POV-Ray : Newsgroups : povray.general : Povray script to OpenGL? Server Time
2 Nov 2026 11:28:26 EST (-0500)
  Povray script to OpenGL? (Message 1 to 23 of 23)
Subject: Povray script to OpenGL?
Date: 25 Mar 2003 04:16:57
Message: <20030325101656.32f6c5b0.liesch@gmx.ch>
Hi all,
I'm looking for a program that could translate a povray script to OpenGL C sources. Is
there a way to do that? Else is there perhaps a povray script OpenGL interpreter?
Best regards,
Christian
Subject: Re: Povray script to OpenGL?
Date: 25 Mar 2003 04:26:30
Message: <3e8020c6$1@news.povray.org>
"Christian Liesch" <lie### [at] gmxch> wrote in message
news:200### [at] gmxch...
> Hi all,
sources. Is there a way to do that? Else is there perhaps a povray script OpenGL
interpreter?
I'm tempted to say 'forget it', but I've been caught out on that once before.
Instead, I'll point you to Warp's VFAQ:
http://www.students.tut.fi/~warp/povQandT/
and the specific bit you should read is:
http://www.students.tut.fi/~warp/povQandT/filesQandT.html#povtootherformatsdiffi
culty
Date: 25 Mar 2003 04:38:58
Message: <20030325103857.197524a9.liesch@gmx.ch>
Hmmm, not very encouraging :-P
To model a povray figure is very easy (readable text file, cause it is a script) and
cheap, so I thought I'm surely not the only one how wishes to have a translation to an
other format (rapid prototyping as a catchword). Just a subset of the povray script
would help. But ok, perhaps this is impossible, but don't give up - not now :-)
thanx and best regards,
Christian
On Tue, 25 Mar 2003 09:26:30 -0000
> > Hi all,
> interpreter?
> culty
Date: 25 Mar 2003 06:01:47
Message: <3e80371b$1@news.povray.org>
No, but understandable. As you say, a subset is possible, but translating a
complex CSG which uses macros to construct it's geometry? Iso-surfaces? Yeech.
Date: 25 Mar 2003 07:01:35
Message: <3e80451f@news.povray.org>
  Actually tesselating an isosurface is not difficult (eg. using the
triangle marching algorithm).
  Tesselating CSG is a bit more difficult, but not impossible.
  However, POV-Ray can also handle infinite non-flat surfaces (such as
infinite paraboloids and hyperboloids) which can't be tesselated (you
simply can't create an infinite amount of triangles).
Date: 25 Mar 2003 08:46:02
Message: <3e805d9a$1@news.povray.org>
"Warp" <war### [at] tagpovrayorg> wrote in message news:3e80451f@news.povray.org...
JOOC, how does pov handle infinities? Okay, the concept of an infinite plane is
easy enough, but at what distance does pov stop trying to find intersections
between the surface and the ray?
Date: 25 Mar 2003 09:01:59
Message: <v1o08vs3i168mrihk5qt4o8lu8q3hrdvt0@4ax.com>
On Tue, 25 Mar 2003 13:46:01 -0000, "Tom Melly" <tom### [at] tomandlucouk> wrote:
Mathematically. The shapes are usually stored just like they are defined in SDL.
ABX
Date: 25 Mar 2003 09:19:05
Message: <3e806559$1@news.povray.org>
"ABX" <abx### [at] abxartpl> wrote in message
news:v1o08vs3i168mrihk5qt4o8lu8q3hrdvt0@4ax.com...
SDL.
Sorry, I should have been clearer (or, if your answer is complete, perhaps you
should ;).
Whilst internally POV can "see" that the shapes are infinite, at the trace-level
POV must give up at some distance, otherwise (afaics) any scene with an infinite
object might take forever to trace. I suppose another way of putting it is "what
bounding box does pov apply to infinite shapes?".
Date: 25 Mar 2003 09:30:55
Message: <20030325153055.4b9ba653.liesch@gmx.ch>
On Tue, 25 Mar 2003 11:01:47 -0000
Of course just a subset:
- differences
- unions
- box
- cylinder
- scaling, translation, rotation
Ok. I just wonder that there is no convertion to any other Graphical system, cause
povray is a realy easy to use tool to build up modells and best of all it is a clear
text script not a binary...
In the meantime I found a Project, which convert a povray script into gts and stl, but
it can not handle scaling. So I have to program something addional stuff for it.
http://www.kritzner.de/
regards, Chrsitian
Date: 25 Mar 2003 10:03:37
Message: <3e806fc9$1@news.povray.org>
Maybe this will be of some use to you (copied from pov.bins.utils):
"Wolfgang Thaller" <wol### [at] gmxnet> wrote in message
news:3c82b64c$1@news.povray.org...
> I've just released a new freeware utility program
> that might interest you:
> http://www.kfunigraz.ac.at/imawww/thaller/wolfgang/vop-intro.html
> VOP is a program that parses POV-Ray scene
> description files and renders them using OpenGL.
> While the resulting 3D images are not as nice as
> POV-Ray's, VOP is anywhere from five to two thousand
> times faster (depending on situation and measurement
> method).
> As you can imagine, this can be very practical for
> designing scenes and animations. The downside is that
> it doesn't yet support the entire scene description
> language - but I think it already supports more of it
> than any other program besides POV-Ray itself.
> There's a Windows compile available and I could probably
> compile a version for RedHat Linux 7.1, too, if somebody
> really wants it.
> I'm looking forward to your feedback.
