue, 21 Jan 2003 13:39:28 +0100, "Thorsten Froehlich"
Umm ... I assumed people would actually read the article too.
Date: 21 Jan 2003 08:19:58
Message: <3e2d48fe@news.povray.org>
  I suppose that they rendered a *different* test scene with POV-Ray 3.5
than they did with POV-Ray 3.1.
  It would have been good if they would have written this. Someone might
get the impression that 3.5 is a lot slower than 3.1.
Date: 21 Jan 2003 08:21:06
Message: <3e2d4942@news.povray.org>
  I'm sure you know that doubling the CPU clock rate does not double the
speed of programs (not even if they are very CPU-intensive), so a factor
of 1.6 may be way too optimistic.
Date: 21 Jan 2003 08:36:54
Message: <3e2d4cf6$1@news.povray.org>
"Warp" <war### [at] tagpovrayorg> wrote in message news:3e2d48fe@news.povray.org...
From the point of view of the authors, why should they care? ;)
It *does* say that they used the programs' own benchmarks...
Date: 21 Jan 2003 09:18:32
Message: <3e2d56b8@news.povray.org>
In article <3e2d48fe@news.povray.org> , Warp <war### [at] tagpovrayorg>  wrote:
Yes, they use chess2.pov for POV-Ray 3.1 and as far as I know they still use
optics.pov for POV-Ray 3.5.
    Thorsten
Date: 21 Jan 2003 09:21:14
Message: <3e2d575a@news.povray.org>
In article <3e2d4942@news.povray.org> , Warp <war### [at] tagpovrayorg>  wrote:
Of course, there is already some bias in my estimate; it would be 1.6666 if
there was a linear scale.  However, with the 3.1 test scene chess2.pov they
use most work takes place in the cache and it does indeed scale almost
linearly.
    Thorsten
Date: 21 Jan 2003 14:14:42
Message: <3e2d9c22$1@news.povray.org>
"Scott Moore" <noo### [at] nospamcom> wrote in message
news:2naq2vsm7uh5urj230qfohibje9g1dqdts@4ax.com...
Looks like this might be worth waiting for. I've got an Athlon 1.2 right now
which is starting to seem a little slow, but I've been thinking about
waiting for this new chip since I heard about it in October.
 -Shay
