POV-Ray : Newsgroups : povray.general : Isosurface troble Server Time
22 Oct 2026 22:47:45 EDT (-0400)
  Isosurface troble (Message 1 to 32 of 32)
Subject: Isosurface troble
Date: 5 Aug 2002 11:27:19
Message: <0u5tkuoupvgafcrgfurg3g7a5btgo3sh9q@4ax.com>
I need some help with generating terrain with isosurfaces. Render
times are intolerably slow! I am getting a max_gradient of over 25000,
which is too high IMHO. The function in question is:
#declare F_Relief = function {
    image_map { tga "relief.tga" interpolate 2 }
    rotate 90*x
#declare F_Terrain = function { y - F_Relief(x,y,z).gray }
Any idea why the max gradient would be that high? I ended up making a
mesh out of the tga in Rhino instead, but I want to learn to do this
right.
Any help will be greatly appreciated.
Peter Popov ICQ : 15002700
Subject: Re: Isosurface troble
Date: 5 Aug 2002 11:34:13
Message: <Xns9261B21EFFCEDraf256com@204.213.191.226>
Peter Popov <pet### [at] vipbg> wrote in
news:0u5tkuoupvgafcrgfurg3g7a5btgo3sh9q@4ax.com
1. maybe try bluring HF map ?
2. mabye there is problem with reding this map, i.e. if it was a 16-bit
gray, *maybe* it can lead to strange results.
btw, it's a greate example for my iso-optimization future ;)
Date: 5 Aug 2002 11:51:38
Message: <fk7tkus0s3vikru6khhkja2j97diatip1a@4ax.com>
On 5 Aug 2002 11:34:13 -0400, "Rafal 'Raf256' Maj" <raf### [at] raf256com>
I want the detail - I didn't spent two hours generating a
high-resolution terrain in World Machine just to kill it with a 20
pixel gaussian blur :)
I don't think so - it reads just fine as a height field or image map.
Looking forward to it (with a grain of salt, if you don't mind)
Date: 5 Aug 2002 11:57:23
Message: <Xns9261B60CE7FAAraf256com@204.213.191.226>
news:fk7tkus0s3vikru6khhkja2j97diatip1a@4ax.com
well - now I'm just going to simulate this patch, because I don't like
modyfing not my C code, especialy as huge as Pov's :)
patch coded into POV probalby willbe ready in 1..6 months (imho)
You may try to simulate it now - divide iso into several small iso's in
union. Then, if You are lucky - some small iso's will have low
max_gradient, and only few fragmeents will need high max_gradient.
But, if You have meany spikes all over the map - it will not help :/
send to me scene + .png (mailto:pov### [at] raf256com) maybe I can help
other idea is ofcourse to use standart HF.
Or maybe - bound ISO with HF (maybe scalled a litle)
Date: 5 Aug 2002 12:09:06
Message: <3D4EA321.B3401113@gmx.de>
>   pigment {
>     rotate 90*x
> right.
Try 'interpolate 4'.  IIRC interpolate 2 does not lead to a continuous
function, therefore the high gradient.
Last updated 03 Aug. 2002 _____./\/^>_*_<^\/\.______
Date: 5 Aug 2002 16:33:26
Message: <j5otkusk7i8inma9k1ve884iqup9c7rber@4ax.com>
On Mon, 05 Aug 2002 18:09:05 +0200, Christoph Hormann
*slam*
/me stupid :( I completely forgot about that.
Thanks, I'll try that (for the sake of the experiment).
Now, any idea about some sane RMF parameters? I'm aiming towards a
water look.
Date: 5 Aug 2002 16:58:41
Message: <3D4EE701.AF500714@gmx.de>
> water look.
Searching the newsgroups for 'f_ridged_mf or ridgedMF' finds:
Subject: Re: iso - ridged mf question
Date: Mon, 12 Mar 2001 19:35:40 +0200
Newsgroups: povray.unofficial.patches
news://news.povray.org/3AAD08EC.ED0A6178@aetec.ee
http://news.povray.org/3AAD08EC.ED0A6178@aetec.ee
Subject: How high? - Iso question
Date: Thu, 12 Apr 2001 15:12:37 +0100
news://news.povray.org/3ad5b7d6@news.povray.org
http://news.povray.org/3ad5b7d6@news.povray.org
Subject: water tunnel water source
Date: Mon, 30 Apr 2001 08:43:27 +0200
Newsgroups: povray.text.scene-files
news://news.povray.org/3AED098F.811CBF30@gmx.de
http://news.povray.org/3AED098F.811CBF30@gmx.de
Subject: RidgedMF clouds
Date: Tue, 20 Jun 2000 22:26:11 -0700
news://news.povray.org/395051F3.13CA5AB5@aol.com
http://news.povray.org/395051F3.13CA5AB5@aol.com
Subject: Re: ridgedMF-Mountain - params?