> Cheers,
> Wolfgang Thaller
jim
Date: 25 Mar 2003 10:51:56
Message: <3e807b1c@news.povray.org>
If only this thing is at least half as smart as its name... :-)
Date: 25 Mar 2003 12:46:33
Message: <3e8095f9@news.povray.org>
  Uh? Calculating the intersection point of a ray and a surface which
is very very far away does not take any longer than with a surface
which is close. Why would you think it does?
  Anyways, what you are looking for in your question is not tracing *time*,
but tracing *accuracy*. Since floating point numbers have limited accuracy,
there's a certain limit how far the intersection point can be. There's a
maximum value which can be represented with a floating point number (and
values near this maximum value are not very accurate, as they make rather
big "jumps").
  Theoretically the upper limit of a distance is really large, as the
maximum value which can be represented with a (64-bit) 'double' type
is about 1.8*10^308 (that's "18" followed by 307 zeros). So theoretically
you could have an intersection point that far away from the origin in each
axis.
  However, as I said, the representation of numbers near that value become
really inaccurate and thus it's not very feasible to get close to it.
  There's an artificial limit in POV-Ray how far an intersection can be in
order for it to have effect. This is done so that they don't get close to
this upper limit, where inaccuracies are large. (However, I seem to recall
that this artificial limit is almost paranoidically low, even though it
could be a lot higher.)
  Anyways, even when there are limits imposed by finite accuracy, the
amount of triangles needed to approximate such surface would be enormous
nevertheless.
Date: 25 Mar 2003 13:29:05
Message: <3e809ff1@news.povray.org>
"Tom Melly" <tom### [at] tomandlucouk> a écrit dans le message de news:
3e805d9a$1@news.povray.org...
plane is
intersections
The wormhole towards other dimension of non-pov world is here if you
decomment the second line:
#declare Passage=9999999.0;
//#declare Passage=9999999.00002;
sphere { 0, Passage
 pigment{rgb<0,.5,1>}
  location  <0, 0,-1>
  look_at   <0, 0,  0>
light_source{0,2}
Thanks Martial
And found by Mael (mlPOV) in the frame.h file of the sources:
 * These values determine the minumum and maximum distances
 * that qualify as ray-object intersections.
#define Small_Tolerance 0.001
#define Max_Distance 1.0e7
Marc
Date: 25 Mar 2003 14:54:31
Message: <3e80b3f7@news.povray.org>
news:3e8095f9@news.povray.org...
Well, I was kind of thinking that an infinite plane would require an
infinite number of rays to trace since there would be an infinite number of
places that a ray could intersect (and that would be potentially in view).
However, on reflection, it occurs to me that:
a) the number of rays is limited by the resolution
and
b) that would just be silly.
Toodleoo.
Date: 25 Mar 2003 14:55:25
Message: <3e80b42d$1@news.povray.org>
"Marc Jacquier" <jac### [at] wanadoofr> wrote in message
news:3e809ff1@news.povray.org...
Many thanks.
Date: 25 Mar 2003 16:13:22
Message: <3e80c672@news.povray.org>
  A ray can intersect a plane only in one place. There's no way for a ray
to intersect a plane in more than one place (unless it bends somehow). :)
Date: 25 Mar 2003 16:14:45
Message: <3e80c6c4@news.povray.org>
  IMHO those values should be promptly changed...
Date: 26 Mar 2003 02:09:47
Message: <3e81523b$1@news.povray.org>
"Warp" <war### [at] tagpovrayorg> a écrit dans le message de news:
3e80c6c4@news.povray.org...
I agree they are limitating when you need close-small and remote-huge
objects in the same scene
Marc
Date: 26 Mar 2003 02:24:34
Message: <20030326082434.5b65fd59.liesch@gmx.ch>
Thanx, I think this will help me.
Only - it is not GPL software and the source distributen is awful ;-)
Date: 26 Mar 2003 04:29:30
Message: <3e8172fa$1@news.povray.org>
"Warp" <war### [at] tagpovrayorg> wrote in message news:3e80c672@news.povray.org...
Sorry, I'm not explaining my question/confusion well (which is now pretty much
resolved).
A plane stretching to infinity would, presumably, need an infinite bounding box
(otherwise it's not infinite). An infinite number of rays would be required to
trace it, since there would be an infinite number of intersection points. This
would take an infinite amount of time. This is obviously wrong, but I was
curious as to how it was wrong, which I think I now largely understand.
Date: 26 Mar 2003 04:41:30
Message: <3e8175ca@news.povray.org>
  I think an infinite object does not have a bounding box at all.
  I don't understand how you came to this conclusion.
  An infinite number of intersection points to calculate what? For one
pixel we need one intersection point (unless using antialiasing, which
means we may need something like 9 intersection points). What do you need
to calculate an infinite amount of intersection points for?
Date: 26 Mar 2003 05:59:25
Message: <3e81880d$1@news.povray.org>
"Warp" <war### [at] tagpovrayorg> wrote in message news:3e8175ca@news.povray.org...
You obviously forgot to factor in my idiocy.
This is the solution to my confusion (and fairly bleedin' obvious when I think
about it). I was thinking that the number of rays required to trace an object
was dependant on the object's actual size (infinite in the case of a plane),
whereas the number of rays is more dependant on the area of the image that the
object occupies (always finite).
Date: 26 Mar 2003 17:08:17
Message: <3e8224d1@news.povray.org>
Internally, infinite objects are even kept in a separate list, at scene
root, outside of any hierarchies.
