POV-Ray : Newsgroups : povray.general : POV-RayUnofficial 3.1g MultiPatch for Macintosh PPC/68k uploaded Server Time
6 Nov 2026 21:46:07 EST (-0500)
  POV-RayUnofficial 3.1g MultiPatch for Macintosh PPC/68k uploaded (Message 1 to 5 of 5)
Subject: POV-RayUnofficial 3.1g MultiPatch for Macintosh PPC/68k uploaded
Date: 15 Nov 1999 13:06:38
Message: <1e1blgw.sg7yh61o9ojnkN%smellenbergh@skynet.be>
We uploaded our latest version of our unofficial compile for Macintosh.
New in this version:
    -Upgraded the rendering engine with several patches.
    -Photons (real caustics).
    -Light & shadow controls with light groups.
    -Improved sampling methods for media.
    -Improved radiosity.
    -Solid triangle mesh and new mesh type: mesh2.
    -Smooth color triangle with different colors at each vertex.
    -New object type: Isoblob.
    -New patch type: rational bezier.
    -Object controls 'no_image', 'no_reflection'.
    -Colored attenuation in objects.
    -Double_illuminate to illuminate both sides of the object's surface.
    -UV mapping.
    -Reset child textures, so that transformations only affect the
      parent texture.
    -Slope dependent texture.
    -Several new patterns (triangle, square,....).
    -Added pigment function in Isosurface.
    -Transform points with vtransform().
    -Trace function to find the intersection point with an object.
    -New keywords 'image_height' and 'image_width' to use actual image
      size in the scene.
    -New keywords 'initial_frame', 'final_frame', 'initial_clock',
      'final_clock' and 'frame_number' to use actual clock
      values in the scene.
    -Added a link in the camera template to call the normal template.
    -Added links in the objects template to call pigment, normal and
      finish templates.
    -Added a panel in the application prefs dialog to set four
      additional include paths.
    -Added an indicator in the files & paths panel to show if 'use ini'
      is set.
Fixes and changes in this version:
    *Fixed a bug in the universal headers, that didn't allow to select
      text and pref files at the same time in the batch.
    *Fixed several small syntax errors in the template dialogs.
    *Using the edit button in the batch will also open text files
      (before only pref files).
    *Fixed a triangle bug.
    *Fixed number_of_waves bug.
    *Fixed bug in gamma with focal_blur .
    *Fixed a bug in movie and pict output. Caused problems when not
      opening the compression dialog.
    *Adapted all templates for the new keywords (patches). Unofficial
      keywords are shown in blue or with an asterix.
    *Rearanged layout for object templates.
You can find all these lovely things at:
http://users.skynet.be/smellenbergh
Many thanks to all the authors of the patches, especially to Nathan Kopp
who we bothered a bit with our questions and bug reports :-)
Also many thanks to J. Grimbert who helped us getting the no-image and
no-refection patch to work.
Best regards,
Smellenbergh
e-mail:sme### [at] skynetbe
Subject: Re: POV-RayUnofficial 3.1g MultiPatch for Macintosh PPC/68k uploaded
Date: 15 Nov 1999 13:31:20
Message: <3830513E.8D9D64D8@pacbell.net>
>       size in the scene.
I'm a little fuzzy on this one. What is the difference in this feature
compared to simply scaling the image ?
Ken Tyler -  1200+ Povray, Graphics, 3D Rendering, and Raytracing Links:
Date: 15 Nov 1999 17:10:38
Message: <383084de@news.povray.org>
I'm guessing it is about gathering the render image resolution up and being
able to use that in the scene file somehow.  But just a guess.
Ken <tyl### [at] pacbellnet> wrote in message
news:3830513E.8D9D64D8@pacbell.net...
> >       size in the scene.
Subject: image_height/image_width
Date: 15 Nov 1999 18:27:54
Message: <1e1c5s7.rg85d918a8dmaN%smellenbergh@skynet.be>
Ken <tyl### [at] pacbellnet> wrote:
> >       size in the scene.
It's easy:
    perspective
    location <0.0, 0.0, -5>
    up y*image_height right x*image_width
    angle 60
    look_at <0.0, 0.0, 0.0>
and your image is right, no mather what size you use. We have found it
very usefull while messing :-) with all those patches.
Image_height/width return the settings you use for the render.
It just makes things easier. There was already a patch but they used the
keywords screen_height and screen width, we think that talking about the
image is more accurate.
smellenbergh
Subject: Re: image_height/image_width
Date: 16 Nov 1999 04:58:29
Message: <38312ac5@news.povray.org>
In povray.general smellenbergh <sme### [at] skynetbe> wrote:
: and your image is right, no mather what size you use.
