POV-Ray : Newsgroups : povray.general : DB -> POV charts and graphs? Server Time
2 Nov 2026 18:44:56 EST (-0500)
  DB -> POV charts and graphs? (Message 1 to 11 of 11)
Subject: DB -> POV charts and graphs?
Date: 7 Nov 2002 01:37:48
Message: <1101713.ccJ0WzO4qp@3-e.net>
Is there a utility or macro set for building charts and graphs in povray
from datasets (SQL) or comma delimited files?
A VB module for MS Office?
Your connection failed because: YOU HAVE AN I/O ERROR -> Incompetent
Operator error
Subject: Re: DB -> POV charts and graphs?
Date: 7 Nov 2002 08:08:03
Message: <3DCA65A1.EA18831B@pacbell.net>
I am aware of most POV-Ray related utilities and macros but there are no utilities
or macros like this available that I am aware of.
Sorry,
Ken Tyler
Date: 7 Nov 2002 08:46:22
Message: <cirksuk2cia6cfbc66uu25dkgqdms559o5@4ax.com>
On Thu, 07 Nov 2002 17:37:48 +1100, Daniel Matthews <dan#@3-e.net>
If you do a s/\n/,/g so that it really *is* a comma-separated list (as
opposed to comma-and-newlines-separated), you can use - guess what -
POV-Ray :)
Yep. POV-Ray's file I/O functions read CSV perfectly fine, IEEE floats
included, provided that you don't rely on white space to separate your
values (because it won't).
Peter Popov ICQ : 15002700
Date: 7 Nov 2002 13:42:24
Message: <3dcab410$1@news.povray.org>
I wrote such a VB program, but it is not suitable to share.
Many, many bugs and features to fix. Also wrote one to
work specifically within SPSS, the objective being to produce
3-D (stereoscopic) bar and scatter plots. I don't have time
or the programming skills to work on it.
Harolddd
"Daniel Matthews" <dan#@3-e.net> wrote in message
news:110### [at] 3-enet...
> Operator error
Date: 7 Nov 2002 14:17:35
Message: <3626244.oWBVZp44mK@3-e.net>
> POV-Ray :)
> Personal e-mail : pet### [at] vipbg
> TAG      e-mail : pet### [at] tagpovrayorg
Thanks for the info Peter, I guess writing the code in POV would make it
more portable too. :o)
If I write anything such as a graphing macro, that has no external
dependencies, I will post it on this server.
Your connection failed because: suboptimal routing experience
Date: 7 Nov 2002 14:19:53
Message: <1129989.OkL2d8F4i3@3-e.net>
OK, I will send you any useful code I find or write.
Hmmm, perhaps I should write an add-on to Open Office rather than MS Office?
> Harolddd
>> Operator error
Your connection failed because: excess surge protection
Date: 7 Nov 2002 14:50:17
Message: <3dcac3f9@news.povray.org>
news:362### [at] 3-enet...
I've once used pov for graphing - iirc it was something pov could do very
easily (or at least visibly) that was beyond excel.
One not necesserily obvious top-tip is that, even though pov reads lines, it
doesn't interpret EOL as a delimiter (iirc).
Date: 8 Nov 2002 05:36:06
Message: <qq4nsug0hj16ucj9g8e14scs0mdsovrfa7@4ax.com>
On Thu, 7 Nov 2002 19:49:34 -0000, "Tom & Lu Melly"
Thought I mentioned that already :)
But hey, you can always patch it to suit your needs <grin>
Date: 8 Nov 2002 12:43:10
Message: <3dcbf7ae$6@news.povray.org>
Given that povray is the only programming language I'm fluent in, I've
considered using it for processing of some txt files.
I have successfully written SDL that writes a big array to a file and then
another one that reads it.  But here the file that is opened is pure povray
SDL-- it's probably just like an "include" command.
Two questions:
1) Could someone write a file that reads a txt and knows what to do with it?
Exactly how does pov perceive a line of code in an opened txt file?  Or is
it seen as one big string variable or what?
2)  Is the "fileio" subdirectory **supposed** to be empty??
Date: 8 Nov 2002 13:24:27
Message: <3dcc015b$1@news.povray.org>
I'm in the middle of changing jobs and moving right now, but
after I've settled I'll send you what I have. I'm not a good
programmer but it might give you a pointer or two for something
better.
Harold
news:112### [at] 3-enet...
Office?
> > Harolddd
povray
> >> Operator error
Date: 9 Nov 2002 01:15:03
Message: <1698905.khs46HFU1V@3-e.net>
That would be most useful.
Thanks!
> better.
> Harold
Your connection failed because: Budget cuts
