POV-Ray : Newsgroups : povray.general : Voxel output from POV? Server Time
23 Oct 2026 13:10:30 EDT (-0400)
  Voxel output from POV? (Message 1 to 16 of 16)
Subject: Voxel output from POV?
Date: 22 Jan 2002 18:14:49
Message: <1416110.YRq4vBrkhl@3-e.net>
How complex a task would it be to patch POV so that is could render a scene
to a wavelet compressed voxel (3d pixel) file.
I know some of these voxel files could be huge but tricks can be used to
reduce their size. Remove all data inside opaque volumes and use a separate
data layer for media and atmospherics so that it can be turned off or very
high levels of compression applied to it. Multiple LOD points could be set
to allow for navigation through the scene. Imagine these LODs as a set of
overlapping spherical gradients that control the compression level.
I often wonder what it would be like to wander/look around inside some of
the first class work on from the IRTC.
Think of it as extreme POV-VRML
:o) Dan.
Subject: Re: Voxel output from POV?
Date: 22 Jan 2002 18:21:48
Message: <3c4df40c$1@news.povray.org>
I have a friend who has a voxel engine that accepts height maps from POV Ray
and color maps to lay over them. It works very well. Let me know if that is
something that would interest you.
"Daniel Matthews" <dan### [at] 3-enet> wrote in message
news:141### [at] 3-enet...
scene
separate
> :o) Dan.
Date: 22 Jan 2002 19:31:13
Message: <13863242.0VBb9nUPly@3-e.net>
No it doesn't.
I was interested in a patched version of POV that has the exact features
that I described, or a reasonable subset of them. Or a discussion on it's
feasibility..
Unless your friend's engine is GPL and can handle multidimensional wavelet
arrays, including alpha/mask dimensional sets?
> Ray and color maps to lay over them. It works very well. Let me know if
> that is something that would interest you.
> scene
> separate
>> very high levels of compression applied to it. Multiple LOD points could
>> be set to allow for navigation through the scene. Imagine these LODs as a
>> set of overlapping spherical gradients that control the compression
>> level.
>> :o) Dan.
Date: 22 Jan 2002 19:48:44
Message: <chrishuff-482EC3.19494722012002@netplex.aussie.org>
MegaPOV has a feature that can be used to create 3D density files, but
that is purely geometry and uncompressed. Your idea sounds
interesting...I think it would have to be another rendering engine
attached to the same parser, though.
I think it would be possible, but a huge amount of work.
BTW, do you have any information on voxel file formats? I've been
working on a voxel file editor...
Date: 22 Jan 2002 20:09:44
Message: <2652268.5OnKVQPIDv@3-e.net>
I have a few PDF files of papers related to 3d wavelet compression of
voxels. Look up stuff on medical imaging.
Date: 22 Jan 2002 20:33:45
Message: <3C4E12C2.578ABD05@aol.com>
Could this be what you are looking for?
 A Fast Depth-Buffer-Based Voxelization Algorithm
Date: 22 Jan 2002 21:01:04
Message: <1022879.ASKD2KPVSP@3-e.net>
Yes! Thank you, that hint + google.com gave me this link
http://www.acm.org/jgt/papers/KarabassiEtAl99b/
Date: 22 Jan 2002 21:10:01
Message: <1173651.usQuhbGJ8B@3-e.net>
The VolVis link off that page also has related images.
http://www.cs.sunysb.edu/~vislab/volvis_home.html
So the steps are
Generate the matrix in POV via a 3d render.
Encode the matrix with compression.
View the Matrix from any point.
No fancy lighting of the Volume is required as the original 3d render will
supply this data. A good radiosity render should be a "fun" object to look
at.
Date: 22 Jan 2002 21:12:54
Message: <2103066.dPhlSkOF2f@3-e.net>
http://www.google.com/search?q=wavelet+voxel
Date: 23 Jan 2002 00:25:50
Message: <MPG.16b8680c1ddc3f7d9896d2@news.povray.org>
In article <141### [at] 3-enet>, dan### [at] 3-enet says...
What about the camera-location-dependent features: reflections,
refractions, highlights...
You can't precalculate and store them all (you would have to this for
every possible camera location) and you can't recalculate them later
on-the-fly.
Lutz-Peter
Date: 23 Jan 2002 00:44:42
Message: <1481257.3LdiiZoQLe@3-e.net>
Each voxel is a spherical map (possible very low res)
The lowest res would be a six sided shape with each side having 16 bit
vales for RGB or HLS. LOD would determine the map size?
The rendered view is an interpolation between these values, which are
chosen from the map points that are facing the camera, with the values of
the map been interpolated too, based on the normal of the map values
relative to the camera. i.e. a cube map would have three sides facing the
camera most of the time so the resulting value will be a mix of the three.
> on-the-fly.
> Lutz-Peter
Date: 23 Jan 2002 00:49:23
Message: <1489933.Bqz00pNo8v@3-e.net>
To see this as wavelets in a simple case such as the lowres cube map,
imagine a 1D wave for each face on each voxel.
Then you have a 2D grid of waves running from top to bottom, another from
left to right and another from front to back.
This would be for a monochrome image, so multiply by 3 to encode the HLS
values.
>>> of the first class work on from the IRTC.
>> on-the-fly.
>> Lutz-Peter
Date: 23 Jan 2002 02:56:45
Message: <7337868.O9o76ZdvQC@3-e.net>
http://www.3dcompression.com/index.phtml
Date: 23 Jan 2002 14:01:36
Message: <3c4f0890@news.povray.org>
In article <141### [at] 3-enet> , Daniel Matthews <dan### [at] 3-enet>
Well, there is a function that can determine if a point is inside an object
or not.  That would work for most but not all objects.  Determining the
color of an object at just about any position should be possible as well,
also it would not be perfect (given that usually nobody assigns interiors to
solid objects and one would have to use the texture an artist only assumed
would be used for the outside - nevertheless, as most textures are defined
at any point in space, it would still be possible to make up a color for
those invisible voxels as well).
Which leaves the compression.  I never implemented any wavelet based
compression, but from what I have read, those are usually a bit more complex
than a simple JPEG or PNG/ZIP compressor to implement.  So unless someone
has a library for this, I would assume implementing the code for the
compression would take by far most of the time.
    Thorsten
e-mail: tho### [at] trfde
Date: 25 Jan 2002 15:37:30
Message: <chrishuff-008041.15385725012002@netplex.aussie.org>
In article <733### [at] 3-enet>, Daniel Matthews <dan### [at] 3-enet>
Thanks for this and the other links, they should be useful...
Date: 2 Feb 2002 16:40:01
Message: <3c5c5cb1$1@news.povray.org>
With Povscript's (3.5) trace() function it should be possible to 'render' a
scene into a 3d-array of intersections and save that to disk. Another
program or util should convert that huge file into a 3d wavelet compressed
file.
By the way: I'm a big fan of wavelets.