... supposing that your screen pixels are square.
  Sometimes the distorted aspect ratio is intentional. For example when
making an image for the 320x400 resolution (eg. windows startup image).
Date: 15 Nov 1999 15:28:13
Message: <38306D89.7DC23B19@compuserve.com>
Well, I can finally stop working on MacUVPov. :-)
Date: 15 Nov 1999 18:19:07
Message: <383094D9.86FC782A@spiritone.com>
Did you do something to the basic render method? I have been working on a
file with the previous release, and grabbedthis one right away. It uses
nothing but standard primitives, and when I render it in the new version it
includes a large shadow, a bunch of red spheres now have blue edges,
andwhile cylinders have light blue "auras". Plus the shadow has some
distinctive blocks in it.
Any ideas? I can post some examples if it'd help?
Josh English
(ps, when I went back to the old version, the Editor Prefs were all messed
up, syntatic coloring was messed up real bad.. I know, I should have
seperated my pref files...)
>     -UV mapping.
>       parent texture.
>       size in the scene.
>       finish templates.
>       is set.
> Best regards,
> Smellenbergh
Date: 15 Nov 1999 18:27:55
Message: <1e1c621.1sltm3h1j4h6psN%smellenbergh@skynet.be>
Yes, but don't stop working on your patches. As you might have noticed,
one of them already made it, we added it in our compile. The other ones
are promissing but.....
We will contact you for the other ones. There just wasn't time enough to
fully test them and add them. There comes a time you have to stop adding
features and release things, that thime was nov 15 1999 :-)
smellenbergh
Date: 15 Nov 1999 18:36:38
Message: <1e1c6qo.15x3cqp157osoaN%smellenbergh@skynet.be>
We carefully watched that renders are the same as when using the
official version. However, we use the uv_patch 6.1+ as a base and there
are still some little bugs in it (harmless and we were sure  we avoided
them)
Please do, that is the only way to find out what is going on. Just mail
them to us and we will check it out.
> Josh English
Yes, that seems to be a problem. We changed a lot in the prefs and the
old version can't handle it. You will have to throw the prefs away in
the system folder or move them every time you use a differend version.
It's an old mistake that keeps following  us :-(
smellenbergh
Date: 15 Nov 1999 18:45:59
Message: <38309BE6.E4584BA9@compuserve.com>
features and release things, that thime was nov 15 1999 :-)<
No immediate danger of me stopping my patch work. It will slow down a
bit, though. If anyone has any suggestions or ideas for new features, I
would like to hear them. :-)
And yes, I did notice that vtransform() made it. I am glad to find out
someone else is interested in my work. :-)
I had a bit of trouble downloading the new version, though. The server
kept dropping the connection. I eventually did get it, though, and will
probably be using it for most of my work.
Date: 15 Nov 1999 21:16:48
Message: <3830be90@news.povray.org>
Wish list, for now: anisotropics, blinn shading, and subsurface scattering.
I'll think of more things as they come...
Thanks for all you have done so far. Believe me, I do appreciate it and I'm
very greatful. Please keep it up. =)
Date: 16 Nov 1999 07:11:40
Message: <38314AAB.C4E74388@compuserve.com>
Could you explain what anisotropics, blinn shading, and subsurface
scattering are? I have no idea what they do, I never even heard of
them.(except anisotropics, I have heard of those. I don't know what they
do, though.) :-)
Date: 16 Nov 1999 08:47:42
Message: <slrn832o29.v8.ron.parker@ron.gwmicro.com>
>do, though.) :-)
An anisotropic shader would have different effects depending on not just
the local "elevation" of the incident ray, as is usual, but also the local
"azimuth." Think of one of those Christmas ornaments that's wrapped with
fine fiber and thus has a ring-shaped highlight.  I'm thinking such a thing
would require UV mapping as a prerequisite.
These are my opinions.  I do NOT speak for the POV-Team.
The superpatch: http://www2.fwi.com/~parkerr/superpatch/
My other stuff: http://www2.fwi.com/~parkerr/traces.html
Date: 16 Nov 1999 14:07:37
Message: <3831ab79@news.povray.org>
Blinn is a type of shading like phong that is good for simulating cloth
materials (I saw it in Max). Subsurface scattering is a rendering concept
that considers all objects partially transparent and renders the light and
its interactions just a little below the surface. If also seems to help in
wetting or dampening surfaces.
Date: 16 Nov 1999 15:17:32
Message: <3831BC8D.758A18AB@compuserve.com>
These sound interesting, know of any web sites with more info?