Date: Thu, 3 Aug 2000 14:34:55 +0200
Newsgroups: povray.newusers
From: "Marc-Hendrik Bremer" <Mar### [at] t-onlinede>
news://news.povray.org/39896757@news.povray.org
http://news.povray.org/39896757@news.povray.org
Subject: Isowater
Date: Sun, 5 Nov 2000 14:37:40 -0000
news://news.povray.org/3a0570b4@news.povray.org
http://news.povray.org/3a0570b4@news.povray.org
Subject: ridged multifractal w. slope-dependent texture
Date: Thu, 18 Jan 2001 04:18:47 -0600
<per### [at] aolcom?subject=PoV-News:%20&body=Relating%20to%20POV-Ray:>
news://news.povray.org/3a66c2b7@news.povray.org
http://news.povray.org/3a66c2b7@news.povray.org
And maybe try:
http://www-public.tu-bs.de:8080/~y0013390/pov/rmf.html
Date: 5 Aug 2002 17:01:13
Message: <3d4ee799@news.povray.org>
interpolate 2 does lead to a continuous function. It doesn't have a
continuous derivative, but it is continuous, so there should be no infinite
max gadient.
Perhaps the high gradient is appearing at the very edge of the image? Check
that your isosurface's contained_by box doesn't exceed the edges of the
image.
Seeing the code may help, also... and perhaps the image too if that doesn't.
 - Slime
[ http://www.slimeland.com/ ]
Date: 5 Aug 2002 17:06:55
Message: <3D4EE8EE.F73599A3@gmx.de>
> max gadient.
Do you write this because you have used 'interpolate 2' a lot with
isosurfaces and had no problems or because you *think* it has to be
continuous.  At least the last time i tested (some beta version of 3.5)
'interpolate 2' did not lead to usable results.
Date: 6 Aug 2002 17:02:17
Message: <3d503959@news.povray.org>
Of course this raises the question why do you want to use an isosurface
to create a heightfield at all?
  The only thing I can think of is that you want to use non-linear
transformations on the heightfield. Creating a mesh instead of an isosurface
will lead to enormously faster render times, and you can move the vertex
points at will, which simulates non-linear transformations.
  I think there are macros in the official distribution for this (I don't
remember if they allow transformations, but if they don't, you can make
your own version of the macro with vertex transformations).
Date: 6 Aug 2002 20:01:11
Message: <chrishuff-FA70F0.18510906082002@netplex.aussie.org>
In article <3d503959@news.povray.org>, Warp <war### [at] tagpovrayorg>
Less memory, no trouble with faceting or other triangle problems.
There are height field generator macros, they don't really have any
advantage over the height_field primitive except that there are
cylinderical and spherical versions available. (and I like the smoothing
better)
You still have the "no overhangs" restriction, for example. However, the
code is there, so you could modify it to do whatever you want.
Date: 6 Aug 2002 22:24:20
Message: <3d5084d3@news.povray.org>
  He is using an image to create the heightfield...
Date: 7 Aug 2002 09:46:57
Message: <3D5124D2.22BBCFF6@gmx.de>
Using image maps in isosurfaces can be very useful if you want to add a
fine structure to a rough geometry defined by an image.
Date: 7 Aug 2002 10:36:17
Message: <3d513060@news.povray.org>
  You could do that with a mesh as well, and get a much faster rendering. :)
Date: 7 Aug 2002 11:25:54
Message: <3D513C00.3BE6D954@gmx.de>
That's quite difficult and it would take incredible amounts of memory.
Date: 7 Aug 2002 12:50:08
Message: <pkj2lu8qbf9l05ccdf8lpd116lme0ufe7v@4ax.com>
Because I want to have the sides of the HF as well. I spent a whole
afternoon trying to resurrect the old HF clipping trick that I used so
often in the past, but I just can't get it to work anymore.
The render times are not impossible with a 16-bit grayscale PNG image
as a source and interpolate 4. The render time for my last picture was
just over 16 hours with two such isosurfaces, one of them refractive
and filled with media, and nested in a refractive CSG object, and well
over 5000000 photons. 16hr is not that bad for such a monster,
especially on a puny computer like my 400 MHz K6.
I ditched the idea and used a ridged multifractal function instead,
just because I couldn't make the HF I wanted in WorldMachine.
Date: 7 Aug 2002 15:00:13
Message: <3d516e3d$1@news.povray.org>
  Subdividing a mesh is not difficult at all, and it does not take
"incredible amounts of memory", just the extra memory needed for the
extra vertex points and triangles.
Date: 7 Aug 2002 15:01:22
Message: <3d516e82@news.povray.org>
  Sorry, but I didn't understand this.
Date: 7 Aug 2002 15:21:27
Message: <3D517335.6A434EDC@gmx.de>
Subdividing a mesh and displacing in normal direction is not camparable to
distorting an isosurface function and it can take enormeous amounts of
memory to generate a mesh of such a resolution.
Date: 7 Aug 2002 16:11:58
Message: <chrishuff-66C5CA.15020107082002@netplex.aussie.org>
In article <3d5084d3@news.povray.org>, Warp <war### [at] tagpovrayorg>
And what does that have to do with faceting?
Date: 7 Aug 2002 16:12:58
Message: <3d517f48@news.povray.org>
  Why not?
Date: 7 Aug 2002 16:13:18
Message: <chrishuff-2D8F4D.15032107082002@netplex.aussie.org>
In article <3d516e82@news.povray.org>, Warp <war### [at] tagpovrayorg>
The sides of the POV height_field primitive are open, it is just a
sheet. He wants them to be closed, something that I've wanted before too.
It should be possible to get the desired effect using an intersection of
a height field and a box.
Date: 7 Aug 2002 16:21:21
Message: <3D518140.E58214B1@gmx.de>
>   Why not?
For example subdividing a mesh can not generate surfaces separated from
the main object.
Date: 7 Aug 2002 16:29:31
Message: <chrishuff-24E16E.15193407082002@netplex.aussie.org>
In article <3D518140.E58214B1@gmx.de>,
> the main object.
That wouldn't exactly be subdividing, but it certainly is a process that
could be done to a mesh.
Date: 7 Aug 2002 16:33:42
Message: <3d518426@news.povray.org>
  An image has a limited resolution and thus it will produce faceting.
Date: 7 Aug 2002 16:34:35
Message: <3d51845a@news.povray.org>
  Well, do I have to say more?-)
Date: 7 Aug 2002 16:37:19
Message: <3D5184FF.58935ED8@gmx.de>
> > the main object.
I don't think so (apart from tesselating the isosurface of course)
Date: 7 Aug 2002 17:24:50
Message: <jp33lu4h4sf8knpgf3l3ltugem5shjpp0i@4ax.com>
On Wed, 07 Aug 2002 15:03:21 -0500, Christopher James Huff
I know it _should_ and it works in some cases, but it doesn't always
work. The old trick used was to clip the HF with an open cylinder and
union it with the cylinder clipped by the HF. However, there's no open
box except for an open prism, and that produced artifacts that sturm
didn't fix. It didn't work with clipping or intersecting it with a
regular box either, nor with a semi-open box clipped by a plane.
Do you really think I am _that_ new to POV? :)
It just occurred to me I didn't try intersecting it with a mesh box.
Back to the drawing table.
Date: 7 Aug 2002 21:13:05
Message: <chrishuff-526A42.20030907082002@netplex.aussie.org>
In article <3d518426@news.povray.org>, Warp <war### [at] tagpovrayorg>
Not on an isosurface. You might get a lumpy appearance from the
interpolation, but not faceting. And that lumpy effect is preferable to
black edges or faceting in some cases.
Date: 7 Aug 2002 21:29:04
Message: <chrishuff-7E8DB1.20190807082002@netplex.aussie.org>
In article <jp33lu4h4sf8knpgf3l3ltugem5shjpp0i@4ax.com>,
I said a box and I meant the built-in "box" primitive.
I just tried it and it works fine. Under what conditions doesn't it
work? Are you making sure the box sides are "inside" the height field?
The artifacts you describe sound like coincident surface problem, or the
box surface being coincident with the height field in/out boundary.
Either use a slightly smaller box or slightly larger height field.
I really wish you could just put "open false" in the height field
block...maybe I'll code that up as a patch someday. It should really
default to on, but having it off by default would preserve backwards
compatibility.
Date: 8 Aug 2002 07:20:20
Message: <8ik4luscie2tt0p7u7grroorrjghs0dkau@4ax.com>
On Wed, 07 Aug 2002 20:19:08 -0500, Christopher James Huff
Yes, first thing I tried.
>work?
When viewed from certain angles? Maybe when the look_at point is
inside the thing? I'll have to test this more comprehensively but I'm
currently using the computer for other things (yeah, real life :( )
Of course, although I tried it the other way around as well since it
shouldn't matter.
The HF is scaled 1.1, should be more than enough.
>compatibility.
Yes, I've wished for that as well. Kudos if you get it working.
Date: 8 Aug 2002 14:07:30
Message: <chrishuff-4CC33D.12573608082002@netplex.aussie.org>
In article <8ik4luscie2tt0p7u7grroorrjghs0dkau@4ax.com>,
> >work?
I suspect you mean "location", since look_at couldn't possibly cause the
problem. That shouldn't matter...POV should only care what surfaces are
in what volumes. I put the camera inside and it renders fine. "Certain
angles" is a possibility that I can't duplicate, but I don't see any
reason for it to happen. My tests work from above, from below, from the
side, and from inside. Could you post the code you are using?
> shouldn't matter.
No, it matters quite a bit. Since the height field doesn't have sides,
POV can only check that the sides of the box are inside the height
field. If they are outside, they are ignored with no height field
surface to replace them.