Date: 16 Nov 1999 21:28:11
Message: <383212bb@news.povray.org>
About blinn shading, no, not really. Perhaps somewhere on Kinetix's site, or
you can look around. About the subsurf scat, someone recently posted a link
to the original inspiration to Nathan Kopp's photon mapping and it's in
there.
Date: 18 Nov 1999 05:30:31
Message: <3833D5FA.2AE62388@compuserve.com>
There seems to be a problem with filtering objects, filter is treated
like transmit. I haven't downloaded the bug-fixed version yet, but this
seems to be unrelated to that bug.
For example, this:
sphere {< 0, 0, 0>, 1
  pigment {color Green filter 1}
 translate < 0, 1.0001, 0>
is invisible when placed on a ground plane, when it should show up as a
green transparent sphere.
This happens with #version 3.1 but not with #version 3.14159, I don't
know if it happens in UVPov.
Date: 18 Nov 1999 05:34:57
Message: <3833D612.B2DF0E2C@pacbell.net>
> For example, this:
I recall that Warp mentioned something about a dissapearing filtered sphere
problem with UVPov v6.0 that Nathan was going to fix for UVPov v6.1. That
may explain the difference.
Date: 18 Nov 1999 06:16:22
Message: <3833E0B9.1AB786F0@compuserve.com>
Oh, and the sphere_sweep template form produces b-spline_sphere_sweep
instead of b_spline_sphere_sweep, I thought this was fixed before?
Still using the Nov 15 version, I lost the connection in the middle of
downloading the new version. :-(
Subject: Downloading POV-RayUnofficial 3.1g MultiPatch for Macintosh PPC/68k
Date: 18 Nov 1999 14:47:44
Message: <1e1hamk.v9nduu19hu9igN%smellenbergh@skynet.be>
We almost had a hardattack while reading this mail! :-)
Keeping cool was the way to go... yes, it was fixed and still is but
there were two spots in the source producing this text. We cleaned up
the sources and guess what: we kept the code producing the wrong test.
It is harmless, and we will fix it for a next version.
Thanks for taking a few year of of our lives. :-) :-)
We know that feeling, we had the same problem if we wanted to download
from the US. We must admid that this didn't happen for a long time now.
We do know that we have a good server, located here in Belgium, and
perhaps you have to solve it like we did: download after rush hours.
Smellenbergh
Date: 18 Nov 1999 14:47:46
Message: <1e1haxe.1i7qseee0oneoN%smellenbergh@skynet.be>
> For example, this:
We tried it and we always get a correct image. The whole scene file we
used is included in this mail.
A little note:
if you set the version in the source, the setting in the prefs dialog
will be overwritten. Thaugt we could better tell you, we have been
looking for a bug that wasn't there. ;-)
There was a problem but that has been fixed by Nathan in 6.1, we waited
for v6.1 to release our version.
Are you sure you weren't working with a version you compiled yourself?
If you can reproduce it again with the nov 17 version, please e-mail us
the complete source and a prefs file.
A little advice: if you have questions about any patch we included,
please post your message in a group where you are more likely to get an
answer (patches, general,..) and give it an appropriate 'Subject'.
Smellenbergh
// Persistence of Vision Ray Tracer Scene Description File
// File: ?.pov
// Vers: 3.1
// Desc: Checkered Floor Example
// Date: mm/dd/yy
// Auth: ?
//#version 3.1;
global_settings
  assumed_gamma 1.0
    perspective
    location <0.0, 1.5, -5>
    angle 60
sky_sphere
  pigment
    gradient y
    color_map { [0.0 color blue 0.6] [1.0 color rgb 1] }
light_source
  0*x // light's position (translated below)
  color red 1.0  green 1.0  blue 1.0  // light's color
  translate <-30, 30, -30>
plane
  y, -1
    checker
    rgbft <1.0, 1.0, 1.0, 0.0, 0.0>,
    rgbft <0.6, 0.6, 0.6, 0.0, 0.0>
Date: 18 Nov 1999 15:34:13
Message: <38346376.A6C59F55@compuserve.com>
answer (patches, general,..) and give it an appropriate 'Subject'.<
Ok, discussion continued under povray.unofficial.patches, in a message
titled "Unofficial MultiPatch filter bug?".
Date: 19 Nov 1999 04:35:31
Message: <383519DE.9F3EF50A@ti-nov3.fbe.fh-weingarten.de>
For subsurf scat check out:
http://graphics.stanford.EDU/~henrik/
for a first start point....
hope, this is useful...
v
Zan
> there.
